Question about Philips 42PF9630A 42 in. Plasma Television
My dead 42" plasma - power problem
Following some suggestions from you guys, I got brave and pulled the screws off of the back of the TV. I followed the AC wire to the input on the board. Right next to it was a fuse. I borrowed my friends Fluke multimeter and checked. I got no response. I checked another fuse to make sure and I got a beep, so I know the fuse is blown. It is a T8AH250V P - does anyone know where to find one?
By the way - YOU GUYS ROCK!!!!!!!!!!!!
Thanks
atombomb72
  • 2 more comments
  • atombomb72 Jun 01, 2008
    I only have a Fluke CAT III Clamp Meter. When set to ohms I can check connectivity. I don't have settings for both. The screen on the fluke reads 1 when I turn it on, when I check the bad fuse, it simply stays at 1. When I put it on a good fuse in the TV, it reads .03
  • Anonymous Sep 01, 2008
    I just did the same thing this weekend. My Plasma's been dead for a month. So I asked my brother in law, an electrical engineer, to help me. We did the same thing and tried 4 different stores to locate the fuse. No one seems to be selling them. If you locate one please let me know.
    Ed E. Camarillo, CA, e_hiza@yahoo.com
  • e_hiza Sep 01, 2008
  • moe_cabral Sep 02, 2008
    Does anyone know where to get this fuse even if its in bulk. We have the same problem.
I went to Radio Shack and bought a 4 pack of 6.3amp 250v glass fuses (5x20)...stuck one in and it works like a charm.
Anyone know of any problem using a 6.3amp fuse instead of an 8amp one? I am thinking it just would blow out sooner...and I have 3 more I can go through until I find an 8amp fuse...am I crazy?
Posted on May 01, 2009
  • toulomelis Feb 15, 2011
    i used the 6.3 amp and it blew the second i plugged it in. and sparked at the wall.. and burnt the plug where i plug it in..
You can get the Fuse at digikey.com
Posted on Jul 30, 2010
Radio shack had the fuses
Posted on Mar 03, 2009
Google images of this (t8ah250vp), then click on the first pic about a gut fixing his 50"
Then Try here for the correct fuse,
http://www.intermtnfuse.com/)
Posted on Feb 26, 2009
Have you guys tried and automotive store for the fuse its an 8amp 250volt fuse worst that happens is the fuse pops again and your out a couple of bucks
Posted on Sep 22, 2008
  • 2,296 Answers
If when measuring the fuses, you should hear a beep if the fuse is good when the multimeter is selected to continuity. If the multimeter is selected to ohms you will see zeros on the display if the fuse is good and OL if the fuse is blown.
I would suggest to measure the fuses first and possible the voltages after determining the fuses are good.
Posted on Jun 01, 2008
Fry's has the replacement fuse, identical to the Littlefuse T8AH250VP, manufactured by NTE Electronics. Part # 74-5SC8A-B (ceramic, slow-blow 8A 250V). 5 per package for $4.99. I'm replacing the burnt fuse on the power supply board on my Philips 42" plasma, right next to where AC cord attaches to the board. I hope it works!
Posted on Sep 05, 2013
  • 1,684 Answers
The E.T8AH250VP fuses are available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=316
Posted on May 18, 2013
42PF7320A/37 went dead, no LEDs on, no normal clicking when you connect the power cord . Though reluctant to do so, I opened the case with torx drivers, verified 120 VAC was coming out of the AC line filter with multimeter. Pulled out the fuse off the main board adjacent to the ac input connector. continuity check on that failed, voilla. The fuse was marked T8AH250VP. Made by company called 'Littelfuse' but couldn't confirm if its 215 or 216 series or something else. The 'T' means its time delay fuse (slo-blo). The H means High break current, in other words, its ceramic. So Fry's had the 8A 250V slo blo ceramic fuse that was close to same size. Never could find out what the 'P' referred to, not even littlefuse's sites's fuse ratings description included that tidbit. Philips referred me to http://www.encompassparts.com/, which I considered calling but wanted my tv up quickly, and that it is. Bought an AV surge protector that I should have had in the first place. Good luck God Bless.
Posted on Dec 31, 2009
I have the same problem with a fuse, a 3500.00 Plasma tv down for a 3.00 fuse. This is BS. They want me to pay 800.00 for a new board when all it needs is a 3.00 fuse. Any onw know where to find a fuse, T8AH250VP.
Posted on Aug 25, 2008
I'm trying to find the same fuse phillips will not sell
it they say it a non sale item. i tried a company on
line but they have a minium purchase of $300.00
to purchase this item. I'm still looking, my local area
electric store will give it for free if they had one, they
said it only cost about $3.00
still trying to order, if i can find it i'll let you know
ana
Posted on Aug 23, 2008
2 Suggested Answers
SOURCE: my dead 42" plasma - power problem
I have same issue with Samsung HP-S4253 Plasma. The fuse is a Littlefuse (manufacturer they do not sell), I have search and called over 20 places and the latest is Fuses Unlimited but it is discontinued and they do not stock but they can order. I will not be able to contact them until the holidays are over. There most likley is a minimum order. If there are other fuses you need write down part #'s so you can fill the minimum if required.
If there is anyone out there that can help with finding these hard to find fuses it would be appreciated.
There are most likey other Plasmas or TVs that use the same fuse just have to figure out witch ones they are.
Fuses on Power Supply Board: The 8 amp is the one I require.
T8AH250V P
T10AH250V
Break Down of Fuse Description:
T = Time Lag
8A = 8 Amp
H = High Breaking Capacity (Ceramic) 1500A @ 250V AC
250V = 250 Volts
P = RoSH Compliant
Posted on Jan 01, 2009
The green led blinks 12times. local repair guy guy said somthing about taking out the y.
Power LED blinking it about 90% power supply board is dead.The other 5% are both boards some time are dead.The power supply board and the Tuner siginal board is dead.Replaced the power supply board it ur best bet to get power back.After power is back should get picture too.Not than the Tuner board also need it replaced.Tries Websites Shopjimmy.com,Ebay.com for boards parts.
Feb 16, 2010 | Sanyo DP42746 42 in. Plasma Television
Lg 42pg20 Plasma Will not turn on
If there is no LED burning to indicate there is power than the power supply is faulty.Repair is not verry easy to do with these complicated power supply's.
Nov 02, 2009 | LG 42PG20 42 in. Plasma HDTV
Dead, no power
It sounds like ze power supply blew when it was being turned off. This seems to be typical of plasmas. Bad power supplys wont let the tv come on and will result in no lights coming on. Since there R no lights coming on, I would suspect the power supply first, followed by the power control board,. and circuit board. It may cost anywhere from $250 to $500 to fix.
May 14, 2009 | NEC PXT-42SX1B 42 in. Plasma TV
T8AH250V P
T10AH250V
T = Time Lag
8A = 8 Amp
250V = 250 Volts
P = RoSH Compliant
Aug 25, 2008 | Toshiba 50HP95 50 in. Plasma Television
42" Plazma Dead
Check the fuse on the powersupply & non-powersupply area, this was very common problem like the one you have experience..
`micro
Jun 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Dead 42" plasma - power problems
that was good to know.. good luc on your work..
`micro
Jun 01, 2008 | Philips 42PF9630A 42 in. Plasma Television
Atombomb72 - 42" dead plasma
This is the correct fuse:
see www.digikey.com
digikey part number is F2668-ND.
Black Bars
Hi guys.  This is totally fixable and pretty easy if you have tech skills at all.  I performed this fix even before I found the following thread that will explain it, and it worked flawlessly!  Read it entirely and follow carefully.  this works on many different models of plasma's.
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
Nov 26, 2007 | Dell W4201C 42 in. Plasma HDTV
Got a 42 sampo plasma tc, no picture
Howzit Brother.
I had the same problem, but managed to repair it myself! There is no need to purchase a new
Power Supply! You can service the faulty PCB yourself, or give it to a Tehnician to service for you.
If you want to try service to yourself, here is how,
On the PCB marked QPWB11326-1B-4 you will need to do the following<
Replace the following Capacitor's, CS704(Most important one), CS705, CS706, CS707, CS708, CS713, CS715.
Replace the TOP210PFI IC marked ICS02
Replace the PC123 OPTO marked ICS03
Replace the TL431 Shunt Regulator marked ICS04
This solution should work! email me on engineering@elektroniktechnisch.co.za if you have any other requests!
Gavin Burger.
Jun 12, 2007 | Sampo PME-42V3 42 in. Plasma Television
Philips 42PF9630A 42 in. Plasma Television Logo
4,143 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
