Question about Sony VAIO® VGCLS1 PC Desktop
How to remove hdd from vgc-la38g? - Sony VAIO® VGCLS1 PC Desktop
Gaining acess to hdd on vgc-lt2s
"gaining access" to a HDD ?
If you mean physically getting-to the hard drive for removal/replacement....HERE is the manual for your PC. Go to page 115 for instructions on HDD access/removal.
Tallon41
Sep 11, 2012 | Computers & Internet
My sony vaio desktop (model vgc-rb60g) powers on then gives a continuous high tone and nothing else. nothing sent to the screen.
I understood your problem.
it's a beep code. That beep code indicates the nature of the problem with your CPU.
these beep codes are different as per manufacturers see the booklet provided with your CPU which shows continuous beep indicating type of problem.
If further cause such a problem then you should remove all connection to HDD and RAM and re-connect it manually.
Thank you for giving me opportunity to solve your problem.
please give me your Ratings!!
Jun 17, 2011 | Sony VAIO VGC-RB60G (027242690547) PC...
I need how disassembling sony vaio vgc ls13s to change hdd
PM me some pictures of your computer.
INSIDE & OUTSIDE
Jun 11, 2011 | Sony VAIO VGC-LS25E PC Desktop
My Sony VAIO VGC-RA920G won't recognize my replacement HDD.
You first should check to see if the SATA cable is plugged in to the HDD all the way. If not, there will not be any data flow. If it is, check to see if the power cable is plugged in. If not, it's not using power or getting data flow.
May 09, 2011 | Sony VAIO VGC-RA920G (R04FA1DTA) PC...
How to remove hard drive
On the bottom of the notebook you will find one flap tightened with screws and HDD or disks sign wiill be there. You will have to open the screws and simply lift the HDD from the end not having the pins. You will be able to see the socket.
Thanks
Oct 07, 2010 | Sony VAIO VGC-LS30E 1.73GHz Pentium Dual...
Can anyone tell me where i can find out how to remove the Back or Front panel to get to the HDD fon a VAIO VGC-LS21N PC Desktop. Thank you in advance.
at the back of the tower you can find the screw you need to remove that and slide that cover then you can find the HDD
May 19, 2010 | Sony VAIO VGC-LS21N PC Desktop
Cannot get driver for windows 7 for Sony Vaio VGC-LA38G
unfortunatly there is not "windows 7 " driver for this model logitech if there where windows 7 will have it when you ran updates so there for you have to use windows vista drivers with your fingers crossed,
thanks hope this helps please do rate it anyhow
Jan 06, 2010 | Logitech Webcam
Fails Post
It's the HDD, or the HDD controller. Give sony a call. Based on the number and sequence of beeps, they can tell you exactly what this issue is.
May 25, 2009 | Sony VAIO RC110G (VGC-RC110G) PC Desktop
Sony vaio laptop vgc-la38g. I need built in webcam software
Sir,
I am sending you the link. There you can download the driver from the 17th number for camera.
LINK
If my advice was helpful, please feel free to rate me.
Thanks
Mar 22, 2009 | Computers & Internet
Sony VAIO® VGCLS1 PC Desktop Logo
247 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
