Question about Poulan P3416 16Inch 34cc 2Cycle Gas Powered Chain Saw
What kind of bar and chain oil do i use as is there a subtsitute?
  • 7,733 Answers
Give a try at ---->eRP..
Posted on Oct 14, 2010
What kind of oil goes in the oil fill?
Use standard bar and chain oil...it is for the chain
Jan 06, 2012 | Homelite Garden
What kind of motor oil is used in the chain saw. what kind of oil is used for the chain.
Hi justariblake...
You did not say if your chain saw was 2 or 4 cycle...
If it is 2 cycle...you will mix 2 cylce oil with gas at a ratio of 50:1...one pint 2 cycle oil per 6 gallons of gasoline.
If it is 4 cycle then you will use 10w30
On the bar and chain you will use bar and chain oil (a special oil made for chain saws)
Please take time to rate me
Aug 19, 2011 | Poulan Garden
16" Electric Chain Saw: what kind of oil is used for electric chain saw...
I assume you are asking about the oil for the chain. Any good quality "Bar and Chain Oil" will do fine. Do not use motor oil you use in your car engine as it will not properly lube the chain and will result in quicker dulling and early demise of the chain.
You can get the "Bar and Chain Oil" at most hardware stores or Farm Supply stores.
May 17, 2010 | Remington 16" Electric Chain Saw
What kind of oil goes in the bar oil hole?
Use CHAIN oil. Any oil will do but chain oil is thicker and sticky and will stay on the chain much longer. The price is much the same. Stephen.
Apr 23, 2010 | Homelite ZR10926 16 Chain Saw
What type of oil is used in electric chiansaw
The oil to use for the chain is called BAR OIL and if there is anything that might be universal, it is BAR OIL. You can use BAR OIL on electric and non electric saws alike. Self sharpening and non-self shaprening chains. Any manufacturer. It is BAR OIL.
Do not use any other kind of oil in your saw. BAR OIL is particularly sticky and hangs on to the chain even while cutting the wood at high speed.
Thank you for posting your question at FixYa.com
Please remember to vote
a
Nov 11, 2009 | Remington 16" Electric Chain Saw
Need to know what kind of oil to put in ryobi chainsaw
If it is an electric chainsaw (not gas powered) then the only oil you need is chainsaw bar oil, which lubricates the chain and bar during use (self feeding system). This goes into the chamber at the top of the saw. You can buy chain/bar oil for chainsaws at any good hardware store or outdoor power equipment store. You can use any brand of chain bar oil, most are pretty good.
If it is a gas/petrol operated model, I will need to know the model number to advise on that.
Jul 03, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
What kind of chain oil to use for a 10in remington electric
According to the manufacturer... "Use SAE 30 motor oil for best results. (For temperatures below 30° F, use SAE 10. For temperatures above 75° F, use SAE 40.) DO NOT use Bar & Chain oil." So, I suggest for any Remington electric chains saw not to use bar and chain oil. I hope this helps...
Jun 25, 2009 | Remington Electric Pole Saw
What kind of oil is used on the bar chain?
You will probably have to clean the oil orifice on the bar, if this does not do it you will probably have to clean and maybe rebuild the oil pump.
May 06, 2009 | Remington Polesaw Wizard
What kind of oil do I use in the oil reservoir of my chain saw?
I believe the reservoir you are talking about is for the bar chain oil. You can get it most anywhere. As for mixing the gas and oil mixture, you will need 2 cycle oil. It is available most everywhere also. Most modern chain saws use a 50:1 mixing ratio which means 2 1/2 ounces of oil to 1 gallon of gas. Hope this helps.
Apr 26, 2009 | Remington 16" Electric Chain Saw
MY ELECTRIC CHAIN SAW
With an electric chainsaw, you only require chainsaw bar oil. There is plenty of brands of chainsaw bar oil available at most hardware or pwer garden tool retailers. Use this oil and not any other generic car oil or anything like that as you will run into problems. Chain bar oil is designed to flow and the higher quality bar oils are better designed to adhere to the chain and tooth components to keep heat on the bar and chain down.
Mar 15, 2009 | Remington 16" Electric Chain Saw
Poulan P3416 16Inch 34cc 2Cycle Gas Powered Chain Saw Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
