Question about Lutron 600-Watt Incandescent Dimmer Switch by Electronics, Inc
Fast blinking led indicator on dimmer switch. lights won't turn on. connected to chandelier. changed out all bulbs and now bulbs and indicator blink very fast.
    Novelist:
  • 107 Answers
Which product is this (the one pictured doesn't have an LED indicator on it)?
I would call their tech support number 1-800-523-9466 to diagnose (available 24/7).
I suggest this because I can think of a few possibilities (is it a dimmable load or a non-dim CFL - is it an LED load that might not meet the minimum load requirement)? And I think the answer will differ based on what product you're using - do you have a model number of what product it is?
There's more answers that are needed to diagnose, so I would call tech support.
Posted on Oct 15, 2010
02 impala back turn singles blink fast, when the hazards are on they blink normal but nothing blinks in the front changed all the bulbs the hazard and turn single switch put new fuses in help
Use a volt meter or trouble light, to test for voltage at the front lights, remove the bulb,turn ignition on, probe from the center of the bulb holder and to the side of the bulb holder must be battery voltage, if not probe from center of bulb holder to metal of car body, if there is now voltage the light has a bad earth, if still no voltage there is fault in the wiring from the lights to the indicator switch, or the indicator switch is at fault.
Apr 03, 2016 | Cars & Trucks
What resistors do I need to fit LED tail lights to a 2012 PX Ford ranger ute
fast blinking light tells you that one of the bulbs is bad. replace the bad one and it should be fixed not need for resisters EVER
Jan 05, 2015 | Ford Cars & Trucks
Both signal lights blink fast
Fast blinking is an indication that one of the bulbs has burned out. The lack of resistance in the circuit causes the blinker to blink faster. Recheck your bulbs.
IF this happens after replacing standard bulbs with LED bulbs, you need to add a resistor at each socket to resolve the problem.
Oct 10, 2014 | Cars & Trucks
Installed LED turn signal lights. Turn signal now blinks too fast. Solution
Hi Dennis
the indicator blinking fast because the LED use less AMP then ordinary bulb, I know an old trick to solve this problem is to connect an extra bulb to each rear indicator by running an extra wires from the light connector to an extra bulb holder.
Good Luck
Mar 02, 2014 | Cars & Trucks
Kia turn signal works but blinks fast on right side when parking lights are on
turn on park lights and signal on right side and take a good look at the front and rear light , see if one is dimmer than the other this may be due to a bad ground and when the park lights are on and drawing more power it also needs better ground, check the sockets front and rear try wiggling the bulb to see which one is causing the problem
Jan 04, 2013 | Cars & Trucks
I installed 2 3 way lighted dimmer switches (DR703PWV) in my Living room Chandelier, and the control for On & Off is working as it is supposed to, but when I try to dim the chandelier flickers from...
Install one dimmer at the load end feeding the light. Install a standard 3way switch at the other end. Make sure the dimmer switch is rated for the type of bulbs in the fixture. ie Led, halogen etc.
Mar 16, 2011 | Pass & Seymour Trademaster 3-Way 15 Amp...
I have always used a lutron maestro dimmer. I replaced the chandelier and put in 6-60 watt bulbs. My previous chandelier used 18-25 watt chandelier bulbs and the dimmer worked fine. after changing the...
You should have just two wires plus a ground hooked up to the dimmer. It should install just like the maestro. If you are getting no lights with a double tap, or tap and hold, and if the led is not on, it is one of several things. Most are basic, but will list anyway. Check that your connections are good. Make sure you have power there. Make sure the bulbs are good. If all is fine, you probably have a defective dimmer if it worked prior to this. To test, take the dimmer out, restore power, and carefully touch one insulated wire to the other one. If the light comes on, it is the dimmer at fault.
Mar 06, 2011 | Lutron ELECTRONICS MAW-600H-LA SMART...
I just installed a chandelier. This is a new connection. So I ran a 3 wire from the chanderlier to a new lutron slide dimmer. I then ran a 2 wire from this dimmer to the switch. When I turned the...
Lutron Dimmer manuals
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro%C2%AE+dimmer+%26+switch
Lutron manuals show a couple things that might be affecting you lights.
1) Wattage: If you have wrong wattage dimmer
2) Type of light bulb: Dimmers work on different types of bulbs
3) Wiring: You say you got 3 wires going to the chandelier? Why you got 3 wires? Is this a 3 way switch? Are the chandelier bulbs wired separately so you can control groups of bulbs with different switches?
Does the dimmer have 3 screws? A dark-colored screw and 2 brass screws? If so, then that sounds like a 3-way dimmer. A 3-way, is where more than one switch controls the same light.
Does the dimmer have 2 screws? Then that dimmer controls a single circuit. Your black Hot wire from breaker box connects to one screw and the black wire to Load connects to other screw.
A quick glance at Lutron wiring manual shows that Hot and Load wires connect to either screw.
The question is your 3-wires from the chandelier ... does the black Hot wire from breaker arrive in the ceiling box first? Or does it arrive in the wall box first? If your Hot arrives in ceiling box, then the Hot must come down to the switch box and connect to a screw on the dimmer >>> a second wire connects to other screw on dimmer and travels up to the ceiling box where it connects to black wire on chandelier. The white wire on chandelier connects to white Neutral.
4) Dimmer might be bad
Oct 16, 2010 | Lutron #DVW-603PGH-WH 600W White Single...
Lutron 600-Watt Incandescent Dimmer Switch by  Electronics, Inc Logo
538 people viewed this question
Top Lutron Electrical Supplies Experts
Steve
jdthefixer
Craig Butler
Craig Butler
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
