Question about HP EliteBook 2530p Notebook
The wireless icon is orange and I can not find a way to turn the wireless back on. I don't see a switch to flip.
Function key for wireless neo m548ss
Maybe you don't have your wireless turned on. Look onboth sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can togglethe wireless on or off. Normally you would Press and Hold the FN functionkey located at the lower left of the keyboard, then hit the correct F1 thru F12key that toggles the wireless. The correct F1 thru F12 key to hit willhave the wireless signal icon )))) on it. Or it might have the icon of a towerwith the wireless signal icon )))). Normally the screen will displayWireless On or Wireless Off when you toggle the wireless.
Jun 09, 2012 | Computers & Internet
I dont know where the switch for wireless
Jun 06, 2012 | Computers & Internet
Where is the wireless radio switch
Jun 05, 2012 | HP Computers & Internet
How can I switch my wireless LAN on?
Jun 05, 2012 | Sony Computers & Internet
Lost wireless connection in ubuntu laptop
Try recycling the router by unplugging it and plugging it back up.
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
Jun 02, 2012 | Computers & Internet
It has internet security,
Why don't the internet work? What happens when you try to open it? What type of message are you receiving? Did it work in the past for you?
May 16, 2012 | Computers & Internet
The wireless icon on the router is flashing in orange and the signal is not going through to my laptop
Orange signal signifies some bug in the router You can reset the router using a paper clip and then check if it turns Green/Blue.
Also you can try to upgrade the firmware on your router Even then if wifi light is orange, its a hardware failure
Jul 06, 2011 | Belkin Wireless-N Wireless Router with...
I am having trouble connecting to the internet because my WLAN has been turned off, how do I turn my wireless back on?
From the HP website:
The power to the wireless network and bluetooth devices is controlled by a switch or button on most computers. It is possible to accidentally bump the button and turn off the wireless service. c02230159.jpg On most computers, there is an LED light that glows blue when the wireless device is turned on and enabled, and glows orange when off or disabled. Some newer models use different a different color scheme. To turn on and enable the wireless device, do the following:
  1. To turn on the wireless device, simply move the switch to the on position. On some computers, the switch is actually a touch point on the panel above the keyboard.
  2. To enable the wireless device, right-click the HP Wireless Assistant (disabled) icon c02228164.gif and select Open Wireless Assistant . Click Turn On . The HP Wireless Assistant (enabled) icon c02228163.gif will display.
Apr 18, 2011 | HP Pavilion dv4000 Notebook
My wireless internet switch will not turn on.
Apr 17, 2011 | HP Computers & Internet
Wireless switch
Here is all I know about Compaq Presario wireless switches. Sorry, but w/o a model I can't be more specific.
Compaq Presario, Model not specified - Button on the Back
C304NR - Button on upper right above keyboard deck, Blue is enabled
CQ Series - Button above the keyboard (antenna icon on button) next to power.
** CQ50-107NR (Conflicting reports on this model show:
Button above keyboard (antenna icon on button) next to power or lighted button below space bar that turns the touch pad on/off.
M2000 - Button above the keyboard (antenna icon on button)
Dec 11, 2008 | Computers & Internet
HP EliteBook 2530p Notebook Logo
139 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
