Question about Olympus Stylus 790SW Digital Camera
790SW Problems You mentioned you are on your third one. So do you just keep sending them back to Olympus with the receipt and they keep sending you new ones? Is the battery charger supposed to blink when it is charging? I was snorkeling with mine when it seized up and wouldn't work anymore. I was turning it on and off so that I could save battery power. I guess something got stuck in there. Then it would let me view pix, but not take pix. Then it said the battery cover was open, when it wasn't. Then it went completely dead and hasn't turned on since then.
  • surfstar16 Jul 01, 2008
    my camera is doing the same thing... i will let me view pix but not take them =( loved the camera took it to maui and even went cliff diving with it.. worked fine until one day i took it snorkeling and a little water got in. worked for a while after that only the screen fogged up and now i have the problem of not being able to take photos
My camera is doing the same thing... i will let me view pix but not take them =( loved the camera took it to maui and even went cliff diving with it.. worked fine until one day i took it snorkeling and a little water got in. worked for a while after that only the screen fogged up and now i have the problem of not being able to take photos
Posted on Jul 01, 2008
How do I tell if my Olympus 790SW is damaged or if the battery needs replaced?
Unfortuneately when water enters the camera this is usually a one way ticket, I recommend you remove the memory card to save your pictures, the liquid has already started eating into the ic pins eventually sending the camera into cascade failure that can take days, weeks, and months before the full extent is known. I recommend you consider replacing the camera.
Mar 23, 2012 | Olympus Stylus 790SW Digital Camera
I'd like to set my Stylus 790SW back to default settings in hopes that my video feature will work. Right now the video doesn't record. It's just a picture. I've been messing with this camera for 4 hours...
Roll the dial to picture mode, press the menu button and you will see "reset" on the left. Select "Reset" and say "Yes" - this will reset your camera to default settings.
Here's a link to the manual if you need more help: (see page 23) http://www.olympusamerica.com/files/Stylus_790_SW_Instruction_Manual_EN.pdf
Hope this helps! Please rate my solution!
Jan 05, 2010 | Olympus Stylus 790SW Digital Camera
How can i charge 790sw without a charger
you can't. you need a charger since this camera doesn't charge via USB when connected to PC. If you need to buy one, i hope this link helps..
http://www.bizrate.com/digitalcameraaccessories/products__keyword--olympus+stylus+790+sw+battery+charger.html
cheers!
Jul 11, 2009 | Olympus Stylus 790SW Digital Camera
Olympus 790SW Leaks
You might want to call Olympus Customer Service to see if it is a part that you are able to purchase or they might tell you it might need to be sent in for repair. Their telephone number is 800-622-6372 option 2 and then option 3.
Mar 14, 2009 | Olympus Stylus 790SW Digital Camera
License
You would need to contact muvee for that information.
http://www.muvee.com/en/support/
Dec 16, 2008 | Olympus Stylus 790SW Digital Camera
Olympus Stylus 790SW "Blue screen"
appears to be repair issue and need to send to a repair center
Sep 02, 2008 | Olympus Stylus 790SW Digital Camera
Battery was put in backward in camera cant get it out
You should probaly listen to the manual and take it to a dealer or phone Olympus about sending it in because it is probaly possible to disasemble the camera to get it out your self but doing so would void your warranty.
I hope you get your problem fixed!!
Apr 29, 2008 | Olympus Stylus 790SW Digital Camera
Olympus stylus 790 sw:windows vista does not recognise the devise?
ganduff2,have vista home premium, have 790sw, have same problem can you help.
Feb 04, 2008 | Olympus Stylus 790SW Digital Camera
Wont turn on
Remove battery from charger. Unplug charger for a minute, then plug back into outlet. Reinsert battery and see if red LED comes on and STAYS on solid. If so, charge for about 5 hours.
Dec 28, 2007 | Olympus Stylus 790SW Digital Camera
Olympus Stylus 790SW Digital Camera Logo
163 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
