Question about Kitchen Ranges
Ge spacesaver micro about 7 yrs old runs but does not heat. i found one fuse by itself, it was good. did not see any fuse on the board.if its the magnatron tube is bad ,are there many different ones, or might i find one in another microwave of the same power paul 410-790-5705
  • pfhh Oct 13, 2010
    ge spacesaver microwave runs but does not heat. i found one fuse by itself and it tested good.it is about 7 yys old. is threr a fuse on a board somewhere?. could it be a bad board, or s it the magnatron tube, and if so , does it have to be replaced by the exact one , or can i get one out of a like wattage unit i have
    Genius:
  • 1,456 Answers
Hello
Voltage test the outlet the microwave is plugged into. If you are not getting a reading, the breaker is probably blown. Reset the breaker for that outlet in your home's circuit breaker box.
Reset the microwave breaker. Take the back cover of the microwave off with a screwdriver. Inside you will find a motor. Most microwave motors have a small red reset button on them. Hit that button. Your microwave should work again if the breaker was the issue.
Unfortunately, if it is not a simple electrical problem, then the issue is likely your magnetron, which disperses heat through the microwave. These cannot be replaced, and you will probably have to buy a new microwave.
Never work on the engine of the microwave while it is plugged in.
Posted on Oct 13, 2010
    Genius:
  • 1,478 Answers
If your microwave oven is not heating up, the fuse is the major cause of this but you said it looks good, i will advice you replace the magnatron tube, it can also cause microwave oven not to heat up, you can get one at ebay.com or amazon.com. You
Take care.
GE spacesaver won't clean dishes, ran finish and dishwasher magic, still won't clean. Ideas? Only 3-4 yrs old.
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Nov 05, 2010 | GE Dishwashers
GE spacesaver II making loud noise and is not heating up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Heat doesn't come on in microwave
If you have the experience with discharging a capacitor and you have a (VOM) Volt Olm Meter. Unplug microwave, discharge capacitor, and check the resistance of the two thermal cut-off discs by removing the lead and set VOM to RX1. If you don't get a reading of zero, replace the discs. For part go to www.partselect.com and enter your model number. If you found any of these suggestions helpful, please rate my solution. D. Lange
May 01, 2009 | Microwave Ovens
GE microwave not heating lights and keypad functional
You may have a fuse blown on the micro/ the vent and lights are a diffrent cercut , Try replaceing the fuse. its on the in side of the unit. if you need further assitance and you think you can do this I will be happy to instruct U DFD
Apr 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE self-cleaning radiant range about 13 years old. The self-cleaning feature doesn't work anymore. The latch doorlight, even though set correctly to the right,keeps flashing on and off and the...
It could be a micro switch in the latch mechanism not communicating properly with the display circuit board, or it could be the circuit board itself. The switch might cost 20 or 30 dollars, but the board could be hundreds. Kinda costly if you ask me...
Mar 13, 2009 | GE Kitchen Ranges
Microwave makes loud noise and does not heat. Smell of light burning
yes anything can be fixed but a do it yourselfer i reccomend against this cause thats a radiated element in the micro
recommend go out and purchase a replacement go with G.E. they have the 7 year warranty great little micro. too change out is easy
Jun 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Spacesaver micro not heating
Your magnetron, HV diode, Capacitor, or control board maybe bad most of these components run with high voltage and difficult to test without the proper equipment
Oct 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver doesn't heat
if you are as lucky as i was...i have a ge spacesaver model jvm130...same problem. first unplug unit and check fuse on the "power control module". if fuse is ok...unscrew the screws holding the "power control module" in place...carefully tilt module and see if a solder joint needs to be re-soldered. my problem was the solder joint under the front plug (5 large wire plug). you may have to unplug the three connectors to the board to get access to bottom. this is the second time i had to re-solder...last one was several years ago though. best of luck tennisrme
Aug 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Kitchen Ranges Logo
46 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
