Need a network key code for the live box. - Computers & Internet
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 265 Answers
Hey ehouse1,
What XBox Live is most likely requesting from you is your Wi-Fi Protected Access (WPA) key to access your wireless network. Without the WPA key, your XBox will be denied internet access by your router or residential gateway.
You may generally obtain your WPA key by accessing your router/gateway from a connected computer on your home network, and by visiting the default router address through your internet browser. Please note that this default address differs from model to model, but is typically one of the two following:
http://192.168.0.1
or
http://192.168.1.1
Additionally, you will most likely need to have your router's user name and password handy in order to access the hardware's menu settings. Once you have access, you should be able to find your WPA key under "Security Settings" or another similarly-named option.
If you are not comfortable doing any of this or are still unsure how to proceed, I would strongly suggest contacting your internet service provider (ISP) for further assistance. Most ISP's are able to provide over-the-phone technical support and walk-throughs for their customers free of charge. In some cases, they may even be able to provide in-home networking services to help set up your Xbox.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 05, 2008
I can not connect to xbox live
Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
X-BOX
On the x-box you will need to connect to the wireless network now.
Open the main Interface of the X-Box.
1. In the Xbox Dashboard, go to My Xbox and open System Settings.
2. Select Network Settings, Configure Network.
3. On the Basic Settings tab, select your wireless settings.
4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
5. If your network has wireless security, enter your WEP or WPA key.
6. Try to connect to Xbox LIVE again.
Trouble connecting to the internet on X-box ,Play station or WII ?
You can try to reduce the MTU settings on the router. if the MTU on the router is set to 1500 then change the MTU to 1365. Also you will need to open the ports on the router.
For X-box port numbers are - 53, 80-88, 3074 .
Jan 23, 2011 | Video Game Consoles & Games
I have a belkin router and 2 xbox 360 connected to xbox live. whats the settings to have on the router which allows both of us to play multiplayer on games? at the moment one computer kicks us off live...
X-BOX
Jan 23, 2011 | Computers & Internet
Im trying to get my xbox live nat type to open i have the linksys wrt54gx2 router with srx 200 please help my by giving instructions on fixing this problem.
X-BOX
Jan 23, 2011 | Linksys WRT54GX2 Wireless-G Broadband...
The dsl is red and when it turn green i still can connect to xbox live, but when i try to connect my xbox says i need a higher mtu is that possible to change from a laptop
X-BOX
Jan 21, 2011 | 2wire (1000-400108-001) Router
I need to know how to open my nat type for xbox live
X-BOX
Jan 10, 2011 | ASUS (SL1000) Router
I am trying to hook up xbox live for the first time. i have a isp windstream and a speedstream 5200 modem. My connection is good verified by windstream but x box cannont connect to the signal. Winstream...
  1. Step 1 Have your Xbox 360 correctly hooked up to television with HDMI or component cables. Turn your television and Xbox on. Make sure your television is on the correct input. Make sure that your WIndstream DSL Modem is on. If you have a router, make sure that it is on.
  2. Step 2 Obtain the security key for your wireless network, and write this key down. You will need this key to allow the Xbox 360 to have wireless access to the Internet. If you do not know where to find your wireless network key, you will have to access the security setup of your router. The way to do this varies by model, so check your user's manual to see how. If you don't plan on using the Xbox Wireless Adapter for your Xbox, you may skip this step.
  3. Step 3 Run a network cable (Ethernet) from your router or directly from the modem to the Xbox 360. Once you have this cable plugged in you will have to access the "My Xbox" tab on your dashboard. Go to the "System Settings" portion of the tab, usually the last portion on the right, and access network settings. For wired setups, go to the "Configure Network" option and make sure both the "IP Settings" and "DNS Settings" are set to automatic.
    For wireless setups, you will need to have the Xbox Wireless Adapter plugged into the Xbox. Under the Network Settings, enter the security key that you obtained earlier to allow access to the Internet and Xbox Live.
  4. Step 4 Create an account on Xbox Live. You will need to either have a credit card or an Xbox Live subscription card. You can purchase Xbox Live cards at your local game retailer. You will be asked to enter information and create a user name called a "Gamer Tag." This is the name that you will be known as in the x-box community hope this help you out
Jun 08, 2010 | Computers & Internet
Xbox live problem
make sure you are putting in the correct code and also make sure that ur computers arent blocking access to the internet
Dec 30, 2009 | Microsoft Xbox 360 Console
Cant conect xbox live to my live box keeps asking me 4 a wpa key
That is the password for your network. Simply enter your network password.
Dec 26, 2009 | Microsoft Xbox 360 Console
Need instructions for a Brinks security box with keypad and key
Push button in the back, enter 4 to 6 code and push the pound key.
To check combo push star, enter your code, push pound. Safe will beep three times and turn your key.
Jan 30, 2009 | Check Point Network Adapter
Connection problems with secondary computer
hi
the key code is the security code or the password that is enabled in the router,are you trying to connect to you own comcast network or to someone elses??
if you are conecting to your own comcast network then you need to log into the computer which can go online using you comcast box,once you are in that computer you need to go ahead and click on start,run in the box type in cmd and hit enter,it shud open a black box for you in this black box go ahead and check the default gateway an example of default gateway wud be like this no 192.168.1.1,make a note of the default gateway and open an internet explorer page now type the default gateway in the address box without http,it shud open the router page for you from comcast,it will tell you to put in the user name and password,the default for comcast is username is comcast and password is 1234 incase you cannot login you can contact comcast so that they can reset the password for you,once you are in this page you will see the wireless setting click on it and there you will see something wghich says wireless security or wep key or authentication key that is the key code..u can now use this key code to connect to the network....
if you are trying to conect to someone elses network thent he person who has setup the wireles comcast network will be able to give you the network key...
vedhick
Jan 21, 2009 | Dynex Wireless-G USB 2.0 Network Adapter
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
