How do I adjust my monitor?
I want to adjust the monitor. In particular I want to adjust the width. I see that in Menu > (the third icon down, a monitor) > there should be a place to adjust the width. However the arrow keys don't move it, the mouse won't select it, the - and + signs don't do anything. How do I move around within menu so that I can make adjustments?
Thank you,
Donair
  • 1 more comment
  • Dondi2 Jun 07, 2008
    Not quite what I needed but I was able to get a Users Manual so I should be able to figure it out. Thanks for your help.
  • pevans746 Oct 10, 2008
    Sure.....you say "Select the Option" but HOW? Like the last person said, the mouse doesn't do any selecting, re-pressing the buttons does nothing, + and - does nothing, holding the menu button down does nothing....so how do you "Select an Option"?
  • kitkat8541 Nov 06, 2008
    I have a chi mei 221D monitor and the task bar at the bottom of the screen is outof sight because the adjustment on the monitor is off. i cannot figure out how to manually adjust the image. please help.
  • 55 Answers
1)Press Menu button once to get the Main Screen Of Menu
2) Select the option which you need to modify (Ex. Brighness)
3) Now again press Menu button to get into that sub menu (Brightness)
Posted on Jun 02, 2008
Sound stopped
There's not much to go on here, but I'll do my best to help. It seems most likely that you turned audio off on your monitor or via your computer's operating system.
If the monitor setting is the problem, you can change it by using the down arrow button on the front of the monitor to scroll through the monitor menu. The fourth item should be Audio Adjust. After highlighting that one, push 2 on the monitor to select that menu item, then press the up arrow on the monitor to increase the volume. When you're happy with the volume, press 1 on the monitor to exit the menu.
If you muted your computer via the operating system, that won't help. If you're using a computer running Windows, look for a speaker icon at the bottom, right of your screen and click it. Slide the volume arrow up to adjust the volume upward.
If those suggestions don't do the trick, please reply with information about your computer, particularly your operating system (e.g. Windows 7, Mac OS 10.5.8 etc.).
Happy Thanksgiving!
Nov 23, 2012 | ViewSonic VX1932WM LCD Monitor
I hv lg 700s studioworks crt monitor... i hv set a resolution of 1280*1024, but now m not able to control some of its functions like its width size...width has gone out of the monitor, it isnt getting
Hello
Select reset option by monitor menu, set it to default first. Then try to adjust the width and height of the screen. If this does not help you, try other resolutions set by the system.
Nov 26, 2011 | LG Studioworks 700S 17" CRT Monitor
Can't adjust contrast
restore your factory settings and then try
Oct 16, 2010 | Samsung SyncMaster 2253LW Monitor
My westinghouse monitor won't align on the screen. i have tried auto adjust already and it is still missaligned.
Ok, with the Auto adjust, but have you actually tried the buttons that actually manually adjust the screen, size, placement, width, height etc, This will allow you complete control over all aspects of your monitor. You usually select, menu, then step through with one button, and change up, down, side to side, with the left & right buttons.
Mar 02, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
The screen is tilted
You can adjust the keystone of the monitor..
this will remove the trapezoidal shape and square up the image to the monitor.
Check on the monitor for the menu controls and you should be able to find the keystone adjustments... allows you to adjust the upper width, lower width, etc...
Nov 27, 2009 | HP Compaq FS 7550 17" CRT Monitor
The view on my monitor is very truncated - about two inches top and bottom are not filled
Press the MENU button on the monitor and adjust the width and height of the picture to full screen.
Oct 10, 2009 | LG Computers & Internet
I need to adjust the hieght and depth of the screen on monitor X173W LCD
The buttons on the monitor are used for this.
With computer and monitor powered ON, press the [menu] button on the monitor.
use the on-screen labels to guide you. Press the button labeled <-> to adjust width, press the ^ v labeled button to adjust height, etc.
Press the [menu] button to exit.
Sep 26, 2009 | Acer Computers & Internet
My sony has an issue
if there no menu button means just after loading os go to properties by right clicking in desktop there u go to settings tab go to advanced option.. there u will be having the tab some thing like intel extreme graphics go to that go to display properties there u will having the option to adjust ur height and width of the screen area... check this out...
Jan 23, 2008 | Sony SDM-HS73P 17" LCD Monitor
Problem with Studioworks 563 monitor
LG Studioworks 563N Monitor horizontal width is exceeding out of screen and not able to adjust it along with pincushion through menu. IRF S630A Transistor replaced, no effect. Pl. help.
Nov 18, 2007 | LG Studioworks 563N 15" CRT Monitor
Width problem
To have unlock your control (auto-adjust ...) you have to hold down the "menu Key" for about an 10 seconds. This will unlock your monitor! peroludiarom@abv.bg
May 30, 2006 | Samsung SyncMaster 753S 17" CRT Monitor
Open Questions:
Computers & Internet Logo
1,011 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
