Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kemore side by side fridge 56072791
Compressor quit working
it is hot but not pumping
where would you find defrost timer?
  • Anonymous Jun 01, 2008
    fridge is not cooling, freezer is not cooling, not blowing any kind of cool or cold air ... everythings is defrosted. Cleaned the entire fridge and vacuumed underneath to get any kind of dirt or debris away. Turned everyting off and back on. Nothing is working.
    Scholar:
  • 110 Answers
Check your ptc first but if you do have a def. timer on this model it is going to be either at the bottom kickplate area or at the main control area in the freshfood side
Posted on Jun 01, 2008
Where is the defrost timer on a kenmore side by side model # 106.58904801
What you should be looking for its a dead fan motor. The condenser fan motor cools the refrigerant and allows the compressor to stay cool with the returning cool refrigerant. If the fan motor is working intermittently then the fridge will do the same. Usually the fan will work for a wile but when it gets hot the lubrication to the bearings becomes poor and the bearings get worn ant the shaft will fall and the rotor will lock up. Condenser fan motor is usually located on the bottom backside of the fridge. Do not run the fridge until the motor is replaced, you can create a whole lot of other problems that will need to be taken care of by a professional. Good luck
Sep 08, 2012 | Kenmore Refrigerators
I have a kemore coldspot side by side maufacture date 04/07 that is not cooling properly. Freezer gets cold but won't freeze and fridge section gets cool. I have checked condenser fan runs and compressor...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 24, 2010 | Kenmore 53642 / 53644 Side by Side...
My fridge wasnt cold yesterday but the light was on and the freezer worked but this morning the freezer has started to defrost and everything was warm in the fridge
If you cant hear the compressor running and he fan under the fridge and in the freezer compartment are not running. The problem would be your defrost timer has quit on the defrost mode. Your defrost timer should be located in the fridge side behind the back plastic liner or if your controls and light are in the center top it will be there. The timer is plastic with a metal motor on one side. There is a shaft in the center that a flatblade screw driver will fit in turn it and you will hear audible clicks and the fans and compressor should kick in. I hope this helps. If the fans are working but the compressor is not the compressor is bad or the start relay on the compressor may be bad it is located under a plastic cap on the compressor and is about the size of a nickle and is connected to one of the 3 prongs coming out of the compressor. Remember to always unplug the fridge before working on it. good luck
Aug 18, 2010 | Refrigerators
Fridge no longer stays cold enough. Compressor will come on for a short time but not long enough to get fridge to proper temp. Compressor seems rather hot to the touch. Fan is working and coils are clean....
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 – Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan – Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper – Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils – Check to see that the condenser coils don’t have a dust build-up and that the condenser motor is working.
* Compressor – Make sure your compressor is working with on and off clicking noises.
Step 2 – Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 – Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 – Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven’t got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn’t work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Hope this helpout in solving the problem
Aug 15, 2010 | Frigidaire FRS-26DR7D Side by Side...
My frost free fridge freezer has stopped working(beko) the fan inside the freezer is consyantly on the food in the freezer has defrosted and the element at the back is usually hot and now its cold
Please checck to see if your thermostat lines are in order or if some of the connecting wires are damaged bby frost. First of all switch off the fridge and allow all frost to clear. then check for the fan circuit, the auto defrost timer circuit. Now after few hours switch on the fridge. Check to see if the compressor is running the back side is getting warm and the freezer is cooling. If not check if the compressor is pumping well or being short of gas-- get help -. If not the timer could be the culprit as after the cooling takes place the fridge does not defrost. Check this out and the fault is confirmed if your fridge works fine now. Hope you try. Good day
Aug 11, 2010 | Refrigerators
My kenmore side by side is not cooling. Everything in the fridge portion seems to be about 50 degrees. After reading we pulled the fridge out from the wall and unplugged it. Something had fallen behind...
Not cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 4 – Volt Test
Good luck.....
Jul 28, 2010 | Refrigerators
FRIDGE AND FREEZER QUIT COOLING
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
I have a kemore elite fridge wont get cold
It can be the defrost timer,defrost element or defrost thermostat or a blocked vent into the fridge
Aug 03, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Came home sunday night and our side by side fridge freezer was not working, just the fan is running, how do i locate a repairman, since this monday is a holiday. i have frozen buckets of water, and placed...
Any frost on back wall of freezer section. If so you have a defrost system problem. If you can hear a hum followed by a click the problem is with the compressor. In back of the refrigerator is a removable panel. remove it and carefully check if the compressor is hot. A cold compressor indicates no power to the compressor which would be related to the temperature control or defrost timer.
Defrost timers are normally located in the area of the temperature controls. Locate the timer and rotate the clutch head screw clockwise slowly until it makes one click. If the timer is the cause of no power to the compressor the compressor will restart. If the problem is defrost related this same action will start the defrost which should take place in 18-22 minutes. If defrost of the freezer coil takes place and the compressor does not restart after the time indicated (wait 30 minutes) rotate the screw slowly one more click and the compressor should restart. If you had to rotate the screw the second time the problem is your defrost timer.
May 19, 2008 | Maytag Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
66 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
