After cleaning the detergent holder we replaced it and statred a wash cycle, it started OK then the top light started flash on and off and the machine stopped. We took out the garments and pumped out the water OK, then switched of the machine and took the plug out for 1 minute as suggested in the manual and restarted the machine it worked for about 5 mins then the top light started flashing on and off again and the machine stopped mid cycle.
  • info65326 Oct 13, 2010
    Hotpoint DWL520
    Genius:
  • 1,416 Answers
what i the problem like?
thanks once again.
Posted on Oct 15, 2010
  • Oloyede Monsuru Oct 15, 2010
    There
    are several reasons that a washing machine won't drain or spin. The
    cause could be something as easy as a clog or something difficult that
    will need a licensed repairman. Start with the simplest possible cause
    and work down to the more difficult causes.
    INSTRUCTION BELOW
  • A
    washing machine won't spin if the water can't drain. Check hoses for
    any kinks or clogs that may prevent the water from draining. If a hose
    has kinks, try to straighten out the kinked hose. If it can't be
    straighten sufficiently, replace the hose. If hoses are not kinked,
    check for clogged hoses. This can be done by using the screwdrivers to
    remove the hoses and looking for clogs or running a water hose through
    the clogged hose to remove the clog. Use the rags and bucket to clean
    up the water that comes out of the hoses when they are disconnected.
    Once the clog is cleared, put the drain hose back into place. The
    washer should drain and spin now if a clogged or kinked hose was the
    problem.
  • 2
    If
    the washer still won't drain or spin, check to see if the lid is not
    closing all the way or if the lid switch is not clicking into place.
    Close the lid and make sure that it closes all the way down. When the
    lid closes, the lid switch should click. If there is no clicking sound,
    then the switch may need to be replaced. Follow manufacturer's
    directions for replacing the switch. If the lid does not close all the
    way, visually check for signs that the lid is bent. If bent, try to
    bend it back into place.
  • 3
    Loose
    or broken belts could also prevent a washing machine from draining or
    spinning. Pull the washer away from the wall and, using the
    screwdrivers and wrenches, remove the back panel. Using the flashlight,
    visually check for any broken or loose belts. Replace any broken or
    loose belts. Although replacing washing machine belts is difficult,
    anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4
    Another
    possibility for a washing machine to not spin or drain is the pump.
    With the back panel still off the washer, check the pump with the
    voltmeter to ensure that the pump is getting power. If the washer is
    getting power, turn on the washer and listen to find out if the pump is
    running but the water is still not draining. It may be necessary to
    remove the pump and clean it or to replace the pump with a new one.
    Once the pump is replaced, turn on the washer to determine if it will
    now drain and spin.
  • 5
    If
    all of the above steps fail to produce a washing machine that drains or
    spins, then it is time to call a professional repairman. Use the
    screwdrivers and wrenches to replace the panel on the washer and push
    it back against the wall
  • Thanks.
  • Washing Mach... Master
  • 8,220 Answers
All these washers have a way to catch the lint and coins etc. before them thangs can get into the pump. Remove the base panel and remove the hose from tub to pump and clean it out OR simple remove the filter and dump the stuff out. After cleaning the detergent holder - c9175e1.jpga6bc7f6.jpge855125.jpg68db9fd.jpgSome washers don't have this convience instead you remove the tub to pump hose and clean outAfter cleaning the detergent holder - 16d0797.jpgcreen within it. Check the vent hose betwAfter cleaning the detergent holder - faf6051.pnger valve and soap dispenser16d0797.jpgfaf6051.png0bed61f.jpg
Posted on Oct 13, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please revert back with make and model# to assist you with model specific information.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Oct 14, 2010
    TO start with check the drain hose and try to clear the pump filter. If the issue is still not resolved then check the timer and replace the part that has gone bad.
We clean the filter after every wash but we still get black & white bits on the washing wa have cleaned the waste pipe, pump filter at the back is always clean .model no sw75usp can you help under...
Hi bob, have you tried cleaning the dispencer drawer that supplys the detergent to the tub? in some cases over time the detergent holder can collects small amounts of powder that can dry out and stick to the walls of the holder and when the machine is in its spinning stage can sometimes vibrate the dry powder in turn cause the powder to enter the tub also there can be a huge build up of liquid detergent like softners that can form a hard black residue in the holder in turn causing the clothes to collect black paticles. If all is ok then you could try applying a hot wash cycle without any clothes in the tub to flush the bowl from any contaminents, thumbs up if this helps thanks.
May 06, 2011 | Samsung Washing Machines
Water will not spin out. Code says 5d
The troubleshooting page in the owner's manual says: 5d "Sd" Suds Detected - Did you use regular detergent? Regular or hand-washing detergents are not recommended for this washer. Use only High Efficiency (HE) detergent. Did you add too much detergent? Always measure detergent. Follow detergent manufacturer's directions. If excessive suds are detected, the washer will display this code while running a suds reduction correction routine at the end of the wash cycle.The susds reduction routine removes extra suds and asures proper rinsing of your garments. If te code remains and the wash cycle dial is flashing after the recovery routine has stopped, re-select your desired cycle using cold water. Press start. Do not add detergent.
Dec 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F28 error / water starts to fill then quits in 15 sec's
F28 is a communication error which usually means there is a connection that has come loose.Check the wires on the control board.
Nov 22, 2010 | Maytag EPIC MFW9700S Front Load Washer
All lights flash says sd
Sd is displayed when the machine/motor control, by analyzing drag on the basket, detects a suds-lock condition, and is steady on while the control then runs a mini-clean out cycle. If the clean out cycle is unable to correct the over-sudsing problem, the cycle ends and Sd flashes in the display. This may signify: Excessive detergent usage. Basket cannot engage during drain step. Mechanical friction on drive mechanism, not allowing basket to engage.
Sep 26, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
The "clean" light blinks 8 times, then there is a pause, then it blinks once. The dishes are clean but not dry, as if it has not completed the drying cycle. We had an engineer out to fix it who said it...
I'm not familiar with Kenmore but it sounds like a faulty heater element. The flashing 'clean' light normally means a water flow problem (blocked pump etc) but since it's washing that isn't the problem. After washing they dry with steam, which needs a heater.
It may be a problem with the board, as your engineer thought, but i would sooner replace the heater, but they are not easy to reach.
A suds sensor may be present, should be a plastic grille or hole in the side or back wall halfway up, this you can flush with a garden hose, messy but it usually works!
Mar 28, 2017 | Kenmore Dishwashers
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
I have a HE5t kenmore elite front loading washer. It has done great for about 15 months. We were away for about 3 weeks, and since we have returned, I put in a load of clothes, and it tries to start...
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*%^*
Aug 27, 2009 | Kenmore HE2 Plus Front Load Washer
Top Arm does not spin so glasses are not cleaned and detergent is not rinsed out of holder very well.
Make sure the water level is just at or below the heating element. Low water level will cause the pump to "run out of water" before all wash arms and connecting tubing are filled. A pulsing sound during the wash cycle will verify. Low water pressure or a bad water inlet valve are one cause. Water siphoning ou the drain line is another. Look under your sink and verify the drain line goes from the garbage disposal or sink tailpiece all the way up to the bottom side of the coutertop enroute to the dishwasher.
Apr 27, 2009 | Dishwashers
Bravo washer spin problem; lights flashing SD appears. called advised to wash clean cycle and use HE detergent.
the "SD" code is for suds, you are using too much detergent, you generally only need about three teaspoons of detergent, more for heavily soiled or larger loads, the HE detergent is a high efficiency detergent that is low sudsing, the wrong detergent can also affect the quality of the spin cycle.
Apr 07, 2009 | Maytag Washing Machines
Detergent caked in holder after running a cycle, using Cascade
Try this before you jettison your current dishwasher. Yes, it is possible that the wash motor is getting weak, beginning to fail but:
Buy and use a box of brand name box of detergent powder Electrosol or Cascade. Stop using the generic powder and never use a gel or tablet in a dishwasher.
You will be amazed how how much better the detergent dissolves and the DW cleans.
Good Luck!
Mar 31, 2009 | GE 24 in. Profile PDW7800 Built-in...
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
