Question about Apple iMac G3 (1999)
Its my imac computer which i changed the start up disk and now it asks for loggin password and i dont have it. It is mac os 9.2 and i have no softwares for that
  • 55 Answers
SOURCE: imac g5 model:a1058
iMac G5's cannot run windows alone, but older software can be purchased like Virtual PC to run windows on that unit.
Posted on Oct 16, 2008
cheap to fix
  • 404 Answers
SOURCE: lost admin password for apple mac os x 10.5.2
u know without the disk there's nothing you can do
Posted on Mar 13, 2009
  • 142 Answers
SOURCE: iMac disk drive is sick
From what you say this is most likely caused by one of 2 possible issues. Either the lens is dirty, or the laser in the drive is going out.For a dirty lens, just try one of those lens cleaning discs. If this doesn't fix it, then you likely need a new drive. If your machine is still under warranty, just bring it to a authorized mac service place and they will fix it for free. Or you can just get an external dvd burner and plug it into one of your usb ports.
If not, its a fairly simple fix. Since you have leopard then you have an intel imac. You can find the drive you need on ebay for between 40-80. Just run a search for "imac superdrive". This will return the the results you need for a dvd burner that works in your mac.
To replace the drive, you will need a torx set. You can get them cheap at sears or most hardware places. These are the screwdrivers with a star looking thing on the end.
To get into your mac, place it screen down on a towel, so you don't scratch the screen. Remove the RAM cover, the one were your memory is. Then remove all of the screws at the bottom of the mac. After that, lift on its leg, the back panel should lift out from the bottom to the top. In the upper left corner you will see your drive. It will look like the ones in the picture on your search on ebay. There's a couple different ways they put them in there but its always fairly obvious how they come out. Take the old one out and put the new one in, replace the cover, replace the screws and you are good to go.
NOTE: If when you go to lift the back cover, all the guts want to come out, then its a bit more involved to get into it. If this is the case let me know and I will email you step by step instructions with pics. And DON"T try to lift out all the guts from the back.
Posted on Sep 12, 2009
Testimonial: "I found this the easiest and most concise solution! Written for the dummy, not the techie. Thanks!"
  • 10406 Answers
SOURCE: Need to reboot or reset an iMac G4 (I think)
See: http://www.fif3.com/howto/archives/001983.html
for special keys during boot-up of an iMac.
Posted on Nov 05, 2009
Macs R We
  • 481 Answers
SOURCE: i install and bootcamp and resize the disk to
I understand your problem to be that at the time you were executing the critical reboot just prior to installing Windows with Boot Camp, you placed the Windows CD into the wrong optical drive. Now your machine is stuck at the gray screen and is not responding to anything and will not boot from the system DVD
I have encountered this problem previously. The solution is to boot from an external drive containing a valid copy of the Mac OS. Although your machine will not boot from a DVD at this point, it WILL boot from an external drive if you hold down the Option key after you hear the startup chime, and select that drive's icon when it appears. Once you have successfully booted, go to System Preferences / Startup Disk to select the Mac partition of your internal drive, and your machine will reboot normally.
This leaves only the question of how you obtain an external drive containing a valid of the Mac OS. Some options are 1) a cloned backup drive, 2) another Macintosh via "Target Disk Mode," or 3) have someone create you such a disk from another machine. On the plus side, this solution involves no loss of your data, which makes it worth pursuing.
Posted on Nov 18, 2009
I forgot the administrator password, there is a malware protection software I believe. Is there any way to recover password?
You need to restart with original media disk and then you can choose reset password from the apple menu bar.
Mar 14, 2015 | Apple 24" iMac Desktop
How to reset administrator password on imac osx 10.6 pc
  • Insert the Mac OS X installation disc into your computer's optical drive (or an optical drive connected to your computer), and then double-click the Install Mac OS X icon.
  • Note:If you're using another computer's optical drive, make sure your computer is set up for remote installation, and then go to step 3.
  • In the Installer, click Utilities, and then click Restart.
  • When the Language Chooser appears, select your language, and then click the Continue button (looks like an arrow).
  • In the Installer, choose Utilities > Reset Password.
  • Follow the onscreen instructions to change the password.
  • Sep 24, 2013 | Apple iMac 24" Desktop
    When I start my computer I can't get past the password becuase I forgot it and I dont have a disk can you help me
    Try this :-
    Creating a new Admin on Mac Os X: Here's how to reset your OS X password without an OS X CD.
    1. Reboot 2. Hold apple key + s key down after you hear the chime. (command + s on newer Macs) 3. When you get text prompt enter in these terminal commands to create a brand new admin account (hitting return after each line):
    mount -uw / rm /var/db/.AppleSetupDone shutdown -h now
    4. After rebooting you should have a brand new admin account. When you login as the new admin you can simply delete the old one and your good to go again!
    Apple stores wont reset it for you. Computer shops may have charged you $50 to $200 trying to reinstall the Mac.
    Nov 16, 2010 | Apple iMac OS 9.1
    I inherited this computer and don't know the password. How do I reset it?
    1. Start up from a Mac OS X Install disc (one whose version is closest to the version of Mac OS X installed). Usually, you can start from the disc by putting it in your computer, restarting, and holding the C key. Or, put it in the computer and click the Install or Restore icon you see in the disc's main window (after which the computer will start from the disc without you needing to hold C). Or, you can use Startup Manager or the Startup Disk preference pane to select the Install disc.
    2. Choose a language, click the arrow button to continue,
    3. Mac OS X v10.6 or later: Choose Password Reset from the Utilities menu.
      Mac OS X v10.5 or v10.4: Choose Reset Password from the Utilities menu.
      Mac OS X v10.3: Choose Reset Password from the Installer menu.
      Tip: If you don't see this menu or menu choice, you're probably not started from the disc yet.
      Note
      : The default keyboard layout is U.S. English while started from the installation disc. If you use a keyboard layout other than U.S English, use the Input menu (the flag icon on the right side of the menu bar) to select the desired layout before typing a new password.
    4. Select your Mac OS X hard disk volume.
    5. Select the user name of your original administrator account.
      Important: Do not select "System Administrator (root)". This is actually the root user. You should not confuse it with a normal administrator account.
    6. Enter a new password.
    7. Click Save.
    8. Click the red button in the upper left corner to quit the application.
    9. Choose Quit Mac OS X Installer... from the Mac OS X Installer menu.
    10. Click Restart
    Aug 30, 2010 | Apple iMac 17" Desktop
    I have mounted a new 40GB on my imac G3 and wanted to install OS ssw 9.0.4 on it, but at start up from the CD, it booth up to where it suposed to show the os type having this icon like a human faced pc at...
    Thank you for contacting Fixya Support, I am glad to assist.
    The "human face" icon is an indication that your hard drive is not being recognized by your iMac G3 because the hard drive is not formatted to read the Mac OS 9 software.
    What you need to do is initialize your hard drive so you can
    it can read the Mac OS 9.0.4 software.
    Below, I have provided a link with simple steps to properly initialize (format) your 40GB hard drive
    Initializing a hard disk, cartridge, or optical disk
    Follow these steps and you will be able to successfully install Mac OS 9.0.4 to your Mac G3 hard drive.
    I hope this helps.
    Regards,
    -Mactechtrainer
    Aug 28, 2010 | Apple iMac G3 Desktop
    When it 1st comes on it says enter current password
    You can do this without the Mac OS X install DVD, but be advised that doing this will trash any saved passwords in your Mac OS keychain.
    1. Power one your Mac and while the computer is starting, hold down "Command-S" until you see text scrolling through the window. This boots the computer into single user mode.
    2. At the Localhost% prompt type:/sbin/mount -uw /
      /sbin/SystemStarterYou will then see various services starting up.
    3. When the Localhost% prompt reappears, type:passwd USERNAME (where USERNAME is the username you login with)It will then ask you to type the new password twice, so do so.
    4. After entering the new password, type:reboot
    May 27, 2010 | Toshiba Computers & Internet
    Problems unlocking the system preferences on my mac
    You will need to change your administrator's password you can do this by putting in the system disk in the disk drive. Boot up using the c key. Once booted go up to the file menu and go to the reset password menu and reset your password. Hope this helps
    Oct 14, 2009 | Apple iMac G5 Desktop
    G5 imac.. with leopard can not get past sign in
    If you've forgotten your password, you can reset it with the discs that came with your computer:
      Note
    7. Click Save.
    10. Click Restart.
    Dec 29, 2008 | Apple Power Mac G5
    Apple iMac G3 (1999) Logo
    Top Apple Computers & Internet Experts
    paulcarew
    Martin Buck
    Martin Buck
    Paul Bade
    Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
