Question about Garden
I am looking to add an additional light on my deck. Can I run a wire from the existing light over to where I want the new light?
  • jgov09 Oct 14, 2010
    Just wanted to be sure!
    Thank you
    John
  • 3,051 Answers
Hello there and thank you for choosing FIXYA
Ok yes you certainlly can connect or even splice into a existing fixture that is already there.
If a light and or wires are all ready there all you need to do is to make sure that the wire that is going to be used is rated at the proper volts IE 110/240 ect ect.
Then when making the connection ensure that the wires are properly connected and have a good connection I highly recommend using the screw on wire caps to connect the wires along with good electric tape to cover the wires and give it a good insulation ok
Also make sure that you have the power disconnected before you start on any electrical project like this ok?
I hope this has helped you out if you need any more assistance please feel free to post me a comment and I will assist you in any way that i can
Best regards Michael
Posted on Oct 13, 2010
How to program my key to 98 ford explorer
for Ford keys (1996 -early 1998 Ford, Lincoln, Mercury)
If you want to initiate a new master key....
1. Insert new key into ignition cylinder and turn it to the ON (RUN) position. The security light on the dash will flash for fifteen minutes.
2. When the security light stops flashing, you have FIVE minutes to start the next step. Turn the ignition cylinder OFF and then back to the ON (RUN) position. The security light on the dash will flash for fifteen more minutes.
3. When the security light stops flashing, you have FIVE minutes to start the next step. Turn the ignition cylinder to OFF and then back ON (RUN) position. The dash will flash for fifteen more minutes.
4. After the security light stops flashing the third time, the new key has been programmed into the vehicles computer and will operate the car. It has replaced ALL the previous electronic key codes and is the ONLY key programmed into the vehicles computer.
If you want to add a key....
1. Insert an existing key into the ignition cylinder.
2. Turn the ignition cylinder to ON (RUN) and back to OFF.
3. Remove the existing key and, within 15 seconds, insert the new key and turn it to ON (RUN).
4. The security light will light up for two seconds to indicate success in programming the key into the vehicle.
5. Don't attempt to start the vehicle with any key for at least 1 minute.
<HR>On-Board Programming Method "C"
for Ford keys (Later 1998-newer Ford, Lincoln, Mercury)
1. This requires that the vehicle be connected to special dealer equipment. There are two ten minute delays involved while this device erases all existing key programming and sets up the vehicle computer to accept new key codes. Two new keys should be ready because the system requires a minimum of two keys in the program. After the first two keys are programmed, additional keys can be entered individually by following the instructions for adding duplicate keys (below).
**You must have two original keys to perform this procedure. If you only have one key, you WILL have to take it to the dealer to get it programmed**
1. Insert and existing (working) key into the ignition cylinder.
2. Turn the ignition cylinder ON (RUN) and back to OFF. Ignition should stay on for at least ONE SECOND.
3. Remove the existing key and, within TEN seconds, insert a second working key and turn it to ON (RUN) and the back OFF. Ignition must be in ON for at least ONE second, but no more than TEN seconds. Remove the key.
4. Insert the new key before TWENTY seconds have elapsed and turn it to ON (RUN). Leave it the ON position for at least ONE secondand turn back to OFF.
5. The security light will light up for THREE seconds to indicate that the new key has been successfully programmed.
6. To program additional keys, repeat steps 1 through 5
As a precautionary measure for all of the above procedures, you should wait at least one minute after you have performed this until you start your vehicle.
Dec 10, 2016 | 1998 Ford Explorer
How to wire a two way switch for a staircase
Copy following link for 3-way switch wiring diagram:
http://waterheatertimer.org/How-to-wire-switches.html#3-way
Add a comment and say if you are adding a 3-way switch to existing single-pole switch.
You need 3 wires running to new 3-way switch.
Mar 16, 2013 | Electrical Supplies
I needed to add another light fixture and mount the switch next to an existing switch to another light fixture. When i run the hot wire from the existing switch to my new switch for the positive and t
You can use a double switch, or make a '2-gang box' by adding another switch.
Copy following links for wiring multiple switches inside same box, and wiring double switch.
http://waterheatertimer.org/How-to-wire-switches.html#double
http://waterheatertimer.org/How-to-wire-switches.html#gang
Here is image showing 120Volt wiring inside main breaker box, so Hot Neutral and ground are clearer.
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-8-8.jpg
Aug 23, 2012 | Home
Renault master wire colours
Looking to add LED lighting to rear load area in new 2012 renault master , needing to tap in to live cable but there are three cables behind existing lights -black-blue black-red black-lightBlue any ideas what's live and what is neutral ? Thanks
Jun 30, 2012 | Renault Sportwagon Cars & Trucks
I have alpine sps600c & am installing them in a 2001 Nissan frontier w/ 6 disc 6 speaker (2 ea in each ront door, 2 in back (crew cab). Do I wire my tweeters to existing tweeter output, or...
Did you change out the factory deck? If not, wire the tweets to the existing wiring. If you already have tweets they have been crossedover already. However, if you replaced the deck, you may need to run new wire to the doors and use the crossover that came with your component set. Hope this helps
Sep 05, 2011 | Alpine SPS-600C Car Component System
HI, I HAVE A SYLVANIA MODEL SA 170 , I CAN&#180;T SEE THE NUMBERS WHEN I&#180;M IN FROM THE SCREEN, IT&#180;S APPEARS VERY DARKS
If I understand correctly, you have Sylvania 170 timer and the display doesn't light up.
If you have different problem, add a comment.
A) If this is existing installation and timer display worked correctly before, then it sounds like timer malfunctioned or power to timer is interrupted. Check breaker, and then pull out timer and test for power.
B) If this is new installation, then 2 possible things:
1) Timer defective: exchange for new one.
2) Timer not wired correctly.
Review wiring:
Timer replaces single pole switch.
Single pole switch has two wires
Timer has 3 wires: Blue Black White
Timer has additional wire to run internal clock and to light up display.
If timer not wired correctly, then display will not light up.
Here is correct wiring:
a) Two wires from switch.
b) Connect timer-blue wire to one of the switch wires. Choose either one for now. You will have to choose other wire if display doesn't light up.
c) Connect timer-black wire to other switch wire.
d) Timer-white wire does NOT connect to either switch wire. Look in back of electric box. There are white wires twisted together and covered with wire nut. These are neutral wires. Connect timer-white wire to neutral wires. This will power the clock and display.
e) If your box does not have the white wires described in d), then connect timer-white wire to bare ground wire.
f) Turn power ON. Does display light up?
g) If display lights up, switch is wired correctly.
h) If display does not light up, then reverse timer-blue wire and timer-black wire shown in step b) and c).
Dec 02, 2010 | Zip Heaters Sylvania SA170 15 Amp Zip-Set...
How does levition 6696 switch work?
The Leviton 6696 Anywhere RF(Radio Frequency) lighting control allows you to add an additional (wireless) switch to an existing switched light(s) without having to hard wire it. For example, let's say that you have a bedroom with a switched overhead light. The Leviton 6696 RF receiver would be installed in place of the existing light switch. It will still function and is wired the same as an ordinary switch. The Leviton 6696 Anywhere RF transmitter (after installing the batteries) can then be used anywhere within 50 feet of the receiver (that replaced the existing light switch) to also control the light. You don't have to mount the transmitter if you don't want too. It can be on the night stand, (or carry it with you if you want) so you can turn the light ON and OFF from the bed or wherever.
Oct 21, 2010 | Leviton #601-6696-I Ivory Wireless 3WY...
I would like to add a outlet to an existing outlet
You will need to wire the outlet, and then run a jumper from the white to the white on switch 1 and 2.
you will need to wire the end switch and middle swtiches normally with the ground and black wires.
the white wire jumpers will run from outlet (GFI if in a bathroom), to middle switch hot, to end switch hot.
Apr 27, 2010 | Hammering
Adding an additional light switch to an existing light
To add a second switch to control an existing light, you need to get a 3wire cable between the two switches, Thats red, black, white, green wires in the cable. Then you would have to use two 3way switches to make it work. I posted a "tip" on how to wire the 3way switches ..
Please Vote !!
Mar 28, 2010 | Cooper Lighting Lighted Switch
Hard drive
Yes, it is possible to do so. Adding a DVD is pretty much the same for most PCs. I suggest getting an 80-wire cable. The simplest solution is to replace the existing CD drive and cable with a new 80-wire cable and a DVD drive. You'll have to get drivers for it as well as software to use it (if the drive doesn't come with any). If you want to add it and use the existing CD, then you'll need to open the case, add the 80-wire cable (in addition to the existing cable) into the second IDE cable connector on the motherboard. Check these instructions from Dell. (Note they suggest connecting it to the existing cable, but that may or may not be possible.) Go to:
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/drives.htm
Jan 17, 2009 | Dell Dimension 2400 PC Desktop
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
