Question about Acer Aspire T180 PC Desktop
I want to do a RAM upgrade. It has an Athlon dual core processor 4200 2.2GHz. What type of RAM do I get?
  • 2,229 Answers
Check here:
http://www.theupgradeplace.com/
These are the people who I use as memory vendors. The will gladly supply you with the information. They are very good and have memory at reasonable prices--but then you are free to buy anywhere you wish.
Posted on Jan 17, 2012
teknowolf
  • 207 Answers
SOURCE: ACER Aspire T180 Upgraded and and now freezes
I have the same PC. I have a couple of POSSIBLE solutions for you.
First, it turns out this MB is REAL picky about its memory so make sure all your RAM modules have the same spec's (Manufacturer, speed, timings etc....) and make sure that if you only have 2 modules that you use two that are the same color as these are the match pair.
Second, seeing as you spent money on Corsair RAM you may be a serious gamer and probably have other upgrades on your system. The power supply that comes with this Unit is only a 250W PSU. Hardly enough for the base unit itself. If you want to do any serious computing tasks with this PC I would recommend upgrading your PSU to at least a 450W unit.
Hope this helps
Dave
Posted on Nov 06, 2008
VenkY3K
  • 118 Answers
SOURCE: Hi,
check compatabilty check online for your board chipset on the www.acer.com/support will find the solution for the upgrade cpu compatabilty, gudday !!
Posted on Mar 23, 2009
  • 4 Answers
SOURCE: Processor update..
The problem with Store bought PCs is that there is no way to tell how fast a proccessor you can safely put into one before it becomes overclocking, but in theory your exact motherboard should support an AMD Athlon X2 5800+ 1000 Mhz FSB. Now if your willing to take a risk, you could buy a 6400+ but be warned, the computer may not recognize it, or it may just underclock the proccessor, if the processor supports 800 Mhz FSB. I said the 1000 Mhz FSB because it can underclock to that speed, and also because they no longer offer 800 Mhz flavors at the sites i order from. Hope that helps.
Posted on Jun 16, 2009
  • 132 Answers
SOURCE: Need to know how to upgrade processor in an Acer
here is a link that should help.. the only thing i can add is make sure you note and pay special attention to the orientation of the processor. Specifically where pin one is, if this is your first time doing it take a picture of the processor area so you can note which corner pin 1 is when you insert the new chip... Also make sure you have a static srap attached to your wrist leave the computer plugged in but turn of the switch on the surge protector and ground yourself to the chasis of the pc.
See link below for additional info, read it in it's entirety before you attempt.
Rich.
http://www.ocf.berkeley.edu/~joyoung/cpu/page1.shtml
Posted on Nov 01, 2009
SOURCE: want to upgrade my proccesor
OMG!! doogie812, quit giving people bad advice. From what you have suggested, you know nothing about computer hardware. You can upgrade the processor in this system and it will not effect the OS one bit, except make it process the data a little quicker. With this system, if you had done any research at all, it only comes with 1GB of memory, you should of suggested to this person to add more memory.
Posted on Apr 13, 2010
Want faster processor for acer x1300 it base unit
Here are the spec on your pc if the information you gave me is correct. You can only upgrade the cpu to the socket you have. I think you would be better off adding more RAM and a better video card that isn't onboard. Processor / Chipset
  • Type AMD Athlon X2 7450 / 2.4 GHz
  • Number of Cores Dual-Core
  • 64-bit Computing Yes
  • CPU Qty 1.0
  • Max CPU Qty 1.0
  • Chipset Type NVIDIA GeForce 8200
Aug 18, 2013 | Acer Aspire X1300 Dual Core 2.4ghz, 3gb...
Processor upgrade
upgrade your ram mem, best bang for the buck
Mar 23, 2013 | Lenovo 3000 Computers & Internet
I want a dual core processor upgrade
You listed this under PC Laptop? It's a Desktop? Have you ever done a CPU upgrade? You are limited to what will work with your machine, Mobo and other components. Your Mobo is, of course, AMD compatible, so if you read the specs: http://support.acer.com/acerpanam/desktop/0000/Acer/AspireX1200/AspireX1200sp2.shtml The AMD Athlon X2 dual-core is best option. Memory is a easy option to increase speed a bit. Remember, with a 32bit OS the most memory it can use is 3.80 GB's More or Less. With a 64bit OS use more. I have done many CPU upgrades, you may not get the Speed/ processing increase you expect. After all, the components work in conjunction with one another. Do your research on Socket type, Pins, Power requirments, etc., etc.Check, Verify, then re-Check and re-Verify. Use this little freeware program to assist you, it list Spec info in detail, SPECCY at: http://www.filehippo.com/download_speccy/.
Jan 12, 2013 | Acer Aspire Computers & Internet
How do i read the motherboard to see what board i have
The Manufacturer of the mother board is MSI and details are as follows:
Manufacturer Part # :K9MM-V
Product Type :Motherboard
Form Factor/chase: Micro ATX
Chipset Type :VIA UniChrome Pro K8M800 / VIA VT8237R Plus
Multi Core Support :Dual Core
Max Bus Speed :800 MHz
Socket Type 0 ( 1 ) :- Socket AM2
Compatible Processors : Athlon 64, Sempron, Athlon 64 FX, Athlon 64 X2
It supports 64 Bit Processor
Multi Core Support :Dual-Core
Its Supports RAM Technology: DDR II SDRAM
RAM Installation : 0 MB / 2 GB (max)
Supported RAM Speed :PC2-4300, PC2-6400, PC2-5300
RAM Features :Two DDR Channels
Video Memory :Shared video memory (UMA)
Audio Codec :Realtek ALC655
Sound Output Mode : 5.1 channel surround
Expansion Slots Total (Free) :1 processor - Socket AM2
You can addin RAM of :2 memory ( 1.8 V ) - DIMM 240-pin
PCI :3 PCI ( 3.3 V/ 5 V )
Storage Interfaces
Additional Connectors : 4 x Hi-Speed USB
Dec 21, 2009 | MSI K9MM-V Motherboard
What is the best procesors(powerfull) for motherboard NF 61S MICRO AM2 SE..?
AMD Athlon™ X2 Dual-Core Processor
AMD Athlon™ 64 X2 Dual-Core Processor
are the best processors for this motherboard
Nov 28, 2009 | Biostar NF61S MICRO AM2 SE...
Upgrade processor in Toshiba Satellite AMD Athlon 64x2
Best way to do all that is to buy a new computer, already configured as desired.
Oct 13, 2009 | Toshiba Satellite Laptop with AMD Athlon...
Want to get more ram for my computer
Use the free tool on this site to scan your PC to determine what kind of memory you need:
http://www.crucial.com/index.aspx
Mar 16, 2009 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Upgrading processor
Sorry, the Motherboard is made by Micro-Star International Co., Ltd.
Model: MS-6734
Chipset: VIA KM400
Southbridge: VIA VT8235
LPCIO: Winbond VV83697HF
Hope this is what you need
May 27, 2008 | Computers & Internet
Acer Aspire T180 PC Desktop Logo
20 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
