In Grudic TV t55- fuse keeps blowing up on switching
2 Suggested Answers
  • 44 Answers
SOURCE: philips model 29pt3425-79 flat screen wont switch on
May try to replace your power supply. Average cost runs $200 via Internet. Also may inspect test & replace deformed an or any bulging caps.
Posted on Jun 02, 2009
My crank fuse keep blowing what cause it to blow
Ignition Switch / Starter Fuse keeps blowing. - CarGurus
www.cargurus.com > Questions > Ford > Focus
CarGurusAug 14, 2010 - Ignition Switch / Starter Fuse keeps blowing. - I own a 2002 Ford Focus, 2.0l SPI engine. 5-speed manual trans. Recently bought from a friend's ...
Jul 28, 2015 | Cars & Trucks
Grundig t55-549 forgot pin code
Try 0345 563 582 515 098 584 219 104 233 223 065 471
Grundig
FT70-700 822DOOFA MW82- 500IRDT ST63725 ST63755 TF55-302 GT210S. MW822699 CVC2030ST ST70-875
563
Grundig
T70-1021, T70-1022
065
Grundig
MW82701 ST55/730 MW70/2700
582
Grundig
GT1401
515
Grundig
T55-1120 T55-1020 WF703020
471
Grundig
32WF100 W82-2030
584
Apr 21, 2014 | Televison & Video
User owner's manual Grundig T55-732/5 text
Dear......
My father in-law who has died used to own a classic 14" Tv Model T 20-6210/6, with a remote control Model TP 711, when I switch it ON a Key with 4 stars shows up, I tried few numbers including 0000, but unfortunatly no luck,
pls. advice for the following:
1 - what is the (manufacturer) original password (key password)
2 - If I need to reset it where is that and how
3 - I need to reprogram the TV how is that
Knowing that :
- I do not know german language and I have been adviced by Grundig main site to download from Buchproduktion.......
Many thanks in advance
Eng. Nazir Touma (Lebanon)
May 13, 2010 | Televison & Video
Philips model 29pt3425-79 flat screen wont switch on
Jun 01, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Fuse inside tv keeps blowing
Hi there!
If the fuse rating is correct as indicated on the board, then the PTC is probably busy going faulty. If not sure where it is located, normally on the front where the switch is and where the coil that sits around the tube is connected to the board. Little plastic box with three pins(sometimes two) black or cream in colour. Some circuits use a disc type with 2 legs, however not sure on your set. This is called the degausing circuit and demagnetises the tube every time you switch the TV on. Good luck, JUS004
Mar 16, 2008 | Sanyo DS31520 31" TV
Blown fuse
Most likely there was a power event (surge, brownout, ect) that caused the power supply to fail in the TV causing the fuse to blow. you will need to have someone come and look at the unit and give you an estimate. If you keep putting fuses in and blowing them you could actually be causing more damage.
Mar 10, 2008 | Televison & Video
Main fuse blown on CT-32G11 32" Panasonic TV, Replacement fuses continue to blow.
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Jan 12, 2008 | Panasonic CT-32G11 32" TV
Checking the 6.3a slo-blow fuse
if you open your tv , you have to put back the board, there are 2  clips
one on left other in the right that keep the board to the case of tv( you have to disconnect  the cable AC before open the tv)
you can see the fuse easely ( if  i remember good there is only one
fuse about near the switch on /off
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
Proscan PS32610
Tv keeps blowing fuses it is due to short ckt in your tv in 1 power supply. 2 horl output section it is mainly due to 1 switching transistr 2 main fil cap 3 rectifier diodes 4 print short 5 h/output tra. 6 eht transformer
Sep 25, 2007 | Proscan PS36810 TV
Fuse blows.
Please check for shorted diode or condenser at power section.
May 29, 2006 | Panasonic CT-27G14 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
