Question about Karcher Garden
Water output Pressure is poor - Karcher Garden
    Scholar:
  • 100 Answers
This link should help you solve the problem
http://www.wmpcs.com/blog/?p=72
Posted on Oct 28, 2010
No water output on Task Force 2000 Motor seems
pumps have inlet checkvalves that can be in the closed position that the hose pressure is not good enough for valves to open ther are normally behind hex screw.on pump head
Aug 17, 2013 | Garden
Hard to start running rich & stall
Sounds like a MAP inlet Manifold Absolute Pressure sensor fault. Symptoms of a faulty MAP
  • Poor starting/erratic idling/engine stall - with the MAP not sending the correct inlet air pressure signals to the ECU, incorrect fuel injection volumes then result. The imbalance in the fuel/air ratio often leads to rough engine performance and poor starting and stall. The engine might be kept running at start up by pumping the accelerator pedal
  • Sluggish performance/power ceiling - the engine may seem to perform normally in the lower rev range but will severely run out of power above about 3000 rpm
Poor fuel economy. The ECU tends to supply an over rich fuel mix to the engine in the absence of signal from the MAP resulting in very poor fuel economy. The reason for this is that if the MAP has no signal this ECU assumes 'no vacuum' = fully open throttle = engine is under load. To match this 'open throttle' signal the ECU increases the injection cycle to supply more fuel
How to Check? The MAP has three electrical pins, one for 12 volts (or 5 volts) reference, one for ground and the third (the middle one generally) is the 'signal' output. Put a voltmeter positive connector on the 'signal' pin of the connected socket (back probe by inserting a bit of wire). Apply suction to the vacuum input, even sucking on it with your mouth, should result in a measurable voltage output. At normal air pressure (open throttle) the voltage seen should be 0 volts. As vacuum is applied the voltage output should change to about 5 volts (throttle closed at idle). If no transition seen the MAP is faulty.
Feb 02, 2011 | Chrysler Sebring Cars & Trucks
Po108 service code
OBD II Fault Code
  • OBD II P0108
Fault Code Definition
The Manifold Absolute Pressure Sensor/Barometric Pressure Sensor measures the rise and fall of the air pressure inside the Intake Manifold. This provides critical data needed for the Power Train Control Module (PCM) to control the Air Fuel Ratio, the Ignition Spark Timing, and many components of the Emissions Control Systems. The Manifold Absolute Pressure/Barometric Pressure Sensor converts the Intake Manifold air pressure into a voltage that is high when the Intake Manifold air pressure is high and low when the Intake Manifold air pressure drops to a vacuum. The P0108 code indicates a high voltage input from the Manifold Absolute Pressure Sensor/Barometric Pressure Sensor to the Power Train Control Module.
Symptoms
  • Check Engine Light will illuminate
  • In many cases, no abnormal symptoms may be noticed
  • In some cases, the engine may be hard starting and/or get poor fuel economy
  • In some cases, noticeably poor engine performance may occur
Common Problems That Trigger the P0108 Code
  • Manifold Absolute Pressure Sensor/Barometric Pressure Sensor is defective
  • Intake Manifold vacuum leaks
  • Faulty or corroded Manifold Absolute Pressure Sensor/Barometric Pressure wiring or connections
Common Misdiagnoses
  • Manifold Absolute Pressure Sensor/Barometric Pressure Sensor is replaced when the real cause is an Intake Manifold vacuum leak
  • Manifold Absolute Pressure Sensor/Barometric Pressure Sensor is replaced when the real cause is a stuck-open EGR Valve
  • Manifold Absolute Pressure Sensor/Barometric Pressure Sensor is replaced when the real problem is a defective Idle Air Control Motor, which causes a very low engine idle
Jan 26, 2011 | Mazda MPV Cars & Trucks
Looking for tank psi trying to get better water psi out of the shower and taps
Every faucet and shower have a water saving restricter in them. Remove them from the shower head and end of the faucets.
They are about the size of a dime and with about 1/8" hole in them in which water flows out. So the flow is getting restricted from 1/2' flow to this giving you a water saving about a 1.5 gpm.
Below is some more information for the web site please check it out for further help.
http://www.inspectapedia.com/water/Poor-Water-Pressure-Diagnosis.htm
Poor water pressure just at certain plumbing fixtures? poor cold water pressure, hot water pressure, or both hot and cold water pressure or flow that is observed just at some plumbing fixtures in a building while flow and quantity are good at others suggests that the water flow or pressure problems are local to certain runs of supply piping or to the specific fixtures. Check the following first:
  1. Clogged aerator or strainer on sink faucets - clogging by dirt, debris, corrosion, can significantly reduce both hot and cold water flow at a sink where the strainer needs cleaning or replacement. Unscrew the strainer from the faucet and turn on the water - if the fixture pressure or flow is much better you've probably found the problem.
    Look at the aerator/strainer: inspect it, clean it, perhaps soaking it overnight in vinegar to remove corrosion and mineral build-up, or just install a new aerator/strainer.
Jun 04, 2010 | Plumbing
Poor hot water pressure form Delta single lever faucet
it can be adjust take handle off and remove locking collar first turn water off,
it has a metal or plastic ball with a shaft for the handle it may have spun or a washer may be bad under it,
you can get a replacement at lowes or Home depot to replace it if this is the problem .
Apr 25, 2010 | Delta Model 172: Waterfall Single Handle...
Kohler K-12177 low water pressure output. Removed
check valves under sink make shure tey are all the way on but spray them into a bucket if you can to see if they are ok.
Oct 25, 2009 | Kohler Model 10433: Fort® Single-control...
We began replaceing our galvanized pipes. Since
The problem is that when you disturb the galv. pipes, the gunk inside breaks loose, and travels to the faucets, gets stuck, and limits the volume of water that comes out.
If possible open the lines at the service valves, and force water through the spigot to fluch out the faucet. The service value could also be partially clogged, keep that in mind
Aug 05, 2009 | Plumbing
Poor cleaning. don't think the pump is getting enough pressure to the arms?
Check if water is flowing into the machine with sufficient pressure.
Check water arms orifices and attachments.
If it is not that check for a blockage on impeller lines.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 28, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Water dispenser is extremely S L O W
check no ice build up in bottle but the most likely cause is poor water pressure on the inlet. no cure except to improve water pressure. if there is a valve in the input water line, check it is fully open
Apr 25, 2007 | Hotpoint HSS25GFP Side by Side...
Garden Logo
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
