Question about Cell Phones
Screen on Sagem D16T handset saying to PLS REG H/S. People can still ring but there is no dial tone because of this
caroldon
  • 17129 Answers
SOURCE: I have a Sagem D16T
Normally the registration takes place automatically as when the handset is fixed on with the base . If there is no communication of the base to the handset there will be the signal showing -waiting - as it tries to connect.
If there is no connection after the "signal hunting" the menu resets.
The possible fault is a change in the frequency of communication . You can remove the battery on the handset, remove power on the base and keep aside. replace the battery and connect the base unit, if the set was unused for a longer period it is possible that there are changes in capacitor values that will effect the frequency of communication.
Keep the sets plugged in the power overnight and check once again. If not try to warm up the circuit board- specially if there is leak of battery on board this might be serious.
Posted on Feb 14, 2011
  • 14 Answers
SOURCE: Dial Tone - Number Dialed does not go through
The problem is possibly the keypad on the phone. Try another phone , preferrably a standard corded phone. If you still cannot break the dial tone, then the problem is with the telephone line (phone company)
Posted on Apr 01, 2008
SOURCE: sAGEM MYx-2 RING TONE PROB
get a job
Posted on Aug 06, 2008
SOURCE: Switching from pulse to tone dialing (there is no switch on the base unit)
hold the select button down a few seconds until you'll see a 'tn' on the readout. this sets it to tone. hold it down again and it will set back to 'Pu' for pulse. i figured this out by accident. the losers at vtech never answered my question.
Posted on Jan 23, 2009
  • 31 Answers
SOURCE: No dial tone in Clarity C4230 setup
if you can get dial tone with another phone, look into manual for any instructions, usually a toll free number for help. ( BEST ) otherwise take phone back for exchange. may be problem in the board.
Posted on Apr 16, 2009
No dial tone...line in use appears on screen
you may have a broken wire somewhere or a bad jack
Jul 31, 2012 | Vtech DECT 6.0 Digital Cordless Phone
I have a GE Cordless 5.8 gigahertz handset and digital answerer. I can see the red light flashing during an incoming call, but hear no dial tone and no ringing. I just replaced the battery. The handset...
Did you pay the Bill ?
this seems as if it,s incoming calls only. Check the line with an alternative Phone. This will verify the lines good. And eliminate that One.
Also check if theres A Tone/Pulse setting.
This can also have adverse effects.
If this is on an adaptor fitting with internet access, try removing the adaptor, and plugging the phone direct into the Socket.
Or try the phone on a seperate or diferent Socket.
Hope This helps.
Mike @ compurepair.
Mar 05, 2008 | Lands Phones
The phone is not ringing and it is plug on charge and my wife got new battery for it too. What can i do to get it working? What size of Batteries cani use for this cordless phone
You need the specific battery pack: 5-2814 for the handset. This is a 850 mAh Nickel Metal hydride battery.
When I see a cordless phone that doesn't ring, the first thing I recommend checking is the phone jack and line itself with a second phone. I prefer to use a corded handset with a new phone cord to check for dial tone. If no dial tone at the jack, check for dial tone at the service entry box. If you have no dial tone at the service box, contact your provider. If it's only a problem at the jack, you will need to check your inside wiring.
To check the base, try a new cable (RJ-11) (double check the power as well).
To check the handset, first make sure the handset is fully charged (16 hours) and that the battery is fully installed. Does the handset beep when the Talk button is pressed? Next check that the handset ringer software is on. With the phone off (not in the talk mode), press the Mute/menu OK button. Use the Caller ID/volume (up/down) buttons to get to the Handset setup menu. Press the Mute/Menu OK button to access the menu. Use these buttons to check the Ringer Volume (should be on) and Ringer Tone. Press Mute/Menu OK to save the settings at each sub-menu. Check that the Do Not Disturb function is not on - this toggles with the Do Not Disturb button and should be noted on the handset screen when on.
If you have multiple extensions on the phone line, try unplugging some of them.
I hope this helps.
Jul 07, 2010 | GE T28821FE2 19 GHz Twin 1Line Cordless...
No dial tone. Base will ring. Handset has no
Check the Battery on the Handset. remove the pwr frm the base unit n connect aft 30 sec. aft this if it still says the same msg, then the handset needs to be replaced.
Mar 03, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
I cant get my phone to work. I get no dial tone and it says connecting but never connects. incoming calls ring but i cant answer
dear
There are a number of things that could be wrong. It really depends on what kind of circuit you have. Is it strictly copper or does it come from a pair gain system? I have had trouble calls for this very reason and I isolated the trouble to a pair gain card in the field. Have you tried dialing out when you have no dial tone? Most people don't realize that dial tone is not a requirement to make phone calls. It's an added feature that lets people know that it's working. It could also be a high open. Just means that one side or both wires of the pair are close to being broke and sometimes very hard to see. I would keep calling because they won't know you have trouble until you do so. Plus you will have documentation that it's an ongoing problem. Good luck.
or
Another possibility is a shunt caused by spiders or whatever. These can get much worse when it get's wet. They might clear on a ring too.
I'm voting for number 1 unless there is more info provided.
I'd provide Verizon with the RENs of all the phones added up. There is probably a 1/2 ringer or (1/2 REN) in the NID.
You need to determine if it's inside or out.
Jan 05, 2010 | Uniden 5.8GHz Cordless Phone
Apr 16, 2009 | Clarity C4230 Cordless Phone
Phillips magic5 problem
Hi, I had this problem and spoke to sagem at www.sagem.com/support.
the solution is simple, turn off your fax machine at the wall, take out your batteries from the handset and leave both off for 15 minutes. then turn on the fax machine and replace the batteries back in to your handset, at it will work.....
Jun 15, 2008 | Philips Magic5 Voice DECT Duo - Fax /...
Hi you posted that you could unlock any sagem! can you unlock sagem my150x and will it be free?
hi,i am sarab from india .i have sagem my150x handset but my handset is not working .my handset is locked so,i canot use it pls ,tell me about the soloution of this problem .i'm very thankfull to u for this pls .....help me
my id is sarbsaab@yahoo.com
Jun 02, 2008 | Sagem My501X Cellular Phone
Faxmachine
CHECK 1.DO YOU GET DIAL TONE ON -ON HOOK DIAL BUTTON OR ON THE HANDSET ? IF NOT PLS CHECK THE PHONE LINE OTHERWISE--- 2.TRY RINGING THE MACHINE FROM OTHER PHONE,CAN U HEAR THE RING ? IF YES ,PLS CHECK WHAT NOS OF RINGS ,THE MACHINE IS SET TO RECEIVE, AS WELL AS SET THE CORRECT RECEIVE MODE , I.E. FAX /TEL/ANS-FAX... 3 IF U STILL DON'T GET FAX TONE WHILE RECEVING ,THEN TELEPHONE LINE CARD SHOULD BE BAD... TRY REPLACING TEH SAME ,SHOULD RESOLVE THE PROBLEM. HAPPY FAXING OMNIPRESENT HAPPY FAXING
Sep 21, 2007 | Office Equipment & Supplies
Cell Phones Logo
457 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
