Question about BenQ FP71E 17" LCD Monitor
Monitor goes on/off in 2 seconds
My monitor, when I turn it on (after having a very brief sighting of the BenQ logo) it goes off in 2 seconds. Please help me. Thanks to all in advance.
  • 6 more comments
  • thukhauser Jun 03, 2008
    I also have problem like this
  • Anonymous Jun 15, 2008
    I had the same problem. Resoldering the transistors solved the problem.
    Thank you.
  • garyhui Oct 15, 2008
    I have the same problem, and I resoldered the transistors (without
    replace to a new one) and the problem is solved. However, the problem
    keep coming back now, I have to resolder it again and again...Does any
    know the long term method to solve this problem?
  • Anonymous Oct 16, 2008
    The same problem, resoldering didn't fix it. (but i resoldered just 2 of them)
    The indicator light just for a 2 seconds, than it goes down...
  • umsumayah Dec 09, 2008
    I had the same problem. I didnt need to solder anything, it was just loose connection on the power board.
    Thank you, you all been very helpful for your advice
  • Anonymous Feb 16, 2009
    I re-soldered the transistors and it didn't help
    Still broken
  • rachid coco Mar 07, 2009
    befor the monitor is not light, because one of transistor c5707 is burn ; i replace with the BU407, then the monitor lihgt 1sec and flashign another time then becom black,
    i dont know ???
    hi is must the exactly transistor for working or there is another problem?
    note : I resoldered and chek all other c5707 transistors but the same problem.
    plz help me
  • dionhewson May 11, 2010
    when you say "resoldered the transistors" --- do you mean you soldered in NEW ones and replaced the old ones...or just redid the solder???
  • 220 Answers
Problem is related to Invertor .If you are Technically able ,resolder power transistors 2sc5707 on powerboard near invertor transformers.
Please rate the solution and provide feedback.
Posted on Jun 12, 2008
Posted on Dec 26, 2008
Monitor goes on/off in 2 seconds - 21cf173.jpg
I had the same problem. I found 4 transistors named "c5707", resoldered them all and the monitor works fine now. Thank you very much!
Posted on Aug 01, 2008
I had exactly the same problem. I resoldered the transistors and the problem was solved too. Thank you!
Posted on Jul 29, 2008
I have the same problem and cant find the specified transistors?
Posted on Jul 01, 2008
Monitor blue light comes on, the picture is on for a brief second but screen goes black, how do I fix this problem please.
I have had this problem before and had to contact the manufacturer. I was able to send them back and the manufacturer sent me a replacement. If your monitor is under warranty it should not cost you anything.
Mar 15, 2011 | BenQ FP757-12 17" Flat Panel LCD Monitor
Benq FP222W The monitor switches on and shows the Benq logo, then screen goes black.Tested on 2 computers and still not working.
A bit late I know, but I have the same monitor with the same problem - see here . Problem with mine was one of the backlight assemblies had died. No mean feat to replace these. If you can do it yourself it'll probably cost around $50, otherwise it's for the scrapheap.
Jul 05, 2010 | BenQ FP222W LCD Monitor
Power light on no screen shown
unplug from pc, turn on monitor. if there is a 'no signal' or any image displayed on the screen then the problem is not the monitor..
Nov 15, 2009 | BenQ FP737S-D 17" LCD Monitor
Monitor E172FP only fashes on then turns black.
its a bad solder/heat problem with the power board you need to repalce eaither the board or parts on the board the parts on the board are:
Q743 - FU9024N
Q741 - FU9024N
Q759 - 2SC5707
Q739 - 2SC5707
Q760 - 2SC5707
Q740 - 2SC5707
and part PF751 the black fuse - 3A 125V
i don't promise that this will fix it but its worth a shot
Apr 10, 2009 | Dell E173FPb 17" TFT LCD Monitor
Please help me fix this benq monitor
There are many posts that have solved this. Check em out
Oct 09, 2008 | BenQ FP71G 17" LCD Monitor
Flickering then off
Problem is with Invertor Board maybe defective 2SC5707 transistors.
Jul 28, 2008 | BenQ FP71E 17" LCD Monitor
Power but no picture
Try to re-solder the inverter part of the board. You may recognize that part where the 4 connectors from the backlight tubes can be found.... usually the small transformators (sorry, my technical English is not good) have bad soldering eyes after longer use. This may work if backlight turns on for a few seconds, then the power led is still alight but screen goes dark.... the inverter then "thinks" one of the tubes might be defective and turns power off. Hope this helps a little...
Jun 20, 2008 | BenQ FP71E 17" LCD Monitor
Monitor Randomly Turns Black
I have exactly the same problem with my Benq FP71E+ ..
What i found is a temp fix is this :
When monitor dims and goes black i turn it off , hit the bottom left side (near the BENQ logo) turn it on again and it works ..
This works every time for me . But after a while it switches off again , could be 5 minutes could be 5 hours . Its random
May 02, 2008 | BenQ FP71E 17" LCD Monitor
Benq 17"Lcd monitor fault
Resolder the power transistors on inverter board and also check them.If display is not there at all some of this 4 transistors C5707 should be defective.Check associated fuse and Fet which drives the transistor.
Also check with Benq ,Normally offers three year warranty.
Mar 23, 2008 | BenQ FP737S-D 17" LCD Monitor
BenQ FP71E 17" LCD Monitor Logo
1,830 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
