Question about Sony VAIO V2M (VGCV2M) PC Desktop
After formatting my system i could not use (tvtv) Tv tuner application on it.
I have window 7 64 bit SAA7130 tv tuner card does not work properly
Most of the programs and applications that are being intergrated into computer chips and hardware are not compatible with 64bit operating system. Re- install a 32bit Operating System of Windows 7. This could solve your problem
Dec 18, 2011 | Televison & Video
What are the classification of simple machune
Specifications Display Image Aspect Ratio: 16:9 Widescreen Modes: Conventional 4:3 Comb Filter: 3D digital Additional Features: V-Chip, parental control Diagonal Size: 42" - widescreen Display Format: 1080p (FullHD) Resolution: 1920 x 1080 V-Chip Control: Yes Image Contrast Ratio: 2500:1 Brightness: 500 cd/m2 TV Tuner Stereo Reception System: MTS Secondary Audio Program (SAP): Yes Analog TV Tuner: NTSC Video Features HDTV Ready: Yes Analog Video Input Signals: NTSC Input Video Formats: 1080p Remote Control Type: Remote control Audio System Sound Output Mode: Stereo Sound Effects: Virtual Dolby Digital Speakers Included: 2 speakers Additional Features: Mute button Speaker(s): 2 x right/left channel speaker - built-in Connections Connector Type: 1 x composite video input ( RCA phono ) ¦ 1 x S-Video input ( 4 pin mini-DIN ) ¦ 3 x audio line-in ( RCA phono x 2 ) ¦ 2 x component video input ( RCA phono x 3 ) ¦ 3 x HDMI input ( 19 pin HDMI Type A ) ¦ 1 x digital audio output (coaxial) ( RCA phono ) ¦ 1 x audio line-out ( RCA phono x 2 ) Power Power Device: Power supply - internal Power Consumption Operational: 240 Watt General Product Type: 42" LCD TV TV Tuner: 1x analog, 1x digital Width: 41.3 in Depth: 10.2 in Height: 29.7 in Weight: 55.1 lbs HDCP Compatible: Yes Digital Television Certification: HDTV Digital TV Tuner Digital TV Tuner: ATSC, QAM Additional Specifications HDMI: Y More Information Model No.: DP42848 Shipping Weight (in pounds): 67.0 Product in Inches (L x W x H): 41.3 x 10.2 x 29.7 Assembled in Country of Origin: USA and/or Imported Origin of Components: USA and/or Imported Walmart No.: 000503420
hope this will be helpfull to you.
GoodLuck
Feb 02, 2011 | Sanyo 42 in. LCD TV
Need the device code for comcast customs dvr remote control
Comcast Universal Remote - Red OK/Select Button
There are no codes for
Protron DVD player you need to use the search mode on the remote here is how.
S
earchching For Youour Code
If your home entertainment device does not respond to the remote control after trying all of the codes listed for your brand, or if your brand is not listed at all, try searching for your code.
For example, after trying all of the codes for your TV, you still cannot get the remote control to operate your TV, then:
1. Turn on your TV.
2. On the remote control, press TVTV once. Then press and hold Setup until the TVTV key blinks twice, then release Setup.
3. Enter 9 - 9 - 1. The TVTV key will blink twice.
4. Press and release the digit 1. The TVTV key will blink twice.
Note: Substitute 1 with 0 if searching for a Cable code, 2 if searching for a DVD, VCR or PVR and 3 if searching for an Audio device
5. Press Power and aim the remote control at the TV and press CH + one or more times until the TV turns off.
NOTE: In the search mode, the remote control will send IR codes from its library to the selected device, starting with the most popular code first.
6. Press Setup once to lock in the code.The TVTV key will blink twice.
7. To search for the codes of another device, repeat steps 1 to 5, but substitute the AUX key for the device you are searching for.
Jan 23, 2011 | Protron PD-800 DVD Player
How can i watch the tv from philips tv tuner card tuner
First step is that you have to install the Philips TV Tuner Driver that suits for your PC Operating System.
Second step, Install the TV Tuner application that came along with CD driver when you bought the TV Tuner, connect TV antenna into TV Tuner, Run the Application, search for TV channel, autosearch will automatically save the channel. All features including recording the TV programs and save them into the harddrive is on the TV Tuner Application features and good luck
Dec 10, 2010 | Philips TV Tuner Video Capture PCI Card -...
Where can i get it's Windows XP driver / Application ? Typhoon TV Tuner with remote chip label reads : SAA7130HL / RB2225.1 1 / kSG05211
Where can i get it's Windows XP driver / Application ? Typhoon TV Tuner with remote chip?
e-mai : jay_jay@abv.bg
Sep 25, 2010 | Typhoon Anubis Typhoon TVIEW TV Tuner...
I have saa7130 tv tunner card and i also install successfully above card but i have not a programme to run tv progarrme through cable but programme compatible to run the tv programme
please check back drivers tv tuner which has been fixed, if it was running perfectly or there is a miss, usually if the driver installed again the tv tuner can be used again. or for more open jelasanya tv tuner application and click on help, there you are given instructions in its use ordinances. thanks.
Feb 27, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
I have no philips 7130 tuner driver and application
This may help - http://global.kworld-global.com/main/prod_in.aspx?mnuid=1248&modid=6&pcid=56&ifid=16&prodid=68
Feb 01, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
GIGA POCKET TV TUNER NOT WORKING
PROBLEM SOLVED. APPARENTLY THE GIGA POCKET PROGRAM IS AFFECTED BY THE SONIC STAGE MUSIC PROGRAM OF SONY. I RE-FORMATTED AND DID NOT INSTALL THE VAIO MEDIA AND SONIC STAGE SOFTWARE ...
THE TV TUNER NOW WORKS FINE ....
I JUST USE WINDOWS MEDIA PLAYER AND WINAMP FOR THE MUSIC ....
NO REMOTE CONTROLS ... BUT THE TV TUNER WORKED .... ONCE MORE ....
May 19, 2009 | Sony Computers & Internet
Philips SAA7130 internal TV tuner card sound problem
hi,
try on a different slot on the pc or if you have another pc try using the tv tuner on another pc
if it still doesn't work your tv tuner card is bad.
further queries are welcome
Feb 18, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
No Sound is there while using SAA7130 TV Card
I am using p4 dual core intel processor 3.06 Ghz. Recently i installed tv tuner card on my suystem with cabil connected to this card. but due to unknown reasons sound stopped coming. though the picture is still there i am using Windows vista . My system config is 2 GB DDR2 ram and tv tuner card with 80 gb HDD + FDD
Due to this problem I formatted my hard disk and re-installed everything but the problem remained i re-checked everything with no results.
can you help me to sort out this.
thanks
Dec 29, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Sony VAIO V2M (VGCV2M) PC Desktop Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
