Question about Pioneer DEH-P680MP CD Player
How do I stop the face from flipping when power is turned on&off from the ignition switch?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pioneer Master
  • 2,226 Answers
You don't , that is the way the radio is designed.
Posted on Oct 13, 2010
My BA ignition switch keeps on flipping back to off position, the car starts but when you release the key if flips back and car stops. a couple of times when going over a bunp it flips off..
take it to a locksmith and have a new barrel fitted
why a locksmith because he can key it so that you can use your existing fob key and will not have problems with the immobilizer system
Jan 05, 2017 | Cars & Trucks
My car alarm won't turn off and I cant start my car. How do I fix this?
Just push the open button on your remote opener, or hit the panic (red) button again.
Dec 23, 2014 | 2004 Toyota Sequoia
Battery was dead. -30 celcius outside. Boosted battery and truck started. After driving for a while, went to turn off truck, and with ignition switch off and key out, engine still ran as if the key was in....
I suggtes check in the Power Distrbution Box (under hood), the power distribution box, trailer tow and electronic shift on the fly relay blocks are located in the engine compartment near the brake master cylinder.
Look position 20, 50AMP (Maxi Fuse) for Ignition Switch (B4 & B5) ans position 21 (same sizes) for Ignition Switch (B1 & B3)...
Keep us updated.
Feb 01, 2011 | 2000 Ford F250 Super Duty Crew Cabs
2000 Sable sedan - which fuse is brake lights? Don't have manual.
USE A FUSE TESTER, TEST ALL THE FUSES, UNDER THE HOOD & INSIDE THE CAR. THERE ARE TEST POINTS FACING OUT ON THE FUSES. THEY CAN REMAIN IN THE FUSE BOXES. TURN ON IGNITION SWITCH DURING THE TESTING. POWER ON ONE SIDE ONLY, BAD FUSE. POWER ON BOTH SIDES, GOOD FUSE. POWER ON NEITHER SIDE SPARE FUSE.
Jan 23, 2011 | 2000 Ford Taurus
The battery went dead, had to jump start the car. The radio stays off & a blank screen. how do I restart the radio Thanks
GET A GOOD FUSE TESTER, TEST EACH FUSE. THERE ARE 2 FUSEBOXES. ONE UNDER THE HOOD & ONE IN THE DASH. ALL FUSES CAN BE TESTED WHILE STILL IN PLACE. THERE ARE TEST POINTS FACING OUT. TURN ON IGNITION SWITCH FOR THIS TEST. POWER ON 1 SIDE, BAD FUSE POWER ON BOTH SIDES, GOOD FUSE. POWER ON NEITHER SIDE, SPARE FUSE.
Jan 10, 2011 | 1991 Lexus LS 400
Turn signals and brake lights won't function
IF ALL FUSES RELATED TO THIS PROBLEM TEST OK, CHECK OR REPLACE THE TURN/SIGNAL/HAZARD FLASHER, { LOCATED UNDER DASH, NEAR STEERING COLUMN, PROBABLY SQUARE & BLACK. IF THAT'S OK, IT WILL HAVE TO BE THE TURN SIGNAL/ HAZARD SWITCH. ALSO CALLED COMBINATION SWITCH. REMOVE THE PLASTIC HOUSING AROUND THE STEERING COLUMN UNDER THE STEERING WHEEL. IT LOOKS LIKE THE AIRBAG & A LOT OF SPECIALIZED TOOLS WILL BE NEEDED. YOU MAY HAVE TO EMPLOY A RELIABLE SHOP IF THE COMBINATION SWITCH IS THE PROBLEM
Jan 10, 2011 | 1996 Chevrolet Cavalier
KDC-X869 Face Flips Halfway, Unit Turns Off
I have worked on many of these radios and there is a lever that contacts switch to determine position of face this lever wears out and switch does not operate properly causing radio to lose its mind. This is usually the cause of this failure unless flip gears have been damged somehow. contact kstahl65@att.net for additional info
Jan 21, 2008 | Kenwood eXcelon KDC-X879 CD Player
Kdc-x879
it needs a new ribbon cable. Some car audio repair shops stock these (mine does). Part is about $20-30. Labor will depend on the shop.
Sep 20, 2007 | Kenwood eXcelon KDC-X879 CD Player
Pioneer DEH-P680MP CD Player Logo
63 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
