Jet 3 Ultra Power Chair Logo
Posted on Oct 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello , The Lights where the control stick is ( Battery meter ) keep going up and down at a fast pace the chair has been charged , but will not move . any suggestions?
Anonymous
Level 2:
Novelist:
  • Expert 232 Answers
  • Posted on Oct 13, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
232
Questions
0
Helped
80057
Points
339
It sounds like you may have to reset or unlock the controller system. Take a look at this website to find the model of controller for your power chair, then consult your owner's manual for reset and/or unlock procedures.
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
You can also call Pride Mobility at 800-800-8586 for troubleshooting assistance over the phone.
Although my power chair should show all the lights on the battery level meter, the last light isn't coming on, and the chair won't move.
Google
make model manual (impossible to guess what you have Carol)
See if it has a power breaker or reset button. Most do.
Jazzy select gt. batteries are good charger is new when charging the lights go from red to green and repeats, but if i hold the button one red one yellow ? i tested the batteries they are full but joy...
Still your batteries are bad. Had this problem before. If the batteries are more than 1 to 2 years old they need to be replaced. The charger only tells you it can't charge anymore, because the battery is sulfated. The meter on the chair is telling you the batteries are not strong enough to run the chair.
My power chair is so slow, not sure what the speed is but, its slower then walking pace.
check with your operators manual and you may find a switch that has the markings of a hare on one side and a tortoise on the other
that will be you low and high speed settings
Jazzy 1113 power chair shows charged but control light is blicking. Chair will not move.
It appears that the controls are in Lock Mode. Unlocking Instructions depend on your type of controller. Go to PrideMobility.com to download the proper manuals for chair and controller.
1helpful
2answers
How do i know if my jazzy power charger is working
Without the charger the batteries would go dead. You could put a voltmeter across the batteries and you should read more than 28 VDC while charging.
How do I know if my jet 3 ultra is charging? I just bought a used one today and do not have a manual
The chair should have a meter on the rear panel where the 9 pin connector for the joystick plugs into the chair when you plug in the charger cord the meter should move up and the lights on the joystick should flash indicating the charger is plugged in. When the chair is fully charged the meter should read zero or bounce up and down. Hope this helps
1helpful
The charge lights blink and the chair won,t go.
Just had this problem with my Guardian Aspire. They had to replace the electronic box with the joy stick. BIG BUCKS!
Led lights flash and Pride Go chair won't move.
Firstly disengage the drive levers and then "flick "them in fash.
Second pull out the large plug that is between them.
Check for damaged or bent or loose pins. press it home firmly .
I did this on my wifes chair and she zooms around.
All switched etc should be off during charge.
Lastly i fully discharged then recharged the battery to ensure no "battery charge memory".
To fully dicharge i shoved a small box between back wheels so to lift of ground and then a elastic band to hond controler on.
Top Jet Health & Beauty Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
