Question about Canon PowerShot A95 Digital Camera
Serious problems due to memory card
After being exposed to heat conditions, my A95 acts crazily when I try to use its Lexar memory card...I can see my pics are still inside it, but what´s the best softwre to recover all them? What should I do after that...to format it or send it to a trash box immediately?
  • David Bland
    David Bland May 11, 2010
    Dear Valeria:
    I would need a bit more specific information on what you mean by "acting crazy" to offer suggestions on your camera, however, if you need to recover images from a memory card, I can suggest a free program that I use from Zero Assumption Software that has worked pretty well for me and is very easy to use.
    Just download the program at www.z-a-recovery.com, attach your card reader to you computer with your memory card installed, and run the program. It will simply ask you to chose the drive you're restoring data from (point it to your reader), and where you want to restore the images to (point it where you want). Then click next and it begins analyzing and restoring your photos.
    As far as the card is concerned I would recommend formatting it in your camera and holding on to it to see if there is a camera problem or a card probem first.
    If you can comment more specifically on what the camera is doing I might be able to help you there as well.
    Hope this helps.
    Sincerely,
    HeavyDLB
  • Canon Master
  • 4,738 Answers
It's no problem at all to get them back. Please see this post for several free software that you can download. You'll need to use a card reader with these programs though:
http://camerarepair.blogspot.com/2007/12/recovering-those-accidentally-lost.html
And yes, format the card in your camera after you've recovered the pics.
Posted on Jun 03, 2008
How to access lexar memory card without loker,my memory card loker has been breaked
If it's still a usable card, I would suggest just placing it back into your camera and then connecting it via USB cord.
If that doesn't work, check if your computer has a slot for SD cards. If it does, try placing the card in one of the slots gently.
Sep 15, 2012 | Lexar Professional High-Speed 2GB Secure...
Lexar 16g pro 133 sd card in canon ixus 750 says memory error card locked which ever way slide switch is. card is ok in computer Help
I'm a member of the PR team. Sorry to hear you are having these issues. We'd like to help.
Lexar support can be reached via email: support@lexar.com or by phone: 1-877-747-4031(US and Canada) or 1-208-363-5862 (Outside US and Canada).
Sep 07, 2011 | Lexar Professional High-Speed 2GB Secure...
I just inserted a new 8GB memory card but it tells me ''OUT OF MEMORY'' I tried to format it but still gives me the same message. Why is that and what can I do about it please?
The memory card you are trying to use in the camera is not supported. This camera is an older technology that can not recognize the large 8 GB memory capacity of the card. In fact, the largest approved card your camera will recognize is 1 GB.
The list of approved memory cards was obtained from the Nikon Site directly, and pasted below for your convenience.
Nikon has tested the following cards and approved their use in the Coolpix 5700:
CompactFlash memory cards:
SanDisk SDCFB series 16 MB, 32 MB, 48 MB, 64 MB, 96 MB, and 128 MB
Lexar Media 4× USB series 8 MB, 16 MB, 32 MB, 48 MB, 64 MB, and 80 MB
Lexar Media 8× USB series 8 MB, 16 MB, 32 MB, 48 MB, 64 MB, and 80 MB
Lexar Media 10× USB series 128 MB and 160 MB
Lexar Media 40x USB WA series 256 MB*
Microtech International Digital Flash Film 1GB*
Delkin eFilm 650MB Pro*
Ritz Big Print 8x 256MB* (Edge Code 0E1B)
Microdrive cards:
DSCM-10512 512 MB
DSCM-11000 1 GB
Please rate this reply if it helped you out. Good luck!
Aug 10, 2010 | Nikon Coolpix 5700 Digital Camera
My 2GB Lexar flash drive has stopped working. It
A flash card wears out every single time you use it. Yours has just reached its end of life - it's dead. Replace it.
May 06, 2010 | Lexar Professional High-Speed 2GB Secure...
My memory card won't work in my camerakeeps telling me to format the Lexar 2GB card every time I insert it
Use the camera to format the SD card not your computer. There should be a menu option to format it.
May 28, 2009 | Lexar Professional High-Speed 2GB Secure...
Lexar SDHC Card from Kodak Easy Share, disk not recoginized
Honestly, it is most likely a defective memory card or not compatible with your camera. Sorry.
Mar 23, 2009 | Lexar Professional High-Speed 1GB Secure...
Lexar card reader
yes surely sanddisk adapter will work with a lexar card reader.....
Dec 24, 2008 | SanDisk 2GB microSD Memory Card
Memory Card Error
Try checking the card slot in the camera. If it is dusty, then it might need cleaning.
Also, the problem could the the memory cards. If you are using a cheap brand, then they might not properly.
I recommend Lexar, Panasonic or SanDisk SD cards.
Nov 14, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
Memory card error
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Sep 24, 2007 | Canon PowerShot A300 Digital Camera
Canon PowerShot A95 Digital Camera Logo
23 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
