Question about Quinny ZAPP Stroller
Link between handles needs replacing. Are parts
Link between handles needs replacing. Are parts available for purchase
  • 21 Answers
This is called the "hand grip connection bar". Your dealer should be able to get this part for you. Please ask for part number SPQ465230.
It is also available on our website. Please follow this link:
http://www.babycare.nl/quinny-zapp-hand-grip-connection-bar-p-2094.html
Please note that the connection bar is attached by rivets. Before trying this yourself, please make sure you have the proper tools. If not, mounting the part is best done through your dealer.
I hope this helps.
Erwin de Raad
www.babycare.nl
Posted on Oct 13, 2010
How to disassemble the door of gmh5205xvs-0
On the inside of the door there is a plastic frame that goes around the edge with 2 slots in it that the door latches go through. You have to very carefully pry the frame outward to remove it. First check with a parts supplier to see if your handle is available because some microwave doors are not repairable----you need to purchase a complete door. If the handle is available then attempt to remove the frame as I described before. Once the frame is off you should be able to see the handle screws. If they are still hidden the outer door frame and inner metal door will need to be separated also. They too just pry apart with plastic tabs holding everything together. Replace handle and reassemble. Not hard just time consuming and must be done carefully so as not to break the plastic parts.
Feb 26, 2015 | Whirlpool Microwave Ovens
Can I modify the handle bars on a Frog? I need to lower them for Mum under 5ft tall? Take then off and replace with adjustable handlebar? Which part would I need to purchase? Is it in stock? price?
The Cameleon has the adjustable handle it is not available as a part only as a complete chassis for around $400 www.babycare.nl/bugaboo-cameleon-chassis-p-2466.html. Your Frog wheels, seat etc would fit. If you found a broken Cam frame on eBay you could swap the handles. Your Frog would have the parts required to fix the Cam. Click on this link to my tips section www.fixya.com/support/r7805199-fix_bugaboo_handle_lock. Note as you don't need the old Frog handle you could try prizing off and reusing the domes but I don't recommend that. Brake cable is compatible.
Aug 05, 2011 | Bugaboo Frog - Black Stroller
I NEED DIRECTIONS TO REPLACE THE DOOR HANDLE ON MY MICROWAVE OVEN, PLEASE
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle (if required) usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. Several of these sites also have helpful exploded view parts illustrations to assist you with parts identification and how disasemble/reassemble your appliance. If you haven't purchased a new handle yet, the part number is 8184264.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
NOTE: If you wish to remove the door, all you need to do on most models is open the door all the way and lift straight up at the hinges. You may have to remove the grille cover located above the door on some models to accommodate being able to lift the door.
If you have any questions, please post back and let me know. I hope this helps you.
May 11, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Door handle broken. I want to find a replacement handle without replacing entire door.
NOTE: I would need a MODEL NUMBER in order to determine if your appliance repair parts list the door as an entire assembly, or if you can purchase the handle separately. You can also view the websites I have listed in the link provided.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
May 05, 2011 | Microwave Ovens
I need a new door for this microwave. I have been looking online for hours and can't find just the door. Can anybody give me a website that sells just the door for this micro? Thanks....
The door is available at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
If the model number you listed this question under is correct, the part number for the ENTIRE door is WB56X10585.
Is there a reason for replacing the entire door? You can purchase individual replacement parts if only a single part on the door is broken. The first three sites on the list have helpful exploded view diagrams to assist you in locating and properly identifying the parts you may need.
The most common thing that fails on these doors is the door handle. If only the handle is broken, the door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
The part numbers for the handle on this model are (2 pieces):
WB15X10119
WB15X10120
If you have any questions, please post back with your and let me know. I hope this helps you
May 31, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Broken handle on whirlpool model MH7140XF. how do I remove the face of the door with out breaking it?
The door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. If the model number you have this question listed under is correct, the part number for a replacement handle is available at appliancepartspros.com. There are several part numbers listed, based on the color of your oven, so make sure you order the correct handle. Here is the parts listing:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=260444&diagram_id=93877#d93877
Apr 13, 2010 | Whirlpool MH7140XF Microwave Oven
Inneed to replace the door handle. I have the
The door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and/or replace the door handle:
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. However, price and configuration of your oven also depends upon the MODEL NUMBER.
If you have any questions, please post back and let me know. If the model number you listed this quesiton under is correct, you can refer to pcappliancerepair.com for some excellent exploded view diagrams of your microwave that confirms how the door is assembled. The part numbers for a new handle (if you haven't purchased one yet) are: 8169737 - (White) 8169738 - (Black) 8169739 - (Biscuit) 8184264 - (Stainless) Make sure you use the correct part number when ordering to ensure you get the correct color to match your appliance. I hope this helps you.
Feb 17, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Has anyone had the plastic door handle break on the WSSH300GWW? Where do you find out how expensive part is and how difficult to repair? I think I'm buying this washer tomorrow with a broken handle. Tks.
Hello SClegg, Typically depending on if you only need the door handle and not the entire outer door trim (the part that goes all the way around the entire door) the cost can range from $45-80 depending on where you purchase it. Online sellers will be less expensive, but you can also find replacement parts from SearsPartsDirect.com
I would at least call the Sears parts department and see what their price is for the handle and to make sure you can actually purchase a replacement handle, before I bought a washer that might not have any parts available for it. I tried to look up the handle part number, but the parts websites were down for system maintenance, so I wasn't able to get the part number and pricing.
Call Sears at 1-800-252-1698 and give them your model number and tell them you want the price and availability for the door handle. They should be able to get it for pretty easily.
Hope you find this Very Helpful and best regards!
Merry Christmas!
Dec 13, 2009 | GE Washing Machines
Handles for Presto Pride Kitchen Cooking Pots
Go to www.regalware.com .Click on customer services, then click order replacement parts.then click on presto pride
Feb 11, 2008 | Presto 06821 Electric Skillet
Quinny ZAPP Stroller Logo
296 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Michael Vincent Cruz
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
