Question about Seth Thomas Radio-Controlled Howard Wall Clock - SET717
Clock has stopped working even after battery has been replaced what could be wrong
Put new batteries in Howard Miller battery operated wall clock now hands have stopped working. What's my problem?
Batteries were put in the wrong way?
Contacts are not clean?
Batteries were not fresh?
Clock is broken?
Mar 23, 2017 | Home
My battery was replaced, I HAVE THE RADIO CODE , BUT IT DOESN'T TURN ON THE RADIO, MY CLOCK STOPPED, MY CD PLAYER WON'T WORK...WHAT WENT WRONG?
You need to see the dealer for information on the radio code. Also sue O'Reilly auto for improper installation of the new battery.
Mar 20, 2014 | 2002 Mitsubishi Eclipse
We have some problem with Clock system.
change the battery for cmos on board if that dose not work then you need a new board.
Nov 25, 2013 | SuperMicro X5DPL-IGM Motherboard
My laptop is saying Time -of-day clock stop what is wrong with my laptop?
your clock-battery is not working, its a little coin-battery inside, have a tech to replace it.
Apr 18, 2012 | Dell Computers & Internet
My Barolo atomic wall clock (with hands) stopped working (I think the battery died). I replaced the battery, and now the hands just keep going around without stopping. I have removed & replaced the...
Try to move the clock to a different place. Atomic clocks work by receiving a radio signal. If it has no reception, it may do that. However, I would suspect that no reception would lead to it not setting at all(at least based on the ones I've seen) and it may be something wrong with it (i.e. having difficulty detecting where it's hands are) Good luck.
Jan 03, 2010 | Kitchen Appliances - Others
The digital clock stopped working even after installing a new one
This is a very common problem with many mid 1990 - 2000 model vehicles. I offer a repair solution that is far cheaper than buying a new clock. Check out www.autoclockrepair.com. I also have the removal instructions there, check it out!
Dec 13, 2009 | 2001 Nissan Pathfinder
Reset radio but can't reset clock
just press the clock button for a few seconds then press it again for few seconds and it should stop blinking once it stops blinking press the clock button down again and hold then once it starts blinking release the clock button and adjust the hours and minutes
Jun 13, 2009 | 2007 Honda Accord Sedan
Replaced battery - need to reset clock / radio won't play
My manual said the same thing. Although I have never had the radio stop working on me even after I changed the battery. To set the clock you hold the mode button, like your changing the bass/ treble. Hold it down then it will show clock flashing. From there I cant remember i think i used the arrows by the number pad to change the time. Hope this works for you.
Oct 30, 2008 | 2003 Jaguar X-Type
Cmos settings
CMOS is a memory chip on your computer that stores BIOS information as well as system clock. It powered by a 3V backup battery. If your computer is more then 3 years old it is possible that the backup battery on your PC needs to be replaced. Replace your battery then go to BIOS setup and adjust your date and time. But it is also possible that the clock is a bit off, so first your can just try to adjust your clock without replacement of the battery. You can also do it inside the windows from control panel. Be sure you have a correct time zone.
Good Luck!
Jun 08, 2008 | Intel Motherboard
Seth Thomas Radio-Controlled Howard Wall Clock - SET717 Logo
201 people viewed this question
Top Seth Thomas Audio Players & Recorders Experts
Dennis Key
Dennis Key
Vito Vacirca Jr.
Are you a Seth Thomas Audio Player and Recorder Expert? Answer questions, earn points and help others
