Question about Amana 3.2 cu. ft. Top-Load Washer
Amana Distinction leaks
I have a leak coming from my Amana Distinctions 3.2 cu ft washing machine. I took the front cover off and ran through it's cycles and noticed that when it is spininning fast and the water is being pumped out, I get a drip drip drip of water being slung out from somewhere on the bottom of the tub. What do I do
    Scholar:
  • 110 Answers
This is a very common probelm with AM washer you have a bad upper sping bearing and at this point you need to cut your loses and send this one to the washer graveyard because this repair in labor intense
Posted on Jun 01, 2008
What could be the cause of a leak in the front bottom left of machine?
check the tightness of the gasket. call a pro to avoid more expenses to replace the gasket. thanks .
Feb 28, 2016 | Amana 3.5 cu. ft. Front-Load Washing...
Gunk gets on clothes-stains them,i pulled agitator out and cleaned it off ran bleach thru-its better but still getting on clothes
The problem may be the seal on the transmission failing. If this happens, grease from the transmission (necessary for it to function) will leak and float (recall from science class that oil is less dense that water) up into the washer. As the grease enters the tub, it stains your clothes.
Washer Transmission Replacement Whirlpool Kenmore Top Load Washing Machine...
Washer Leaks Water GE Top Load Washer Tub Seal Replacement Part WH02X10383
Jan 21, 2016 | Amana 3.2 cu. ft. Top-Load Washer
My Amana Front Loader sounds like a pachinko machine intermittently, and leaks water Idea's anyone?
you could have something hung up between the inner and outer tubs. A lot of times, a underwire out of a bra will get hung up between the tubs and can cause a hole in the outer tub. If the unit is over 5 years old and you have to replace the tubs, it's not worth fixing
Feb 26, 2015 | Amana 3.5 cu. ft. Front Load Washer
Leaking from inside door when washing puddle under the machine...took back panel off water leaking from front left side.. HELP
It's located here, just download and save.
http://miele.com/manuals/before_download.asp?id=164&bhcp=1
Mar 23, 2010 | Samsung 4.0 cu. ft. Washer
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Leaks
it could be an old tank, how old is it? it could be rusted out, then again there is a seal between the pump and the tank that could be bad, take off the bottom cover and look with a flash light and run the washer and look and see where it is comming from
May 30, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Hi, I have a 5yr old Amana Distinctions Super Capacity Plus top load washer, 2spd motor, 3.3 cu ft. I have taken off the front cover to expose the wash tub, because recently when the washer is in a spin...
sounds like a drain pump issue, not able to remove water quick enough before the centrifical force of tub spinning throws it over the top, remove the pump hoses and look for blockages
Nov 07, 2008 | Amana Washing Machines
Stall in rinse cycle
loks as if its been amonth since this post, but i would chek your cold water supply, common problem
Sep 05, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Mar 09, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
AMANA DISTINCTIONS FABRIC CONDITIONER RELEASE
Hello Daddy 2,
Welcome to fixya
I'm Huuum and happy to assist you,
What is the model number and the year of the washer?
Front load or top?
A waiting your response!
Huuum
Dec 10, 2007 | Amana 3.2 cu. ft. Top-Load Washer
Amana 3.2 cu. ft. Top-Load Washer Logo
431 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
