Question about Kenmore 22422 Top Load Washer
How can you disconnect the lid switch so the washer works when the lid is open? I am asking this because the switch has failed, and I want to bypass it, not fix it.
    President:
  • 1,891 Answers
By passing the lid sw is ok if owner is only on that uses it . but this sw is there for a reason .( I think you know why . ) if you by pass it it may save yor a small part cost . but what if you open the lid and its still spinning and your hand or arm gets caught in it . and in some cases i know of the agitator and come loose and damaged the lid but the machine did stop . hope this helped mm
Posted on Oct 16, 2010
Can i bypass the lid lock on a amana washer model ntw4605ew
Can you do it? Yes.
Do I recommend it? NO.
The lid lock it to prevent injury to the people near the washer, as without it stopping the machine, the agitator will turn with the lid open.
So.
If you will open the top up, you should see the lid switch, and you should see the electric wires attached to it.
With the machine unplugged, you can disconnect the wires to the lid switch and attach them to themselves, and the lid switch will then be by-passed.
May 10, 2016 | Amana Washing Machines
Can I bypass lid switch latch completely
1 way to find out . do it and if it doesn't work put it back the way it is now .
Feb 22, 2015 | Washing Machines
I have a Whirlpool Gold Ultimate Care II washer (MOD# GSQ9669LW0) The washer stopped, was full of water and will not restart on any cycle or settings.
This problem sounds like a broken lid switch. Power to the drive motor is routed to the lid switch and if the lid switch fails, the machine will fail work on any cycle. Verify this by bypassing the lid switch.
Disconnect power to the washer then remove the screws securing the console to the rear of the cabinet.
Pull forward and up on the console and lay it back on the hinges.
Disconnect the lid switch harness connector by pressing on the tab located in the middle and pulling it up.
Jump a wire between the outer terminals of the disconnected connector from the top of the cabinet then reconnect power. The problem is indeed the lid switch if the machine starts. Check the lid switch plunger and the lid switch attachment to the cabinet. It may not activate properly if the mounting is loose, re-tighten it. Replace the lid switch if the plunger is intact and and if it is mounted tightly and properly.
The cabinet is attached to the rear of the washer by two brass-colored retaining clips. Insert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, and then pry back to release the clip from the slot in the cabinet.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base.
Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up the cabinet and lay the front on a cushioned floor to access the lid switch.
Remove the lid switch ground and mounting screws then release the wire harness from the metal retainers. Pull the lid switch connector out and install the new lid switch in reverse order of the removal steps.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine.
Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
Jan 11, 2011 | Whirlpool Washing Machines
My Lid on my washer displays open when I close it and won't start if lid is open... please help.
your lid switch is not working or may be jammed try opening the top of the back of the washer make sure the lid switch is working im not sure if the mtw range uses switch or magnetic recognision with switch there is a small lid switch that clicks when the lid is slightly lifted with magnetic it makes no noise however they can both be bypassed by cutting the switch wires normaly black and red running along the right side of the control board (making sure power plug is not plugged in) stripping the two wires and joing them together
this should work
Dec 28, 2010 | Maytag Bravos MTW6600T Top Load Washer
The washer filled up with water but wont turn on
This is a clear evidence of a broken lid switch. Power to the drive motor is routed through the lid switch. The machine, therefore, will not turn on when the lid switch is not working. Manually activate the lid switch and if still doesn't work, bypass the lid switch. Disconnect power then jump a wire between the outer terminals of the disconnected connector from the cabinet top then reconnect power. Replace the lid switch to address the problem if the machine works with the lid switch bypassed.
Release the console from the top of the cabinet depending on the model of your machine then pull forward and up on the console and lay it back on the hinges.
Nov 09, 2010 | Whirlpool LSN1000LW Top Load Washer
My Kenmore 80 series will wash, but when it gets to the rinse it won't spin or drain water? I had used it the day before and it was working fine with lid open or close. Didn't have to close the lid for any...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
It sounds as if the Lid Switch had been stuck in the closed position and something caused it to open and stick open.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Oct 12, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 70 series #11020722990 how to open cabinet and replace lid switch?
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20722990&pathTaken=partSearch
Aug 10, 2010 | Kenmore Washing Machines
LS error
The machine control detected that the lid switch is not functioning properly. Raise the top part of the washer to gain access to the lid switch.
Disconnect the machine from the power source. Gently pry the emblem from the front of the machine and remove the T20 torx screw hidden behind it. Slide the top of the washer forward and raise its front. Prop it up high enough to allow easy access to the lid switch.
The lid switch is activated by an actuator (part number 19119) mounted on a hinge. It will not work properly if the actuator is damaged.
Check the operation of the lid switch using a multimeter. Disconnect the lid switch wiring harness and connect the test leads of the multimeter (set to X1 or ohm) to the terminals of the lid switch and activate it. The multimeter should read zero ohms while the lid switch is activated and open when deactivated.
Replace the lid switch if it is broken or if it fails the test above. Remove the lid switch mounting screw and install the new lid switch. Reconnect the wiring harness and slide the top of the washer back into position. Reinstall the T20 torx screw and the emblem.
Feb 11, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Lid switch is out
I would recommend you replace the lid switch rather than by-passing it. The following link explains how:
http://www.fixya.com/support/r385198-replacing_lid_switch
The lid switch is a safety feature that is to protect the consumer from the high speed rotation of the wash tub and the agitator. If you by-pass it, you will need to push in the timer PRIOR to opening the lid in order for the tub to stop. I would recommend by-passing as a last resort (temporary repair) while awaiting a new switch.
To by-pass a lid switch, follow the steps in the link provided to open the console. Make sure the washer is UNPLUGGED. Locate the white lid switch connector and unplug it. Remove the washer exterior case and remove the lid switch from under the washer casing. With the lid switch in your hand, cut the connector plug off, leaving about 2 inches of wire. Remove the green (center wire) from the plug and crimp the two black wires together. You have just made yourself a by-pass plug. Plug this back into the connector on the timer and the washer will now operate without the lid switch.
As I stated before, you will need to push in the timer prior to opening the lid to stop the tub. You can save the plug for future use, but use only as a temporary fix.
Replacement switches are available at searspartsdirect.com, appliancepartspros.com, repairclinic.com, and pcappliancerepair.com. They don't cost much and I provided you with easy instructions to follow.
If you have any questions, please let me know. I hope this helps you.
Jul 06, 2009 | Kenmore 24032\24036 Top Load Washer
My washer won't drain
I just had the same problem and it was the lid switch. I disconnected it so to bypass the switch and now it works. A friend at work also had the same problem and called sears out and it was a stocking stuck in the drain hose. you can google a fix my washing machine and it will tell you how to repair it yourself. That is what I did with the lid switch.
Jan 20, 2008 | Washing Machines
Kenmore 22422 Top Load Washer Logo
69 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
