Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
Sony kdf-55wf655 Where is the access to replace the lamp?
Behind the front bottom panel. It is removed by the two hand screws located behind the panel on the back side of the TV.
Posted on Jun 02, 2008
For a KDF-55WF655 SONY PROJECTOR TV, WHAT REPLACEMENT LAMP DO I NEED
Required lamp for Sony KDF-55WF655tv is as follows:
A1085447A .... LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200
Thanks.
Nov 02, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
I turn on my KDF-55WF655 Sony TV. The green power light flashes about 10 seconds and then the picture fades in to full intensity for about 305 seconds then goes blank. The green power led flashes about...
If lamp has not been replaced in tv in last 2-3 years, then replace the lamp as symptom shows that lamp has reached to end of its working life span and causing that problem.
Lamp is not dead or broke but weak so you get above said problem in tv.
Thanks.
Oct 05, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
I have no pic sony lcd proj tv model # kdf-55wf655, 57in,
Lamp or ballast bad. If ballast good and lamp bad, will here a mosquito buzz every 15 secs. after turn on.
Apr 20, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KDF-55WF655 picture and sound are going on and off. The green light flashes when they are off and when they come back on the picture comes on first then the sound.
These are symptoms of weak lamp as lamp in tv is reaching to end of its working life and will be replaced to fix this issue.
Lamp replacement procedure would be written in user manual and its easy.
Please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Thanks.
Apr 18, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Picture and sound shut off, blinking green standby
MY SONY PROJECTION TV WENT BLANK WITH NO SOUND GREEN LIGHT WAS ON WHATS WRONG
Oct 14, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Grand wega kdf-55wf655, won't power on and led flashes 3 times
Make sure lamp cover is placed properly and securely after lamp replacement.
3 blinks of LED shows lamp door is still open or not closed properly.
Jul 04, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Changing the lamp in a Sony Wega KDF46E2000
Click Sony Support to download instruction manual of KDF-46E2000that has lamp replacement info in detail.
Click Sony Support to download instruction manual of KDF-55WF655
that has detailed procedure of lamp replacement.
lamp replacement is very easy and mentioned in related instruction manual of TV. Please buy original Sony lamp from Sony Accessories Store and avoid aftermarket / cheap lamp.
May 02, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
KDF-55WF655 Sony TV red lite flashes6 times
The thermal fuse has opened. Unfortunately, its likely that the ventilation system of the TV has been blocked by dust or other foreign matter. The cyclone fan mounted above the lamp housing is prone to this type of accumulation. Check for evidence of overheating in the lamp, lamp housing, and especcially the red wires going to the lamp socket. If they appear scorched, its a safe bet it got very, very hot.
To bring this TV back to life a new fuse needs to be installed, all the fans need to be cleaned, the lamp ballast board may need to be replaced as well if the wires appear to be damaged. Also, if your lamp is not new, it should be replaced too. Botton line here is cost. If you call a service company out, expect to spend a minimum of $300 and as much as a $1000 or more.
Keep your eye out for class-action lawsuits being filed on these TVs. I've seen a few of these actually melt the plastic lamp cavity to the point where it may catch fire.
Feb 19, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
54 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
