Question about Samsung DV218AEW Electric Dryer
My belt came off at the motor...how does it go back on? Diagram please...It loked as it would be simple, just put it back on the motor and tentioner. There is wwaayy too much slack....what am i doing wrong?
  • Samsung Master
  • 7,482 Answers
The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Oct 13, 2010
Could you please show a diagram of how belt goes over motor and tentioner
Mike,
We need a make and model number for your dryer. If you put it in when you submitted your question, it did not come through.
May 18, 2015 | Dryers
How do change a serpentine belt in my 1994 Grand Jeep Cherokee?
first if old belt is still on jeep draw a diagram of how belt is routed first even i get confused motor needs to be cool release tention on belt some have spring loaded tentioners some you have to losen the center bolt on tintioner pully and turn ajusting bolt to losen belt install new belt tention propley
Jan 21, 2013 | 1994 Jeep Grand Cherokee
Need diagram of how to put a serpintine belt on a 2005 chrysler pacifica
  • Hello and thank you for the opportunity to assist you.
  1. 1. The first thing you want to do is jack the vehicle up and make sure you secure it.
  2. Underneath the vehicle is an engine shield with two bolts that have to be removed and the shield dropped to expose the belt. This procedure is for the 3.5 or 3.8 engine See diagram below.
  • Now you take a wrench and put it on the tentioner which is the little pulley. When you put the wrench on the pulley push upward to relieve the tention and remove the belt. This procedure is also for both engines. See diagram below.
  • Now the next thing you want to do is compare the new and old belt to make sure the parts store gave you the right one. Check the length, width and teeth markings. Now install the belt. There are different belt paths depending on the engine size. I will list both.
  • For the 3.5 engine - Pulley #4 is the tentioner pulley. Put your wrench on this pulley to remove the belt.
  • For the 3.8 engine - Pulley #4 is the idler pulley on this one. Put your wrench on this pulley to remove the belt.
  • After you put the belt on you need to start the car and take a flashlight and look carefully to make sure the belt is turning properly.
  • Now turn the car off and re-install the shield and lower the car.
  • Job complete.
  • If you have any questions please feel free to ask.
  • If this solution has satisfied you then please do rate and leave a comment so that others can see the results of my good work.
  • Hope this helps and thank you for using FixYa.
Regards,Tony
Nov 19, 2011 | Chrysler Cars & Trucks
Replace a serpintine belt on a lincoln mark 7 1997
If your asking how. It's simple make a diagram of the belt routing (there might be a diagram on the frame under the hood). Ther is a tentioner pully that holds the belt tight. Get a ratchet with the proper socket fit it on the nut n the center of the tentioner and you can pull the tendioner pully as to le6t the belt have slack. then carefully take it off of the pully . youll have to twist and wiggle it to come out from behind the fan then install the new one in reverse
Sep 09, 2010 | 1997 Lincoln Mark VIII
How to put new belt on
remove back, loosen motor bracket, remove belt, put new onw on, belt size on belt, move motor on braket to put tention on belt tighten motor bracket
May 08, 2010 | Whirlpool Dryers
Placrment of belt
THIS ONE IS TOUGH PUT THE BELT AROUND THE DRUM FIRST THRU THE REAR OF THE UNIT PUT THE BELT AROUND THE MOTOR PULLEY LOOK CAREFULLY AND THERE SHOULD BE WHAT THEY CALL A TENTIONER PULLEY THIS TENTIONER SHOULD GO ON THE BACK SIDE OF THE BELT THIS IS GOING TO BE TOUGH, THEY DON'T GIVE A WHOLE LOT OF ROOM FOR THIS
Aug 09, 2009 | Dryers
Putting the belt back on this dryer
Hello Friend, Replacing a dryer belt is very simple. Just remove front of dryer cabinet. unplug wires from dryer door switch. Just slide a new belt over the drum with the belt grooves facing to the inside. Underneath drum you will see a tention wheel next to motor. Install belt around tention wheel and around motor shaft pully. Re-install front dryer cabinet. Make sure to plug in the wires to the door switch and make sure that the drum is re-inserted back over the felt glide on inner cabinet front. Happy to help, Tim.
Jun 26, 2009 | Hotpoint Dryers
The belt broke drum won't turn
Jun 25, 2009 | Roper REX3614KW Electric Dryer
Dryer heat but what turn
Mar 28, 2009 | AEG T57800 Electric Dryer
Belts
There is a diagram under the hood, most likely next to the emission sticker which is either on the underside of the hood or near the radiator
Aug 10, 2008 | 2000 Dodge Caravan
Samsung DV218AEW Electric Dryer Logo
298 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
