Question about Polaroid FXM-2611C 26 in. LCD Television
Tv doesn't turn on , no light on front electric ok
  • 998 Answers
Did you the dc output try to check it first
Posted on Oct 13, 2010
I have a kenmore stove model number 790,72403012 and 3 of the 4 burners are working. They all are getting a spark, but the front left won't fire up.
First, try to light the burner in question with a match. Just hold a match to the burner, then turn the gas on to low. If the burner doesn`t light, the problem is the gas supply to the burner. Next, lift the top cover and put the prop rod in the hole in the cover to support it. Hold a match to the left-front burner. Now, turn the control knob to "light". You should see the igniter spark and hear a snap. If this doesn`t happen, repeat this step with the left rear burner. If you hear the spark and snap.
If the igniter doesn`t work on the front left burner, but does on the rear left burner, the igniter does work. The problem is likely the control knob for the left front burner. The. Control knob includes the electrical switch the activates the igniter when you turn on that burner.
Jan 26, 2015 | Kenmore Kitchen Ranges
Air bag light is on
Under the front seats there are a couple of electrical connectors, if there\'s a ton of garbage under there clean it out. Trash and objects under the seats are not good. Disconnect these connectors and inspect them if they look ok spray them down with electric contact cleaner blow them out and reconnect. It\'s the ONLY simple cause of this problem. If it doesn\'t clear out your light (sometimes takes a couple days) take it to a repair shop, I recommend dealer. Good luck, rate this and let me know how you make out
Nov 17, 2013 | 2005 Chrysler Sebring Conv
On my 2004 impala, the front right turn signal doesn't work, (only works with hazard lights). And the back right signal is fast. The signal "clicking" sound is non stop but on the other hand...
If the turn signal filament of the right front park/turn lamp is known to be OK and the hazard switch is in the normal position, the hazard switch or the turn signal/multi-function switch could be defective
Oct 16, 2012 | Cars & Trucks
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
03 chevy venture rt.front parking light&turn light don't work replace bulb&socket
The rapid flashing occurs because of the light problem. If the 20A PARK LP fuse in the underhood fuse block is OK, the front marker lamps and the park lights should turn on when you set the headlamp switch to PARK. If the 10A T/SIG fuse in the instrument panel fuse block is OK, and the ignition switch is on, moving the turn signal multi-function switch to signal a right or left turn should cause the turn signals to flash. If this doesn't happen, check for a missing ground connection to the socket you replaced and check to be sure the replacement lamp was not forced into the socket backwards (it happens).
Sep 17, 2012 | 2003 Chevrolet Venture Passanger
VIZIO VS470 WON'T TURN ON
do you mean the power indicator at the front panel doesn't light.ok this kind of trouble is in power supply section since the stand by doesn't work. the first place to be check is the fuse if blown. if blown with darkened color that was an indication that has other component part that get shorted. at this time you will need a proper trouble shooting using the a device like a digital or analog tester. if you don't have enough idea on how to do the job and necessary tools, just send it to the trusted service shop to fix the problem.thanks for using the fixya.
Aug 13, 2012 | Vizio VO370M LCD TV
Rca HD61LPW42 -- we just replaced the color wheel. now we get a picture but only for a few seconds. then it turns off and after a few seconds restarts. this goes on indefinitely. a couple of times...
Hello
If the power light blinks slowly,
you've tried to turn on the TV during
the lamp cooldown cycle. Wait
approximately 30 seconds, and the TV
will turn on automatically.
If light blinks, pauses for about a
minute, and blinks again: the lamp is
trying to turn on (TV will turn on
when successful). If TV doesn't turn
on and sequence continues, the lamp also
needs to be replaced.
To order lamp call 1-800-338-0376.
Have your TV serial number
and lamp type available (you'll
find this information on the
sticker that's on the right side of
the TV).
OK.
Jul 24, 2011 | Televison & Video
I have numerous proglems. I have a 2000 intrique. The right back signal light blinks very fast, doesn't work in the front. The ac blower works fine but blows warm air.A mechanic , someone my hysband...
Your rear turn signal flashes fast because the front is not working. Most likely you have a burnt out bulb in the front. If your A/C compressor can be turned over by hand and doesn't lock up or make any clanking sounds it's probably alright. The compressor will not run if the system is low on refrigerant. If you're having problems with the A/C and heater controls, that would be the first ting to repair. It doesn't sound at all like any electrical problems.
Jul 20, 2011 | 2000 Oldsmobile Intrigue
The LED indicator is flashing/blinking we replaced the lamp and it will not still turn on. someone suggested the cooling fan? Thank you Shawna2735@Gmail.com
If Fan is running when you turn TV on and keeps running then its OK ,Ballast Board is what turns Lamp on, Is Lamp Lighting at all?
Encompass Parts Distribution has Ballast board for $62.00
Be sure to give the whole model # to TV Ending in WXXaa
WAX/XAA or WX/Xaa HLR6167wxxaa or wax/xaa or wx/xaa
1-800-638-3328 You can also go to their website and type in your model # for List of Parts and Free Service Manual.
Sep 28, 2010 | Samsung HL-R6167W 61" HDTV
My Pioneer Elite PRO-111FD just shut off on it's own, and now won't turn back on. No green or red indicator light... nothing. Any suggestions?
Check your power source (electrical outlet) and the power cable. If electrical outlet is ok, try using a different power cable (the cable that you plug on to the electrical outlet going to your TV set). If everything is ok but still no indicator light, call your technician there might be a problem with the TV power supply.
Sep 08, 2010 | Pioneer Elite PRO-111FD 50 in. Plasma TV
Polaroid FXM-2611C 26 in. LCD Television Logo
76 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
