Removed the range to install counter tops now have an F-1 Error code.
SOURCE: F1-1 error on Jenn-Air Range
VANMAN69, I have looked in the door under the oven door and can not find the codes. Any more suggestions? I have had a repair man come and replace my control board but I am still getting the F1-1 fault code and when using the oven I get the F3-1 fault code.
SOURCE: 2001-2002 GE Spectra XL44 Gas Range Parts search
it is your lucky day.....I have 4 grates/burners in gray .....make an offer before I put them on Ebay.
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
SOURCE: Want know how to open the top of range to clean?
This is not really meant to be done by user. If done incorrectly you could easily bend or break the gas lines to the top burners.
First you need to remove all the screws in the top burners and remove the burners. Then carefully twist out the ignitors. They do not necessarily have to be disconnected. Then remove all the knobs in front. and remove the manifold cover (that's the cover behind the knobs).
You will then be able to remove the screws that hold the top down and lift the top up high enough to clean under it. Lift this carefully though making sure that the gas lines do not bend when you do it.
SOURCE: Oven wont light
Mine did that and I found the ignitor for the oven was bad. It was the "glow" type for pilotless ignition and it was burned out. It is supposed to glow bright red and the gas comes on and the oven will light. It was easy to tell that it was bad. But to check it I swapped the broiler ignitor with the oven ignitor and the oven worked.
-F1- beeps with regularity, already had the electonic range control replaced once (at $250) and only solved problem for a year.
