Question about Home
Just fitted Fluidmaster 747 side inlet. It makes a squealing noise when shutting off. Any suggestions to stop this?
  • 4 Answers
SOURCE: Squealing noise during spin cycle
The spin cycle activates the fast mode on the motor, squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
Posted on Jul 08, 2007
  • 61 Answers
SOURCE: I have installed a fluidmaster 400 bottom inlet
I have installed 400A or 400LS valves on systems as low as 30psi, but below that I don't know that it would work very well if you needed it to fill faster.
Keep in mind that your pressure to the toilet will be 1/2psi for every foot above the fill level of the tank, which is reduced by friction loss in the pipe and fittings on the way to the toilet.
Posted on Oct 27, 2009
SOURCE: 99 Chevy Z71 heater core inlet hose male fitting broke
This is an easy $7.00 fix. Go to your local auto parts store and get a GM Heater Hose Fitting. I went to NAPA, part #730-5631. Cut of the old fiting with a hack saw blade, being careful not to damage the pipe from the heater core, put the new one on. Total time takes less than 10 minutes, make sure you fill your coolant resevoir.
Posted on Nov 22, 2009
  • 111 Answers
SOURCE: My four year old fluidmaster 747 is shooting water
toilet fillvalve? top comes off by squezing tabe and turning counterclockays when water is off.replace rubber disc
Posted on Dec 23, 2010
joemidjette
  • 158 Answers
SOURCE: I have a fill valve
There should be a small flexible tube/hose that came with this and goes over where the water is spraying out, it should look like a little nipple, the hose goes on there and then to the white tube appoximately an inch or so in diameter that goes to the bottom of the tank where the flapper ball is connected. The small flexible tube is supposed to connect to the top of the larger tube via a clip so-as to fill the toilet bowl back with water. If everything is connected like it's supposed to be then you might have a cracked fluidmaster.
Posted on Mar 11, 2011
Fluidmaster
First shut water off at stop than flush all the water out of the tank next take a sponge and get all the water out of tank next unsrew the supply line from the valve under tank than move out of the way next unsrew the nut on the valve of fluidmaster than pull the fluidmaster out of tank stick the new fluidmaster in tighten nut srew the supply line back on turn on stop and let the tank fill up thats it if the fluidmaster dont shut off press the handle let some water out and adjust the fluidmaster screw Tip the water should stop a 1/4 inch below the flush valve tube in center of toilet
Jul 11, 2016 | Fluidmaster Plumbing
Why is fluidmaster 747 loud when filling the tank?
Water rushing through a small opening creats turbulence and noise. Only way to quiet it down is to restrict(slow down)the water volume by closing the supply valve partially.
Nov 01, 2014 | Plumbing
How to fix running toilet
if toilet is running non-stop, check flap in tank. possible handle not returning completely holding flapper fron seating tightly. if toilet runs, then shuts off for awhile then runs again, flapper needs replaced.
Jul 19, 2012 | FLUIDMASTER INC #B1FV16 16" Faucet...
Fluidmaster model 747 flush valve is spraying water out the top
Hi tdechill...
Make sure the hose that goes to the top/side of the fluidmaster is in the overflow tube of the water tank, if it is then It should not spray water from the top, it is faulty and needs to be replaced.
Please take time to rate me
Aug 18, 2011 | Home
Have fitted new fluidmaster flush valve, has a dual flush button operation but water constantly dripping down bowl so fill valve activates sporadically to maintain water level. how can i stop water...
Flapper not seating properly,either get new flapper or try a old trick i've used shut off water to tank and drain tank then add hot water to tank and let set for a while sometimes that will soften and seat flapper it's worth a try it's free.
Jun 08, 2011 | Fluidmaster & Fits-All Faucet Connector
I have a fill valve that says Fluidmaster 747. when tank goes to fill it sprays water out at the top
Mar 11, 2011 | Fluidmaster Plumbing
After flush tank refills very slowly
Make sure that any valves that you shut to install the fill valve are fully open after the installation.
If that doesn't work, the following is from another fix your stuff site:
Shut off water supply. Lift the rod arm and remove top cap assembly by turning 1/8 turn counterclockwise. Using a straightened coat hanger, carefully clean out the inlet passage of the Valve.
If these don't help, check the model number of your Fluidmaster and include that the next time you write.
Dec 09, 2010 | Fluidmaster INC #B1F09 9" Faucet Connector
I installed brand new fluidmaster and it would not shut off even though the flowter are all the way up. why it would not shut down?
If the fill valve will not turn off. There may be debris at seal. The seal in the top of valve may be damaged.
Shut water off and the top will come off.
Check out www.fluidmaster.com for more trouble shooting details.
Jun 05, 2010 | Fluidmaster & Fits-All Faucet Connector
Sep 27, 2009 | Fluidmaster Plumbing
Home Logo
245 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
