Question about HP Computers & Internet
Can not load aol games. tried to disable pop ups did not work
    Guru:
  • 1,342 Answers
Try updating your flash player.
Click HERE to get it.
Posted on Jun 01, 2008
My game is freezing up and will not play
Bejeweled has been giving so many people a lot of problems, it also happened to me, I uninstalled it, and then reinstalled it and now it's working fine again.
Sep 16, 2014 | PopCap Games Bejeweled Blitz
Dolby profile selector has stopped working
Reinstall or disable.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Nov 02, 2012 | Computers & Internet
I have automatic aol schelued howcan i cancel this
Disable Automatic AOL The AOL software lets you turn off the the Automatic AOL feature any time you like.
Disable a scheduled Automatic AOL session You can disable all sessions or any particular session of Automatic AOL.
To disable a scheduled session, do the following:
1. Click the Mail menu, and then click Set Up Automatic AOL.
2. Click the Schedule Automatic AOL icon.
3. Uncheck the box next to the day which you want to cancel the scheduled session for, and then click the OK button.
4. Click the X button on the upper right of the Automatic AOL window to close it.
Disable the Automatic AOL scheduler When you turn off the Automatic AOL scheduler, Automatic AOL will no longer run at predefined times.
To disable the Automatic AOL scheduler, do the following:
3. Uncheck the Enable Scheduler box to clear it, and then click the OK button.
Jul 15, 2011 | Computers & Internet
When I receive messages from Stthomasepis@aol.com with a file attached, the file will not open and I get the message in the box that opens saying, "Browser is blocking Pop-ups." This is my...
Normally when this message appears a yellow bar at the top of the browser is also present. In IE you just need to click on it and chose the option that says "allow pop-ups". In Firefox there should be an "Allow" button at the right hand side of the yellow bar.
Best of luck to you mate!
May 05, 2011 | Computers & Internet
Java Problem
your java will most likely need to be updated or it is disabled in the internet explorer. try using FIREFOX instead of internet explorer. this is faster more secure and will allow java to run.
Oct 24, 2009 | Computers & Internet
To eliminate popup AOL's SpyZapper No Longer Available
AOL FINALLY listed the way to remove this major annoyance.
And it actually WORKS.
Delete the SpyZapper components manually. Log in to your computer using the administrator username and password, and then search and delete the following files:
  • AOLszs.drv
  • settings.ini
  • OptScan.exe
Note: Generally these files are located as below:
AOLszs.drv & settings.ini files location:
  • In Windows Vista: C:\ProgramData\AOL
  • In Windows XP: C:\Documents and Settings\All Users\Application Data\AOL
OptScan.exe file location:
  • In Windows Vista: C:\ProgramData\AOL.
  • In Windows XP: C:\Documents and Settings\All Users\Application Data\AOL\C_AOL 9.1
Dec 25, 2008 | Computers & Internet
Security issues
http://games.aol.com/help/technical-issues
Games Do Not Work Unable to Play Games. For most game errors there are a couple of steps available that will alleviate the trouble. If you are having trouble you should:
  1. Clear Your Browsers Cache On AOL
  2. Clear Your Browsers Cache on Internet Explorer
  3. Clear Your Java Cache
  4. Browser/Service Error when playing Pogo Games
  5. After you've done the above Once you've performed all the steps detailed above. Close all your browsers. Once all your browsers have been closed, restart them and go back to the game you were trying to play.
  6. More Technical Assistance
Seeing A Red X Seeing A Red X Some members will see a Red X where a game should be running. This happens when a small piece of software provided by the game publisher is not installed. These little programs are called Active X controls. When you see a Red X you need to do the following to get the game running:
1) Close down your browsers (and the AOL client)
2) Open Windows Explorer and go to C:\WINDOWS\Downloaded Program Files
3) Find all non-Java labeled files
4) Right-click it and select "Remove" for each
5) Open up Internet Explorer or AOL and try to run the game again.
Slingo Help Slingo Help 1) Make SURE you have the latest version of Java by clicking here. and installing Java (the games need Java to run properly)
2) You will see more of the screen if you use Internet Explorer or Firefox instead of the AOL browser. Just sign onto AOL, minimize the AOL running but leave it running in the background and then open Internet Explorer and go to Slingo
3) If you cannot see the entire game screen, adjust your screen size (the resolution) to 1024x768. Then you should see the game AND the chat.
4)You can play in any state and any room by clicking on the regional tabs inside the game lobby.
5) You can play in ANY of the game rooms regardless of what state you are from by clicking on the “Play” button in the lobby. Pop-Up Blockers Pop-Up Blockers Some of our games open as a pop up. If you click on one of our games at it is blocked it may be due to a pop-up blocker. You can make sure that AOL games are never blocked by adding AOL.com and Games.com to your pop-up blockers safe list:
  1. Pop-Up Blockers, AOL Games and Games.com
Contact Us -->
Need More Help? If after browsing our help area you still have questions or would like to send a comment, please don’t hesitate to get in touch with us. Your feedback is very important. You can contact us on our monitored Community Forum or by sending email using the Submit Your Feedback link.
Sep 28, 2008 | Computers & Internet
Can not load aol games tried to disable pop ups did not work
Disabling the popup will not solve the problem.
You have to enable popup.
Install latest version of JAVA from Java.com.
Install latest version of adobe player.
Jun 01, 2008 | HP Computers & Internet
CANCEL PARENTAL CONTROLS
"Cancel Parental Controls" keeps popping up? or it keeps asking for a password to go to sites? Either way, you can disable parental controls in the AOL software preferences. For instructions, please see; http://help.channels.aol.com/kjump.adp?articleId=218163
May 20, 2008 | Edirol UA-4FX External Sound System
Computers & Internet Logo
122 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
