Question about Motorola Mobility Motonav TN30 Car GPS Receiver
Motorola tn30 GPS, how can I fix? heave a big red X on screen...
Tip
Motorola Motonav TN30 Firmware Fix Does you Motorola Motonav TN30 GPS lock up,...
Does you Motorola Motonav TN30 GPS lock up, freeze, or not load properly anymore? Replacing the system software / firmware of your Motorola Motonav TN30 GPS will fix these and other symptoms of corrupted firmware.
Follow these steps to fix the firmware / system software of your Motorola Motonav TN30:
  1. Start by downloading the Motorola Motonav system software from Motorola from here.
  2. Extract the files onto an SD memory card.
  3. Make sure your Motorola Motonav is fully charged.
  4. Turn your Motorola Motonav off by holding the power button for at least 8 seconds, until the charging LED indicator blinks.
  5. Insert the SD memory card
  6. Turn your Motorola Motonav on. The software upgrade will begin automatically. Select “Yes to All” if prompted.
  7. The full upgrade process can take up to 15 minutes.
  8. When the software upgrade is complete, your Motorola Motonav will
  9. automatically load either the Map screen, Warning screen, or the Language Settings screen, depending on the state and configuration of your device.
  10. Remove the SD memory card from your Motorola Motonav navigation device.
The software upgrade procedure is now complete. Your Motorola Motonav is as good as new again.
I hope that helps.
_______________________________________________
Motorola Motonav TN30 Manual Download
Motonav TN30 Upgrade Manual
Motonav TN30 Firmware Download
on May 06, 2010 | Baby Care
Motonav TN30 blue screen em "X" red
send the unit in for a warrantee repair
Techman
Apr 30, 2010 | Motorola Mobility Motonav TN30 Car GPS...
I am looking for map and software updates for the TN30
See the Moto customer FAQ page, as of Sep.2009, they won't provide map update for TN30!
Apr 06, 2010 | Motorola Mobility Motonav TN30 Car GPS...
Tip
Motorola Motonav TN30 Firmware Download
Does you Motorola Motonav TN30 GPS lock up, freeze, or not load properly anymore? Replacing the system software / firmware of your Motorola Motonav TN30 GPS will fix these and other symptoms of corrupted firmware. Satellite reception is also improved with newer firmware.
Follow these steps to download the firmware / system software of your Motorola Motonav TN30:
1. Head to Motorolas webpage to download the system software.
2. You will presented with this screen:
3. Find and enter your Motonav's serial number. Review the picture below to find the correct number on the label.
4. Pause for moment and consider the Purchase Date. If you enter a date here beyond the covered warranty period of your Motonav TN30, you will see this screen:
Since the default year of this screen is 2007, I recommend choosing a more recent year. Many people complain that they didn't notice this and get themselves locked out of what they should be entitled to.
5. Enter the Purchase Date, click Submit, and save the file somewhere on your computer.
The software download procedure is now complete. Follow these steps to install the new system software for your Motorola Motonav TN30.
I hope that helps.
on May 06, 2010 | GPS
Tip
I hope that helps.
on May 06, 2010 | Motorola Mobility Motonav TN30 Car GPS...
Tip
I hope that helps.
on May 04, 2010 | GPS
Tip
I hope that helps.
on May 04, 2010 | Motorola Mobility Motonav TN30 Car GPS...
Tip
Download Motorola Motonav TN30 Upgrade Manual
Have you misplaced your Motorola Motonav TN30 Upgrade Manual?
Would you like a digital, searchable, pdf version of the Motorola Motonav TN30 Upgrade Guide?
Follow this link (& click FREE) to download a pdf version of the Motorola Motonav TN30 Upgrade manual.
I hope that helps.
Tip
Download Motorola Motonav TN30 GPS Manual
Models: Motonav GPS TN20 / Motonav GPS TN30
Have you misplaced your Motorola Motonav GPS TN30 Manual?
Would you like a digital, searchable, pdf version of the Motorola Motonav GPS TN30 Manual?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
on May 02, 2010 | GPS
Tip
I hope that helps.
on May 02, 2010 | Motorola Mobility Motonav TN30 Car GPS...
Open Questions:
See all Motorola Mobility Motonav TN30 Car GPS Receiver Questions
Motorola Mobility Motonav TN30 Car GPS Receiver Logo
263 people viewed this question
Top Motorola Mobility GPS Experts
Are you a Motorola Mobility GPS Expert? Answer questions, earn points and help others
