Question about Pierre Cardin Goldtone Bracelet Watch for Men
How do you remove links from this watch (the Pierre Cardin goldtone bracelet watch model #PC2344YS)
SOURCE: My watch dosen't fit
Have a look at bracelet clasp exetnder from RTL Watches
Posted on Jul 28, 2007
escapement
  • 2334 Answers
SOURCE: I have a bracelet link
If you are ready to take that risk, here is how you can do that.
First- get watch on your wrist and by squeezing the bracelet count how many links you have to take out to make it tight enough (say 4 for example).
Check the sides of a bracelet. You will notice that the upper bands metal is flipped over the bracelets side. Take tweezers or small pliers and unbend one of these. Try to do as little damage as possible.
When it's done, you will see two metal staples inserted into the bracelet. You have to pull them out. While pulling out, remember how they where positioned, as you will need to drive them back in the same manner.
So, when the staples are out, do the same on the other side of bracelet. Now you have bracelet in two halves.
Count off 4 links and undo the staples in joint of 4th and 5th link in the same manner as previously.
When links are out, take the staples and drive them back into the bracelet koining two ends together. You have to do that exactly the same way and position as you took them out.
When all staples are in place, bend the metal back over to the bracelet sides.
BE WARNED: as you gonna do it first time, be ready that you can damage the bracelet or can not put it back together.
Good luck
Posted on Dec 21, 2008
escapement
  • 2334 Answers
SOURCE: How do I shorten watch bracelet?
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 21, 2009
escapement
  • 2334 Answers
SOURCE: Can not figure out how to remove links from Casio watch band
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Apr 01, 2009
dmbgo
  • 58 Answers
SOURCE: How do I remove links from stainless steel
The band has pins in it which can be removed by tapping them
Posted on Jun 22, 2009
What is battery for PC2500TS?
this watch uses sr621 size of battery. i hope i had been helped you.
Aug 20, 2011 | Pierre Cardin Pierrecardin Gents Bracelets...
I have a 2-tone pierre cardin diamond watch and the gold already faded. was it a fake?
Gold does not "fade" but if it is very thin plating, then it may wear off.
This make tends to be expensive; if you did not pay a high price for it, then it seem likely be a fake.
Jul 07, 2011 | Pierre Cardin Gold Tone Bracelet...
Watch bracelet s too small
Contact the manufacturer for replacement links.
May 12, 2011 | Pierre Cardin Watches
Need repair or replace braclet have tried jewellers
The only place you will be able to find a PC wartchband is from the PC website unfortunately.
Here is a link for you!!
http://www.pierrecardinwatches.com.au/watchpage.php?watch_num=3656
Aug 19, 2010 | Pierre Cardin Goldtone Bracelet Watch for...
Help! I own a Pierre Cardin wrist watch I wear it every day and have doneso for many yearsbut, the case has coroded and needs replacement. The number on the reverse is D265. Can you help to...
mcdevito75 Here, Hello Graham, yes the case of your Pierre Cardin watch can be fixed, Best Bet is to look for a small watch repair shop in your area, they can send your watch out for replateing. They may have to send your watch to Pierre cardin for this service.
Aug 06, 2010 | Pierre Cardin Watches
I need a spare part to my Pierre Cardin watch. Is there a retailer in Finland or Sweden that I can contact?
mcdevito75 here, You can try to contact online at Pierre Cardin watch.com Most likely you"ll have to send the watch to Pierre Cardin or you may be able to order the part you need.
Jun 30, 2010 | Pierre Cardin Pierre Cadin Swiss Women's...
Broken strapthe
needs a new brcelet or some repairers will try to buff up the bracelet and case but it can be expensive so is it going to be worth it..you can try yourself you need a very very fine emery paper and a electric drill with low speed and a mop end atachment rub gentley with paper then buff with drill very difficult..or try ebay for new watch bracelet you need serial numbers and model..
Mar 25, 2010 | Pierre Cardin Pierrecardin Gents Bracelets...
I purchased jewelery abort a flight from italy to US in October 2009 the rodium jewelery is now turning black and the goldtone is not gold any longer. could you pleasehelp me and give me some information...
There is no way you can do it yourself. Visit your nearest jewellery repair shop and ask to re-plate your products. Bear in mind - this process can be costly. Rate me, plz.
Jan 28, 2010 | Pierre Cardin Watches
Pierre Cardin Goldtone Bracelet Watch for Men Logo
315 people viewed this question
Top Pierre Cardin Watches Experts
richie46
Ron Durham
Are you a Pierre Cardin Watch Expert? Answer questions, earn points and help others
