Question about Samsung SGH-D820 Cellular Phone
Hi,everyone! I've been using Samsung D-820 for a long time but suddenly in the middle of a conversation,my display wont work anymore while everything else is working fine.Is that related with flat cable or something else? If flat cable should be the problem I would gladly take it to Samsung service,if it's not I'll keep it just as a sentimental value or a fancy alarm clock and buy a new phone:))
    Sergeant:
  • 172 Answers
Yes surely its the flat cable or commonly called flex cable or ribbon connector is already have a cut or damage bring it to samsung it is the of your phone.
Posted on Oct 13, 2010
  • Srdjan Peljevic Oct 13, 2010
    Tank you very much for help and for clearing that out...:)..I owe you a beer or something if you ever visit Belgrade,Serbia:)..All the best!
Why is my Samsung phone say : unable to connect with WEP460.
get into router and take off WEP, run it wide open. If it works, turn WEP back on or go to WPA2. Some newer devices wont do WEP anymore.
Sep 04, 2015 | Samsung Cell Phones
Samsung Galaxy S2 fell into water wont turn on ! PLEASE HELP
You should not have tried to use it right away. You should have immediately pulled the battery out and then blow dried it and put into the rice bag for 24-36 hours. Because you tried to use it is shorted out. You will need a new phone as it is probably not going to be able to be fixed. Sorry!
May 06, 2012 | Samsung Galaxy Cell Phones
Hi I've had a parrot mki9200 in my van for a year
maybe its time to bin it could have anything and everything wrong with it and the cost to repair will be more than a new one from the ****** shop
Feb 04, 2012 | Car Audio & Video
Samsung S8300 touch screen wont work all of a sudden
hey mate, same problem with my phone, only has happened to me recently. seems to be a problem with these phones, have you found a solution? if so, could you contact me? cheers.
Jul 30, 2010 | Samsung Lands Phones
I VE A SAMSUNG LCD TV/MONITOR SNYCMASTER 932 19
can you see that a capicitor 820/10v is pluked ? replace it.
Feb 21, 2010 | Samsung SyncMaster 932B LCD Monitor
HI I have a FSP200-61GT SPI switching power supply with a burned out Mosfet on the high voltage side. There is a (I think)a .5 or 1 watt resistor on both sides of the mosfet. But they test good, my problem...
I think it's usually about 820 - 1K Ohms... It;s the emitter resistor.In saying that we generally don't repair these SMPSU's anymore as they are so inexpensive these days like NZ$45.00 for a 350 Watter. Also 80% of the time the repaired supplies fail again shortly after due to the stress put on the other components, by the initial problem.Good luck.
Jan 27, 2010 | Computers & Internet
Apple Cinema Display 23" LED short-long-short flash prob.
Hello, I had the "short long short" blinking led problem with my 23" ACD after a power outage which left my screen blank and my cheek wet with a tear for my baby. I read somewhere that a guy was getting a 1 volt reading on the middle pin of his damaged 90 watt power block. I figured maybe the display might work if I could somehow block the middle pin. So I cut a small strip of paper wide enough to block just the middle pin and long enough to cover both sides, folded it to look like a "W" from the side. I then carefully pressed it into the brick receptacle with a toothpick leaving just a little slack so it would not tear when I pushed in the small white plug. It was a bit of a tight fit but guess what. IT WORKED! I am now enjoying my beloved monitor anew and saved $$$ on replacement brick or repair. If you want to try it and you feel you’ve nothing to lose, make sure you cover just the middle pin (both sides) and you may have to try a couple of times. It worked for me. I hope you have good luck too. Regards, Moozler
edit December 2016. Still working after 7 years.
***CAVEAT AND WARNING***
Use this fix at your own risk.
A faulty voltage regulator is probably the cause of failure. Voltage regulators can start a fire if too much voltage is applied.
Bud Martin's post below describes the electronic component failure that causes this problem. Thank you Bud.
Jul 19, 2009 | Apple Cinema Display 23" HD Monitor
Samsung SGH-D820 Cellular Phone Logo
96 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
