Epson EP-X7 projector has a color convergence problem - RGB colors are slightly separated - most blacktext shows green on one edge and red on the other edge, causing a fuzziness.
  • 998 Answers
Try first to adjust it in your remote if still not moving it has a defective convergence ic.
Posted on Oct 13, 2010
I would like to know ow yo fine tune my Yellow and Green colors on my Mitsubishi HD 1080 Series
If this is an auto convergence you may be in for a bit more of a project than you want to be into. If there are separate color guns then you can adjust them individually with a screwdriver from inside
Nov 09, 2013 | Mitsubishi Televison & Video
My RCA P52937SG projection tv. Picture distorted. I beleive it has to do with the green circuit / projector. Everything needs to be aligned to green. Green projector is on, but, in alignment screen I get...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board must have replace the 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 28, 2011 | RCA R52WH73 Projection Television
Image is bright but there is a slight issue - on the left hand side a purple line displays vertically. Anybody knows why is this fault appeared and how could it be solved.
There is three LCD in the projector red, green and blue. If green LCD make any fault mean line or dot or dots then screen show these line or dot in purple color:
If line is very straight and sharp edges then green LCD is faulty and need to be replaced.
If line is not straight and faded edges then some thing in LCD block so your projector need service
Feb 22, 2011 | Sony VPL PX40 Multimedia Projector
Epson PowerLite 83+ goes completely green or red
make sure the signal matches. you could reset the settings to factory default.
Nov 10, 2009 | Epson PowerLite® 83c LCD Projector
My video yellow plug works fine, showing correct video colors yet, the red blue green connection is only showing picture in a pale green
Yellow is composite input if RGB is not working it's probably a cable/output problem try with a different device first.
Aug 28, 2009 | InFocus ScreenPlay 4805 Multimedia...
RGB on Barco Reality Sim 6 diverge at edges...
Should be possible to adjust the convergence having a projector this quality! Call Barco in Belgium and ask them!
May 20, 2008 | Barco Office Equipment & Supplies
Philips model 60PP920217F
You need to replace both convergence ICs STK392-120 they are an easy repair you will also need (4) 6.8ohm Convergence resistors. You can get replacement ICs and the resistors at the following link and they will provide free installation instructions and free on line tech support so you will be able to do the repair yourself and save about 400.00 for a 45 minute repair. heres the link.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Philips Magnavox 9P6034C 60" Rear...
Colour problems with projector
In short If the reds show as red, The greens show as green & Blue shows as blue. I would say thats as good as it can project. It's hard to judge color without seeing it for ones self but usually DLP projectors that use a colorwheel do not have perfect color.
Feb 13, 2008 | Office Equipment & Supplies
Epson EMP TW 10H spares
i can understand what is your mean
Aug 22, 2007 | Epson (ELPLP25H) Projector Lamp for...
Red & Green seem "off centered"
Your set uses the 195 series chassis, which has separate components for each of the 6 convergence channels and a separate power supply for the convergence circuits. If all 3 colors have drastically shifted, especially around the edges, then chances are your convergence power supply has stopped working. This is usually caused by the failure of the STK730-010 switching IC. If one of the colors has dramatically shifted by itself then something has stopped working on the convergence board. Sometimes I see CRT coolant leaking onto the convergence board as the cause. In either case this is something that should be repaired and realigned by someone experienced with RCA projection TV convergence circuits.
Aug 05, 2007 | RCA P46922 TV
Televison & Video Logo
148 people viewed this question
Top Televison & Video Experts
Electro Med Services...
