Question about EuroTech EWF150 Front Load Washer
I have a Eurotech E6 Washing Machine and the door latch has broken and i would like to get a replacement.
jsrock516
  • 5911 Answers
SOURCE: Washing Machine door latch replacement
Go to searspartsdirect.com and type in your model number. The door latch assembly can be found under the "Door and Latch Parts" heading as item number 7 (part #8181700). If you need instructions on how to replace, just follow this link:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
If you do not wish to purchase parts online, use the part number provided and go to your nearest appliance parts retailer. I hope this helps you.
Posted on Jun 19, 2008
  • 1462 Answers
SOURCE: Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
Posted on Jul 10, 2008
MNfisherman
  • 11896 Answers
SOURCE: Manual for Eurotech MLD110
(copy and paste this link in your address bar)
http://www.ersatzteilonlineshop24.de/suche_ger2.php?model=MLD110&hersteller=Eurotech
Posted on Feb 01, 2009
  • 566 Answers
SOURCE: door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Posted on Feb 16, 2009
TheMobilian
  • 8220 Answers
SOURCE: HOTPOINT WF541 WASHING MACHINE DOOR CATCH
Check this out
Posted on Mar 19, 2010
Can I order the door to replace my broken one?
do you mean the door latch , google the door latch as its easily replaceable an obtained
May 19, 2014 | Equator EZ 3720 CEE
WFW9200SQ00 Whirlpool washing machine. Door strike doesn't go in the latch, seems a mechanical issue. There is a little white pin inside the latch on the way. Any ideas what can be wrong?
Does the door strike seem to be broken and is that what you see inside of the latch asm.? if no the strike is ok i suspect the latch itself has broken apart and your seeing a internal part of it through the opening where the strike fits into, in which case the latch/lock assambly would need to be replaced.
The part numbers are
DOOR LATCH ASM. 8183270
DOOR STRIKE W10217552
GENE
Oct 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The washing machine works fine the only thing is that the spin doesn't work, it starts but never gets to it's optimal speed. Clothes are soaking wet when the cycle ends. Our washing machine is a...
Hi
The issue is with the door lock assembly that is bad and should be replaced. If the door lock assembly is bad the control will sense that the door is open and so will not start a spin cycle. If you want you can test the door lock assembly with a voltmeter before replacing it. Hope this helps...please post back for further assistance.
Daniel
May 09, 2011 | EuroTech EWF150 Front Load Washer
Samsung WF7700N6W1 wont start because of 'door' error, door is closed
there is a switch in the door latch that tells the unit the door is closed so it can start to operate if there is a fault or a peace of the latch has broken off the unit will read door open check the latch for any broken off peaces if it looks good replace the inter lock unit on the machine
Jun 19, 2010 | Samsung WF328AA Front Load Washer
Door will not latch
It is likely the latch itself is broken or else the machine is in the locked position. If the switch is broken, replace it. You can get one at repairclinic.com or partselect.com
If the lock is on, disconnect from power source (unplug machine) for few hours, press and hold start/cycle button for 3 seconds and wait half hour more and pllug back in.
Dec 12, 2009 | Washing Machines
Door latch broken on indeset wd12x, how do i open to empty and replace part?
got a front loader electrolux washing machine & i broke the door latch.
still got clothes in it, how can i open the door?
Oct 30, 2009 | Washing Machines
Front loader washing machine the door latch is broken, it will not shut to perform cycle. Can you help?
Does it never latch and run, or does it occasionally work? Have you tried pushing on the door? Does the latch make any sort of noise? Have you recently had the boot replaced because of mold? Sorry for all the questions in reply to your question, but if the latch is physically broken then it needs to be replaced. If the question is "how do I replace a broken Bosch latch?", that's a different question.
May 06, 2009 | Bosch Nexxt 300 Series WFMC2201UC
EuroTech EWF150 Front Load Washer Logo
103 people viewed this question
Top EuroTech Washing Machines Experts
shaun taylor
richie46
Are you an EuroTech Washing Machine Expert? Answer questions, earn points and help others
