Question about Canon Office Equipment & Supplies
Hi, I have a problem with the printer Canon iPF600. Printhead is not in order - have clogged nozzles. For this reason, I guess gives me an error E161-403E. I bought a new print head, but can not log in the menu to change it because when I go as printer error. How can I go to the menu to change the printhead? Regards! M. Metodiev
  • Metody Metodiev Oct 13, 2010
    This is exactly as you explained it to me. But this is a half-explanation, because my next question would be - how to access service menu. This is the complete answer. I already did and the printer is in order.
    Regards
    M. Metodiev
    President:
  • 1,216 Answers
E161--403E means that the temperature of the print head is abnormal
you have to enter the service mode(not the main menu) and perform print head replacement.
Be carefull of the firmware update. you have to do the firmware update first
Posted on Oct 13, 2010
  • Aviral Saxena
    Aviral Saxena Oct 13, 2010
    I guess what u want from me is how yo access service menu,but your printer is in order
I have the same problem. how do i fix it. havent ordered the print head yet but i am stuck with the same error code and there is no way to bypass it
Posted on May 28, 2013
Why won't it print with black ink?
Hi Michael,
Can you check the printer properties whether it shows up the new ink level ? I would like to have more info to help you further
Thanks
Seb
Jun 02, 2015 | Canon Pixma MG5220 InkJet Printer
Tip
How To Check Print Head Nozzle Condition
Sometimes we need to know condition of the printhead of our printer. How to check it?. In order to know whether printhead nozzles are clogged of not perform following steps:
* Set paper in sheet feeder
* Right click in the printer driver name
CONTINUE READING...
on Sep 19, 2012 | Canon Office Equipment & Supplies
I had some problems with my IPF 600 printer. i had to clean printhead, so i started with head cleaning A but after 2 or 3 times i putted on head cleaning B for 2 or 3 times. Also didn't work. ink level is...
maybe the print head nozzles are to badlly clodged or purge unit is faulty and cant **** out the ink.
Try to phisicallly remove print head, put the nozzles on piece of wipe, previouslly moistured with destiled water.Press gentlly few times. Dry it by pressing it on dry wipe.Put back in, run head cleaning once again and check the nozzle pattern.
If you want service manual, you can write me on emma.servis@gmail.com
Aug 30, 2010 | Canon imagePROGRAF IPF600 - large-format...
How do I replace the printheqad on my Canon
go to menu-maintenance-replace print head check yes and then OK
Oct 28, 2009 | Canon imagePROGRAF IPF600 - large-format...
My printer will only print all text on the high setting,on standard it prints with a lot of gaps.
if its a canon or hp printer try changing the cartridge if inks have built in printhead, if not try changing the printhead. if its an epson printer only authorized service center are allowed to change the printhead. the reason for the horizontal banding in printouts is that some of the nozzles in the printhead are not functioning or clogged.
May 17, 2009 | Canon Office Equipment & Supplies
Photo Quality is Poor
hi i am a certified Canon repair tech for this printer. the reason for this problem is the printhead. what happens is when the printer is new the printhead has little mirco nozels that the ink goes through. when the printhead gets older the nozels get smaller and smaller causing problems. the first thing i would do is replace the printhead that can be ordered from Canon direct at 1-800-OK-CANON or their website or a canon service center. hope this helps.
Jan 01, 2008 | Canon Pixma MP500 All-In-One InkJet...
Black will not print
I am not sure if this will help but I will try. I have 4 types of Canon printers and 7 canon printers. I have had problems w/some of my colors not coming out. There are 2 ways that I've done. First is the simpler one. Just go to the printer maintenance and choose nozzle cleaning for the BCI3 or the Colors CMYK or for all. If after that you do a print check, not the printhead alignment, and the black still doesn't come out then the 2nd way is to pump it out of the printhead. The print check should give you an indication which of the black is not coming out. I checked over the net and see the IP4000 has 2 black cartridges BCI3 and BCI6. So we need to identify which of the black is not coming out. Based on the print check you can identify which of the black is clogged. I suggest you remove the printhead from the printer. The lever that holds the printhead should be just above or in front of the cartridges. I'm guessing that you may have used refilled cartridges before. Which might have caused the clog. But then even original inks under extensive use also has that problem. Not as fast though. You can choose to identity which of the 2 black colors are clogged or you can choose to just unclog the 2 black colors in the printhead. You can do this by getting a syringe and a plastic or rubber tube that has about 5mm for the inner diameter hole. Cover the round nozzle from the inside of the printhead and slowly pump out the nozzle. You should have tissue or newspaper under the printhead and make sure it less than an inch above the tissue or paper. That way you don't get splattered when the ink comes out. When the old ink has cleared out, put the cartridge back in w/ the printhead. Turn the printer off and on a 2-3 times so the printer can prime the tubes in the printhead. Do either 2 light or 1 deep cleaning. Then do a printcheck to see if the black will print.
I think you problem is only a clogged printhead. So you can do the light nozzle cleaning,or deep nozzle cleaning or you can flush out the printhead manually. This should open it up and I think it will be ok. If not, let me know. That's going to be a challeng for me.
Oct 09, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
1,124 people viewed this question
old marine
old marine
