Question about Philips SA3025/37 Flash MP3 Player
When I switch on my go gear will display go gear and immediately it's turn off. I want to update my go gear.
    Sergeant:
    Champion:
  • 218 Answers
Visit www.philips global.com.ask for your model firmware file
Posted on Oct 13, 2010
Touch screen stops working
common problem. might need tho be calibrated. turn off front power switch and then the rear main power switch. turn on the front switch, hold down energy save button and copy button, turn on rear switch and continue to hold energy and copy buttons until the screen displays an X in the top left of the display. immediately release the buttons and touch the X with a pen/pencil/pointed object. the X will move to the center and them to the bottom right of display. touch the X as it moves position. the copier will reboot and the display may work. if not, replace the touch screen. part #n2baayy00771.
Sep 13, 2014 | Panasonic WORKiO DP-C322 Printer
I have error code e106 on my 733 hp camera,whatis that?
CausesThese errors display because the lens will not move. There are several reasons why the camera lens might not move:
  • something is blocking the lens
  • the firmware version is old
  • the camera has been abused
  • foreign material is inside the lensor
  • the lens is loose or completely off the track
SolutionFollow all of the steps listed below.
  1. Perform a power reset on the camera.
    1. Turn off the camera and remove any optional memory card.
    2. Hold the ON/OFF switch in the ON position until the HP logo displays and then disappears.
    3. The camera is now reset. When the camera is turned back on it should prompt for the date and time.
  2. If the camera does not display an error after the reset and appears to be functioning properly, it is imperative to check and update the firmware. The firmware update corrects the lens positioning issue that can cause E104, E105, and E106 errors with the camera.Determine if an update is needed by following the steps below to check the current version of the firmware on the camera:
    1. Before turning the camera on, press and hold the Flash button.
    2. While the Flash button is depressed, turn on the camera. A Service Screen displays.
    3. Located at the bottom of the screen is an entry, F/W.
    4. If the version of the firmware is lower than 1.12, then the firmware update is required and should be performed immediately.
Nov 21, 2011 | HP Cameras
All the gear indicators PRN321 on th dash of my 87 Tornado are flashing, what gives?
The gear selector switch is either out of adjustment or it is bad. Loosen the two bolts holding the gear selector in place and turn it slightly to see if the display stops flashing. You will have to manually shift the transmission lever at the switch into neutral, and then turn the switch until the display says neutral. Tighten the bolts and then check all gears. It's also possible the shift cable could also be out of adjustment. Does the display change if you simply wiggle the gear selector lever?
Dec 02, 2009 | 1987 Oldsmobile Toronado
When the laptop is turned off, after a couple of hours the displays does not want to work. I can access the display after pressing F2 immediately upon powering back up.
Either you need to do a system restore, or update video card drivers or turn of hibernation mode. Hib mode really messes with laptops for some reason.
Oct 29, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Gearshift selector problem
Oct 22, 2009 | 1988 Oldsmobile Toronado
HP Pavillion dv9500t lcd screen is extremly dark. I can barely see anything once it is booted up. I can hook up an external monitor and the laptop functions properly with exception of the laptop screen....
From the Windows desktop, hold the fn key and press the f7 key c00776226.jpg to increase or the f8 key c00776225.jpg to decrease the brightness of the display. If using the function keys does not resolve the problem and you have a Lid Actuator on your particular model, check the movement of the Lid Actuator switch to determine that it moves freely and is not stuck. NOTE: The key numbers ( f7 or f8 ) may vary depending on the notebook PC; however, the images on the keys should be familiar. Check the movement of the Lid Actuator switch The Lid Actuator switch is available on some models. It is a small button or switch located above the keyboard near the hinge for the LCD. Pressing this switch when the computer is on may turn the notebook display off, or it may cause the notebook to enter a different power state. Press the switch two to three times while observing the display. If the display does not return to normal brightness when the switch is released, the switch may be sticking and need to be repaired. Contact HP service and support for further assistance. If the display turns off when the switch is pressed, the power management function may be set to hibernate or turn off when the lid is closed. Install updated BIOS and drivers To resolve certain hardware and software issues, use HP Health Check to automatically search the HP web site for an updated BIOS as well as any updated software and drivers. To launch HP Health Check, follow the steps below.
  1. Click Start , type health into the search field, and then select HP Health Check from the list. HP Health Check displays a list of available BIOS, software, and driver updates for your particular model.
  2. Click the description link for any BIOS, software, or driver updates, and then follow the on-screen instructions. You can only install one update at a time.
  3. Repeat steps 1 and 2 above for all updates that you want to install.
You have now installed the available BIOS, software, and driver updates for your particular computer model.
Nov 15, 2008 | HP Computers & Internet
Player not working
  • If your MuVo player turns off automatically after a few seconds of operation, or if it turns off immediately when you press any button on the player, it is possible that the battery is depleted or the firmware is corrupted.
  • To resolve this difficulty and prevent it from happening again, update the player's firmware
  • Aug 30, 2008 | Creative Labs Nomad MuVo TX MP3 Player
    Hp 735 camera error e106 then it turns off
    When the camera is turned on, the lens is stuck either in or out and the camera gives the error E104 , E105 , or E106 . The camera then turns itself off. Causes These errors display because the lens will not move. There are several reasons why the camera lens might not move:
    • foreign material is inside the lens or
    Solution Follow all of the steps listed below.
    2. If the camera does not display an error after the reset and appears to be functioning properly, it is imperative to check and update the firmware. The firmware update corrects the lens positioning issue that can cause E104, E105, and E106 errors with the camera. Determine if an update is needed by following the steps below to check the current version of the firmware on the camera:
      4. If the version of the firmware is lower than 1.12, then the firmware update is required and should be performed immediately. See the HP document Recommended Firmware Updates for Photosmart 733 and 735 Digital Cameras .
    Jun 23, 2008 | Cameras
    Philips SA3025/37 Flash MP3 Player Logo
    66 people viewed this question
    Top Philips Audio Players & Recorders Experts
    Gyula Lacz
    Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
