Question about AMD Sempron 3000+, 1.6 Ghz (SDA3000AIO2BA) Processor
My Sempron 3000+ at 1.6GHz is shutting down just before loading Windows, only if the booting time is short. If I push the pause button during boot and wait for 3-5 minutes, it will load Windows without any problem. I reinstalled the windows ( now I have Windows7 Ultimate ), but it keeps shutting down. I have a GeForce6100 SM-M motherboard ,1Gb( 2x512) DDR2, dual channel and a 400W power source.
5 Suggested Answers
djnick989
  • 1067 Answers
SOURCE: I Can't Install Windows XP Operating System on my AMD Sempron Computer
cheak ram clean disk ? try one ram do partion on hard drive del it then make new one then slow formatt then install ok and update call it in
Posted on Jan 18, 2008
  • 942 Answers
SOURCE: windows xp sp2, amd sempron 2800
you just need to go to the website of your motherboard brand, then after that you just click the motherboard, when you are now in the site just type your motherboard model, then click the driver, then chose the US when you download the sound and video driver
Posted on Jun 30, 2009
Geekman
  • 32281 Answers
SOURCE: I have lost my driver
You can download the device drivers for your computer from the motherboard manufacturer's WEB site.
I cannot give you the link to the motherboard manufacturer's WEB site because youhave not provided me with the details of the make and model of your motherboard.
Posted on Apr 25, 2011
  • 674 Answers
SOURCE: I have Installed Windows7 on
- Windows 7 BSODs are often due toheating issues inside your computer. If you are using a desktop computer thentry to install a better cooling fan. Or simply you may turn off your computerfor sometime and start computer again. - BSOD may also happen when there islow RAM installed on the system. Some programs need more memory space to runand adding RAM would give your computer much needed boost. - One of the most important aspectof operating system is its registry. If there is minor corruption in this partthen it may lead you to errors similar to Windows 7 Blue Screen. There are somereadily available registry cleaners on the market. You may choose reginout asits secured. As we cannot stress enough thatmanual modification of registry is dangerous as well as difficult but anymistake in its modification can cause some of your programs to stop running. It would be wise to select aregistry cleaner that also offers you a feature of PC optimization. Using its PC optimizer feature youcan even remove browser junk, system junk and also manage the start up items toincrease the boot speed of Windows 7 computer.
Posted on Jun 23, 2011
Reset switch of toshiba satellite M35x
I would definitely Try booting in safe mode to see if it at least loads up the basic system. If it does this then you need to explore what it is that you last installed or did. Hopefully you had a restore point set up but even if not it still is not the end of the world.
But the answer to your question is to press <ctrl> <alt> and <del> all at the same time and this should reboot the system. If it does not you have no choice but to use the power button. If when you push the power button the system doesn't turn off you need to hold it in until the system shuts down. The system will shut down it takes a few seconds (may seem long but it isn't )
When you push the power button and turn the system on start pushing <f8> right at the load screen (you can go ahead and just keep tapping it all the way from the time you turn on the power until it loads the alternative options screen). At the screen select safe mode and see where that gets you.
Good Luck
Sep 07, 2012 | Toshiba Satellite M35X-S114 Notebook
Shut off in middle of system reboot to earlier date and will not boot up now.
Hello
The fault should be of its bios backup battery. It is 3V disc battery. Just switch On the system, and press 'delete' button during boot up to enter its bios settings, and see whether the time is correct. If not set the time and reboot again and see whether it boots up normally. If it does, and it won't boot up normally after shut down, repalce the battery with a new one, set time as dectibed above once again. The system will be alright. OK.
Jan 21, 2012 | Toshiba Satellite P105-S6197 Laptop
Computer would not booy up. now it does but the password does not work
which operating system ant what type of computer??
Restart your computer
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
also
how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased
or if using XP
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer Advanced Boot Options screen appears. Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system. Press ENTER. Shortly, the welcome screen should show.
Log in as "Administrator". Click Yes to not use System Restore Mode.
Click the Start button. Choose Run and type in "control userpasswords" (without the quotes). Click OK.
Select the "Administrator" user. Click Change my password. Enter a new password in the corresponding text boxes. Click OK. Write this password down and store it in a secure place Close the User Accounts window and restart Windows.
hope this helps you
Sep 10, 2011 | Computers & Internet
I've inherited this ic power nc5560 notebook at work. several people have had the thing before I got it and it's so loaded down with **** (apps, files and other garbage) that the things is...
Typically each hardware manufacturer has a key stroke to hit during power on that will take you a system recovery mode (basically reload the operating system that was loaded when sold). The hard drive usually will have a second partition that is not visible inside Windows. This partition holds the "image" of the base operating system. If anyone deleted this partition you cannot factory reset without install CDs.
Alternative: Try booting into safe mode by hitting F8 during boot (this will not load all the garbage apps). Once in safe mode uninstall as many application that you do not need, then boot windows normally and run disk defrag a few time to help improve performance. Hope this helps.
May 19, 2011 | Computers & Internet
HI I have a D865 PERL m/b. The CPU overheated, due to a load of dust blocking the heatsink fins. I have cleaned it all up and the heatsink should be fine now, but when I try and boot I get a message...
or
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
hope this helps
May 14, 2011 | Intel D865PERL Motherboard
Hi, i have a Sony vaio and it was working fine until I shut it down overnight, the next morning I tried to turn it on which started out fine but as soon as the windows emblem started loading, it didn't...
or
Also you might try
hope this helps
May 01, 2011 | Sony Computers & Internet
When booting up the devise, only the GPX logo appears. seems stuck and won't shut down unless i remove the battery. switch to off position does not work. I can load and delete mp3 files from the computer...
or you might try
hope this helps
Apr 10, 2011 | Computers & Internet
Boot up takes too long
This happens when the computer gets full of "junk" (this happens with any computer over time) and can be remedied with a fresh windows install.
If you don't plan to reinstall windows in near future I suggest you go to Control Panel -> Add/Remove Programs and uninstall any software you don't use/need
Also tweaking the system registry migh help speed up boot time:
1. Click ‘Start’ then 'Run’
2. Type in ‘Regedit’ then click ‘Ok’
3. Navigate to ‘HKEY_LOCAL_MACHINE\SYSTEM\Cur rentControlSet\Control\Session Manager\Memory Management\PrefetchParameters\ ‘
4. Right-click on “EnablePrefetcher” and set the value to ‘0′
5. Close 'Regedit'
6. Navigate to 'Windows\Prefetch' folder (usualy drive on C:) and delete all its contents
5. Reboot.
7. Enjoy greatly improved boot time ;]
Hope this helps!
Oct 01, 2008 | Shuttle MS51N Motherboard
Hp xw 6000, keeps shuuting down during initial boot up.
reseat ram if not i'd say to take 1 stick of ram at a time and start the computer with such might be a ram issue or run memtest 1.7 which can be downloaded here http://www.memtest86.com/ boot to cd once downloaded and burned to test ram
Mar 19, 2008 | HP XW6000 PC Desktop
Your CPU may have a problem
Have you removed all memory, other cards and unhooked all other drives to see if a short exists there? With a 300W PS some other component may be pulling too much that the CPU can't start so it tells you the problem is with the CPU or The CPU its refering to is on the video card? Good Luck, Tim
Feb 10, 2007 | Albatron K8T800 (K8X800 PRO LL)...
AMD Sempron 3000+, 1.6 Ghz (SDA3000AIO2BA) Processor Logo
59 people viewed this question
Top AMD Computers & Internet Experts
David
David
rafnix
rafnix
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
