Question about Olympus VN-2100PC Digital Voice Recorder
My dictaphone was working absolutely fine and over the past couple of days it stopped turning on so i got new batteries and had a fiddle about with it but now it seems completely broken, I wouldn't mind but there is stuff on it that I really need!! I cant find the driver disc to connect it to my new computer either!! I just need the info off it, is there anyway I can do that? Many thanks. Mark Dugdale
  • Mark Dugdale Oct 14, 2010
    Ah thats brilliant, I clicked on the link to download the driver software but it said that it is not compatible with MAC, is that right??? I just assumed you could use it on either pc or Mac
  • 2,069 Answers
Hi depending on what you want exactly, please download its Drivers from here. almost all operating systems are supported and please note that free registration may be required before you download. otherwise, go here there is only two OS so choose the right operating system first.
Regards
Posted on Oct 14, 2010
  • Muzahura Frank Oct 14, 2010
    please go here too for more helpful info
  • 6,993 Answers
there is not way you can get your stuffs on the recorded if it does not turn on.
You can get the drivers for your recorder from the below link. Select your computer's operating system and you can proceed for the download:
http://www.olympusamerica.com/cpg_section/software_results.asp?id=1270
Secondly, you should also think of how the recorder can be fixed. The manufacturers of this recorder has repair centers, so you can contact the manufactures of the voice recorder or their repair centers by visiting the below link:
http://www.olympusamerica.com/cpg_section/cpg_servicerepair.asp
I hope this helps,
Good luck.
Posted on Oct 13, 2010
Battery goes dead after a couple days. was told it could be anti-lock break module...how hard and expensive are these to replace
Your battery going dead every couple days has absolutly nothing to do with your anti-lock break module. (unless it is causing a short or something and staying on-which i doubt.) Have you ever thought that maybe the battery may be dead and old and need replacing. you should test to see how strong the battery is first with a volt meter or load tester. batterys go dead all the time- more so this time of year where it starts to get cold out. If your battery is new or just got it. (usuaslly 2 or 3 years you should be fine). - it may be your alternator isnt charging the battery anymore. Make sure all dome lights are off when the doors are closed. or that nothing else is left on
Dec 02, 2009 | 2003 GMC Sierra 1500
Brand new battery, won't start, will with jump.
It sounds like your alternator is not charging your battery properly. I would have that tested.
Sep 11, 2009 | 2000 Volkswagen Beetle
It wont turn on,
The battery can read 12 or so in volts, but may not have the amps to run it, or the cca to start it, it also has to maintain a certian voltage to run the injectors and coils.
do a check on the battery, any parts store can do this.
sounds like something is shorting the system draning the battery, but it could be the battery itself
Jun 03, 2009 | 2003 Volkswagen Jetta TDI
Intermitent start
Bad/malfunctioning relay. Let me know if you want to work on this.
Jun 01, 2009 | 1995 Mercury Villager
20 year old Dictaphone Voice Processor Microcassette not working
Not sure if you're still having problems with this portable, but the first thing I would check is to make sure that you've put the batteries UNDER the battery clip in the battery compartment. Does the machine just make a 'beeping' noise when it tries to play, rew, or FF?
Apr 04, 2009 | Dictaphone 1243 Handheld Cassette Voice...
Foot pedal FF or Rewinds when pressing Play
It's possible that there's a broken wire in the cable that connects the foot control to the machine. This usually happens near the plug that plugs into the machine, or by the end that goes into the foot control.
You can usually duplicate it if you put the auto-backspace up a bit and then hold down the play pedal on the foot control. While holding down the play pedal, try moving the cable near the machine or near the foot control in a circular motion. If the machine stops, rewinds or fast forwards, then odds are that the problem is with the cable.
Mar 13, 2009 | Dictaphone 3750 Desktop Cassette...
Switch Off
hi,
try to change the battery of your unit?
Feb 19, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Electrical problem
possible bad Body Control Module (BCM)...
Feb 05, 2009 | 2003 Chevrolet Silverado 1500
Doesnt turn on
THE BATTERY OF BTHS IS FAULTY .
Jun 05, 2008 | Motorola Mobility H350 Wireless Headset
Olympus VN-2100PC Digital Voice Recorder Logo
71 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
