Question about Apple iPod nano
This question is about specific product. - Apple iPod nano
    Genius:
  • 1,478 Answers
What is the problem?
Posted on Oct 13, 2010
Product specification
What make and model is the "above" product?
Jun 26, 2012 | Office Equipment & Supplies
I bought new 2gb ddr2 with 800 mhz and its not working on my motherboard d102ggc2 can u plz help me with the solution
i guess you did not check the compatibility of the RAMs to your MB limitations....
the only solution is to return the RAMs and get the RAMs that is supported by your MB.....
the MB (D102GGC2) can hold only a max of 533 mhz and max of 1GB each in each slot of RAM....
so if you are trying to install one 2GB card of 800 mhz IT WIILL NOT WORK....
get TWO RAM cards of 1GB each (total 2GB) of RAM.... each of 400 mhz....
hope this helps...
Reg
Suresh
to check what your MB supports, look for the details below...
http://www.intel.com/support/motherboards/desktop/d102ggc2/sb/CS-029352.htm
Intel® Desktop Board D102GGC2 Technical product specification circuit388.gif Product Specification
This product specification applies only to standard D102GGC2 boards with BIOS identifier GC11020M.86A. Changes to this specification will be published in the D102GGC2 Desktop Board Specification Update before being incorporated into a revision of this document.
pdf.gif D102GGC2 Technical Product Specification [PDF]
File Name: D102GGC2_TechProdSpec.pdf
Date: April 2006
This document is an update to the specifications contained in the D102GGC2 Technical Product Specification. It is intended for hardware system manufacturers and software developers of applications, operating systems, or tools. It contains specification changes, errata, specification clarifications, and documentation changes.
pdf.gif D102GGC2 Desktop Board Specification Update [PDF]
File Name: D102GGC2_SpecUpdate03.pdf
Date: November 2006
Apr 27, 2011 | Intel D102GGC2 Motherboard
Explain what a person specification is
specification:
A specification is an explicit set of requirements to be satisfied by a material, product, or service.[1] Should a material, product or service fail to meet one or more of the applicable specifications, it may be referred to as being out of specification;[2] the abbreviation OOS may also be used.[3]
A technical specification may be developed privately, for example by a corporation, regulatory body, or military organization, or it may be developed by standards organizations which often have more diverse input and usually develop voluntary standards (Voluntary standards may become mandatory if adopted by a government or business contract).
Sometimes the term specification is used in connection with a data sheet (or spec sheet). A data sheet is usually used for technical communication to describe technical characteristics of an item or product. It can be published by a manufacturer to help people choose products or to help use the products. A data sheet is not a technical specification as described in this article.
sourced from wikipedia
Apr 22, 2011 | Computers & Internet
Need a manual for Compaq Presario SR1130NX manual
1) Compaq Presario SR1130NX > HP Support > Main page,
http://h10025.www1.hp.com/ewfrf/wc/product?product=425917&lc=en&cc=us&dlc=en&submit.y=8&submit.x=5&lang=en&cc=us
In the list go to the right, and click on > Manuals
On the Manuals page;
1) Quick Setup Poster 2 is a diagram of how to connect the computer up.
2) Getting Started Guide is essentially a User Manual
3) Compaq Presario Desktop Products - Upgrading and Servicing Guide;
Describes how to;
A) Open the computer case
B) Replace a Harddrive, or Optical Drive
C) Removing and replacing Ram Memory
D) Adding Add-In Cards in an expansion slot
E) Replacing the CMOS Battery. (CR2032)
4) Part Replacement Guide;
Describes how to;
A) Replace an Optical Drive
C) Replace an Expansion Card (Add-In Card)
D) Replace a Diskette Drive (Floppy Disk Drive)
E) Replace the Power Supply
F) Replace the RAID Controller Card
G) Replace the 6-in-1 Memory Card Reader
Back in the Main menu clicking on Product information > Product specifications > Product Specifications, details out the Compaq Presario SR1130NX specifications.
Clicking on Product information > Product specifications > Motherboard Specifications, A7V8X-LA (Kelut)
details out the motherboard specifications, and at the bottom shows a motherboard illustration and photo.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00069442&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=425917&lang=en
The Processor socket is a Socket A. Also known as a Socket 462,
http://en.wikipedia.org/wiki/Socket_A
Processor's, and maximum processors supported, are shown in the specifications.
The motherboard chipset is a VIA KM400A, and VIA VT8237
(Northbridge chip = VIA KM400A. Southbridge chip = VIA VT8237)
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Slot_A_and_Socket_A
Ram Memory supported is DDR Sdram at either 266MegaHertz, or 333MHz
PC2100 and PC2700 respectively.
2GB Maximum TOTAL Amount
2 ram memory slots.
EACH slot has a Maximum Amount of 1GB.
The graphics expansion slot is an AGP.
(Accelerated Graphics Port)
Uses AGP 8X graphics cards.
Power Supply uses is an ATX form factor.
Approximately 6 inches Wide, 5-1/2 inches Long, and 3-1/2 inches Tall.
Guessing here but it's either a 250 Watt unit, or 300 Watt unit.
Probably made by Bestec, or Delta, or HiPro.
If the above is not what you had in mind, please post back in a Comment.
Regards,
joecoolvette
Dec 01, 2010 | Compaq Computers & Internet
Error 49
If the error can be reproduced, use the following sections of this document:
  • Product-specific documentsProduct specific document are available on the HP support website at the following url http://welcome.hp.com/country/us/en/support.html. Select your product and use the search string Product specific 49 errors to locate your product specific 49 error troubleshooting document(s).
  • Clearing the error
  • Validating the firmware
  • Stack Trace Random error troubleshooting
  • Hardware troubleshooting (if applicable)
Power-cycle doesn't eliminate errorIf the error cannot be eliminated by a power-cycle, use the following sections of this document.
  • Hardware
Feature-specific errorThe error has been narrowed down to a specific feature.
  • Software, Sending, Faxing, and environmental troubleshooting
Nov 03, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
The error "49. FF05 SERVICE ERROR" is displayed on
  • Product-specific documents Product specific document are available on the HP support website at the following url http://welcome.hp.com/country/us/en/support.html . Select your product and use the search string Product specific 49 errors to locate your product specific 49 error troubleshooting document(s).
Power-cycle doesn't eliminate error If the error cannot be eliminated by a power-cycle, use the following sections of this document.
  • Hardware
Feature-specific error The error has been narrowed down to a specific feature.
Oct 26, 2010 | HP LaserJet P3005d Printer
How do i find my product key for my nuvi250
The Garmin product key, also called the product serial number, is included in the box your Nuvi i250 comes in. This number is nine digits; it's printed on the yellow specification sheet. Fortunately, the key is also printed on your Garmin unit, which is helpful in the event you lose your specification sheet. The Garmin product key is required to register your Nuvi i250 with Garmin. (Registration allows you to download software and map updates, and receive recall information.)
Follow the procedures below on your nuvi i250;
  1. Turn your Nuvi i250 around to view its back.
  2. Flip up the GPS antenna with your finger. Look behind the GPS antenna for the specification sticker.
  3. Write down the nine-digit product key. With this number, you'll be able to register your Garmin. (See "Resources.")
Good luck
May 17, 2010 | GPS
Ever since i installed avanquest softawre my computer has slowed down worse than dial up. have i done something wrong or what
I have not used this software, but here is thier Tech Support #'s
Telephone support is available FREE for registered users.
Avanquest Software helps ensure that our products and services are working properly. If you are a registered user of a currently supported U.S. version of Avanquest software, you are eligible to receive free telephone support under these specific guidelines.
  • Installation: Successfully install software products and services for the first time or re-install on a replacement computer (online or disc installation).
  • Specific Errors: Resolve Avanquest product and service-specific error messages.
  • Product Defects: Resolve confirmed product defects for registered, supported products.
We are ready to help you from 7:00 am to 5:00 pm, Mon-Fri, Pacific Time.
Phone: 818.591.6258
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 14, 2008 | Computers & Internet
Need to know abt fax
HP.com has a web page that talks about the different ways you can send a fax from this product:
Faxing Overview
In general, the fax machine in the all-in-one product doesn't need a computer to work. It works just like a stand alone fax machine. You shouldn't have to scan anything in from the scanner in order to fax. Just put the sheet of paper you want to fax into the product's feeder and follow the fax instructions (see the link I posted above).
As long as the product has electric power and is connected to a phone jack, it should work out OK.
As far as legal papers, if you mean legal sized papers, it should work as long as the product supports the paper size you want to use. You can get that on the product specifications web page at HP.
Once that page opens, go to the Faxing specifications and Paper specifications sections for the relevant details. Good luck.
Oct 09, 2008 | HP Officejet 5610 All-In-One InkJet...
25 digit product key
These product keys are specific to particular versions. What is the product that you are attempting to install. XP? Vista? The product key for the "basic" version will not work for the "professional" version etc. Make sure that the particular versions match the key. Post the specifics here (but not the key please).
Dan
May 30, 2008 | Intel Motherboard
Apple iPod nano Logo
13 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
