Question about Raymarine C70 GPS Receiver
I can't turn the anchor alarm off on my c70 - Raymarine C70 GPS Receiver
How can I stop spontaneous anchor alarm
The anchor alarm tolerance may be set too tight. Ray marine has an extensive library on-line. I have usually been able to find what I need there. May take some digging though.
Aug 10, 2014 | Raymarine St40 Bidata System Depth/Speed...
During my first sail for the season, my anchor alarm kept going off even though it was turned off. What is the problem?
Try going to the Raymarine.com website to find the appropriate user manual. There might be a troubleshooting guide in the back.
Apr 14, 2013 | Raymarine St60 Plus Tridata Repeater
How do I find the wall bracket to attached bathroom hardware to?
conniesieber-
To locate wood framing in the wall you will need an electronic "stud-finder", which can detect the relative change in density of materials within the wall and will sound an alarm when those materials are encountered. However, the odds the framing is exactly where you want to hang the towel bar is slim. Another option is to use anchors - there are different types of anchors for drywall, for lath and plaster, and for tile/tileboard. There are anchors that will work for your specific application.
The folks at your local hardware store will make sure you get the right type of anchor. Then follow the instructions that come with the anchors and the towel bar.
If you need further instructions as you proceed, don't hesitate to reply to this message and I will try to answer your questions.
Hope this helps.
Regards,
DIYpro
May 03, 2011 | Gatco & Channel& Satin Nickel Towel Bar
Alarm goes off on my 1999 C70 cabriolet after approx. 20-30 minutes, or can go most of the night until the early hours of the morning
you need to reset the alarm system with the remote(s) as per the book.(you can leave it unlocked as the car has an immobiliser and cannot be hot wired.) i leave mine unlocked all the time and just use the key to start it.how many people respond to the alarm going off??
I live in england,bad car crime area.....
May 07, 2010 | 2001 Volvo C70
Hallo. My C70 ragtop alarm goes off 3 or 4 times
Take it back to the shop...where you got the alarm installed, and if it's factory, take it to the dealer..Your sensbilty sensor is too high..they need to turn it down...
Dec 01, 2009 | 2002 Volvo C70
Got a c70 and my alarm keeps goin off
unplug it it is duff, car will be fine, it will keep going off for about a minute as battery inside.
Aug 09, 2009 | 2001 Volvo C70
1999 volvo c70 alarm program.
Please get an individual to disconnect the former security and you can get a new one installed.
Mar 18, 2009 | 1999 Volvo V70
No volume on my GPS 60
There is no volume control, but page 44 of your manual might help.
Go to the setup menu, then select "tones"
Use the drop down arrows to select a tone for "message beep" and "turn warning". One of those two settings is for the anchor drag alarm.
Make sure the mute box at the bottom is not checked off.
When setting your drag alarm, bear in mind that GPS error is usually @9' to 15' it can be as much as 50' in any direction. Which means any drag distance less than 100' is likely to cause false alarms. Choosing a drag distance that is at least twice as much as the position error reported on the satellite status page will minimize false alarms.
Jul 23, 2008 | Car Audio & Video
Raymarine C70 GPS Receiver Logo
54 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
