Problem with sitecom wl-130 connection
I have recently installed a new Sitecom WL-130 to extend the range of my Bebox router at home. When on the router configuration page, the status is stuck on "scanning" which - according to the manual - means that I need to move the extender closer to the router. This clearly isn't the problem, as they are currently right beside one another. I am able to connect to the Sitecom WL-130 from my laptop, but it doesn't seem to be able to talk to the router correctly, and when I try to connect to the internet, I get "Page can not be found" and "Limited Connectivity".
  • Jassem Jun 03, 2008
    I im trying to conect sitecom expander to my linksys wireless modem model number wag200g. it says that sitecom is connected to linksys but there is no or limited connection massege comes from the laptop when i connect it to sitecom.
I think I have the solution: you have to click on the basic settings tab, then n "site survey" button, then (optional) on "refresh" button.
Now you will get the information about your network, and you just have to check the channel number of the signal from your main router. then you have to set that channel in the "channel" button of the basic settings tab. You also have to choose Universal repeater as working mode of the sitecom device, instead of Access Point.
Hope it helps.
By the way, all these settings should be automatic in such a device.... But this sitecom range extender is ****.
I suggest everybody is reading: DON,T BUY THIS ITEM!!!! Spend 10 bucks more and get a working one!!!
Posted on Sep 18, 2008
Maybe it's not connected 2 your sitecom wl-130 but still 2 your router, choose via network connections the sitecom wl 130.
Posted on Aug 07, 2008
I have lost sitecom installation CD?
Go to this site:
http://www.sitecom.com/support/
enter your module number and you should be able to download drivers from there.
Burn them to a new cd and keep in a safe place.
Jun 03, 2010 | Sitecom (WL -004) Wireless Adapter
Sitecom WL-342 Wireless Router won't access internet.
Make sure there is a network cable going from your ADSL modem into the WAN connection of the router.
If the ADSL modem is wireless, then it is also a router in whihc case you will want to bypass the WL-342 all together.
Thanks,
Pat
Apr 01, 2010 | Computers & Internet
Problems configuring WL-130 Wireless Extender
http://192.168.0.1
then type user name:admin
password is:admin or blank
then enable DHCP.then u can get ip automatically.
Nov 12, 2008 | Computers & Internet
Dwl-2100ap set up propblem
There's quite a bit to know about extending / repeating WIFI signals.
Read about extending a WIFI signal with a Sitecom WL-130 repeater here.
Sep 05, 2008 | D-Link AirPlus G Wireless Range Extender...
Wireless extender
OK.
It's pretty easy:
1) turn on both devices
2) connect to sitecom device.
- you may have to manually set your IP address. (from network resources control panel, TCP/IP tab. Check the istructions, cause you have to choose an address in the same subnet of the sitecom range extender. I mean, the first three numbers must be the same, and the last number of the address must be different, between 3 and 255).
- now you can type the sitecom address into the address bar of your browser (allow pop ups from that address!). The defaut user name is admin, as well the default password.
3) Ok, now you're connected and you just have to set this way in the basic settings:
working mode: universal repeater
now click on site survey and remember the ssid of your main network, and the channel number.
channel: type the channel number of your network (IT MAY CHANGE WHEN YOU TURN OFF\ON THE ROUTER!! so you'll have to change it maybe every day..... **** sitecom device, I HATE IT)
ssid: the ssid of your main network.
4) click apply.
Of course if your WLAN is protected you must set the rigth password and encription algorithm...
Now it should work.. but remember, everyday you will have to change the channel, and sometimes ou will have to reset it, from he toolbo tab.
IT,S BETTER NOT TO BUY THIS DEVICE, cause even the latest firmware is not working properly.
Jul 13, 2008 | Computers & Internet
Compatibility with Sitecom wl 031
This 10dBi omni directional antenna enables you to very easily extend the range of your wireless network. By linking the Omni Antenna to your wireless router, you gain the benefits of an optimum wireless signal while minimising the number of ‘dead spots’ (points in your home where the signal is either weak or lost).
However it does not fit the following types of routers,modems and accespoints:
WL-143
WL-122v2
WL-114/WL-517
WL-114v2
WL-108/WL109
WL-111
WL-106
WL-025
WL-018v2
These antenne's will also fit other brands of wireless products that use an SMA connector
Jan 29, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
3,019 people viewed this question
David Payne
David Payne
