Question about Gitzo Explorer G2227 Tripod
Loss foot screw - Gitzo Explorer G2227 Tripod
    President:
  • 1,932 Answers
This website provides the exploded view of Gitzo explorer G2227
http://dl.owneriq.net/4/435a3e82-bab8-421f-8328-9da1c8cc59fa.pdf
You can get the replacement part from below website
http://shop.thefotogeeks.com/gitzotripodparts.aspx
Thank You
Posted on Oct 13, 2010
The panel lights up and then all stitches blink and there is a beep. No power and presser foot does not work.
1. Remove the bobbin and bobbin case. Try checking to see if the machine will set up without power loss.
If it stays on you need to adjust the bobbin case so it is just tight enough to keep it from spinning. Put the bobbin case in. There are screws on top of the case to loosen. Move the hand wheel each direction and see it move. The screws will allow a bracket to move to a point which will prevent the bobbin case from spinning.
Replace the bobbin. Check the tension. (See instruction)
2. While rotating the hand wheel check the bobbin to see if the needle thread moves across the top of the bobbin without getting stuck. Also, pay attention if the needle hits the sides.
3. If the thread gets stuck the bobbin case will need to be loosened about one hair strand distance.
4. If power loss is still a loss check good connection to the socket. Sometimes making a small bend will correction.
5. Check the connection to the machine. If it is loose you may need to make a very small bend on the connection. They have to be tight.
6. The same thing has to be done with the foot controller.
See attachment for tension adjustment.
Aug 13, 2015 | Singer 8763 Curvy
What would cause the foot controller on a singer 237 to put out hardly any power?
Rust on the contacts inside can cause this. Usually, a good cleaning, and adjustment of the screw will fix the problem.
Aug 11, 2014 | Singer Sewing Machines
I undid the screw of the foot shaft without a foot on it and the shaft dropped to the plate. I have levered it up and put foot on but the foot wont lift, can you advise me how to fix this please?
there two holes on the side plate where the presser ft bar is located. take off the rubber cover and a screw will be visible. this screw controls the presser ft. height and angle of ft. place ft all the way down and cnter needle in foot slot and them tighten screw. use an long screw driver because u get more leverage. in fact long screwdrivers are the only thing to use on machines. every one should be ground to fit the different screws. anyway raise the foot to see how much clearence u have and adjust accordingly.
Aug 06, 2014 | Juki DDL-5550 Industrial Straight Stitch...
PFAFF sewing machine: How do I attach the gathering foot on the PFAFF 1473?
usually a gathering foot or ruffler fits on like one would fit an old style foot. Unscrew the thumb screw that holds the snap on foot holder.... and place your foot making sure the needle holder thumb screw holds the lever on the other side. And tighten the thumb screw to hold on the foot.
Good luck.
Aug 02, 2012 | PfaFF Sewing Machines
HOW DO I ATTACH PRESSER FOOT G TO MY MACHINE??
there are 2 type of presser bar foot clamps
one allows you to snap on the foot--raise & then lower the presser foot holder until the cut out is directly above the pin on the foot,,as you lower the presser foot holder the presser foot will automatically engage when put down on the pin area
the second is a shank & foot combined & there is a screw on the presser bar,,unscrew it some & put the shank up around the screw & retighten the screw
Nov 24, 2010 | Janome Memory Craft 5700
I have a singer 4552 (portable) and I am having a prblem getting the zipper foot attached. Also I am having a problem getting the design stiching to work. I can get the red design stiches to work but not...
Hi. Here's how to attached the zipper foot.
To Attach the Zipper Foot
1. Loosen the large screw at the left of the presser bar and remove presser foot (You do not need to remove the screw).
2. Hook the prongs of the Zipper Foot around the presser bar from the back, and tighten the presser-bar screw.
3. If the raised edge (zipper or cording) is to the right of the needle, adjust the Zipper Foot by loosening the thumb screw at the back of the foot and sliding foot to the left of the needle. If the raised edge is to the left, slide foot to right.
4. With presser foot down, check its position by lowering needle into side notch, making sure it just clears the foot.
5. Tighten thumb screw to lock foot into position.
When raised edge is placed to right -- adjust foot to left of needle.
When raised edge is placed to left -- adjust foot to right of needle.
Sep 04, 2010 | Singer Sewing Machines
How to attach a quilt guide
You have to unscrew the screw for the presser foot first. The walking foot will then fit. Use the same screw to attach the walking foot. Before you insert the screw, take the white handle on the walking foot and slide it on the screw arm for the needle. Now tighten the screw.
Mar 21, 2010 | Singer Sewing Machines
Fiat Stilo intermittant loss of power
How old is the car? Have you tryed fuel injection cleaner? Is it well you speeding up?
May 13, 2009 | Fiat Pininfarina Cars & Trucks
Gitzo Explorer G2227 Tripod Logo
55 people viewed this question
Top Gitzo Photography Experts
Tony Parsons
Tony Parsons
John Kahts
John Kahts
Level 1 Expert
Are you a Gitzo Photography Expert? Answer questions, earn points and help others
