Question about Philips 42PF9630A 42 in. Plasma Television
Atombomb72 - 42" dead plasma
Hey Jamie 687
I got brave and puled the screws off of the back of the TV. I followed the AC wire to the AC input on the board and there was the fuse. I used my friends FLUKE multimeter and sure enough, the the fuse is bad. I checked a another fuse and I got buzzed, so I know this one is bad. Its a T8AH250V P. Do you know where to find them?
Hey thanks for the feedback too. You were right on it!!!!
Adam
  • Anonymous Aug 29, 2008
    same problem found fuse blown - were do you find this fuse - t8ah 250vp
This is the correct fuse:
see www.digikey.com
digikey part number is F2668-ND.
Posted on Oct 03, 2008
Did replacing the fuse work?
Posted on Oct 27, 2008
  • 138 Answers
How do I remove the back cover from my flatscreen plasma TV?
Cover a table protective blanket.
Place TV face down on table.
Remove the stands legs( 2 screws each) then 4 large screws the legs attach to.
Or remove the wall mount brackets.
2 small black screws middle of the cover (above the component interface box).
Remove the component interface box, 5 small black screws , 2 on top, 3 on bottom.
6 black screws by the PC connection ports, (3 above, 3 below).
2 black screws on either side of the AC input plug.
12 screws around the perimeter.
Then the back should be able to be lifted straight up.
Aug 05, 2014 | Gateway GTW-P42M303 42 in. Plasma...
Panasonic TH-46PZ85U Plasma TV All 3 HDMI was working fine with cable box, PS3, XBOX360. I used to connect my pc to the tv with a dvi-hdmi cable, but recently unplugged it. So I tried to plug in the same...
Symptom:
TV shuts off unless all the input (phono and HDMI) cables are disconnected. The
symptom may be intermittent.
Cause:
There is an abnormal AC voltage entering the TV from one of the input cables or AC
outlet.
Remedy:
Follow the Testing procedure to determine if there is a problem external to the product.
Concept
Constant symptom
If the TV no longer shuts off when all input cables are disconnected, then one of the
input cables is introducing abnormal voltages into the TV. Panasonic Plasma TV sets
have 3 wire AC plugs.
As a result, abnormal voltages introduced into this TV will cause the TV to shut off for
protection.
Intermittent symptom
If the abnormal input voltage is borderline (marginal), the TV shut off symptom may be
intermittent. However the cause may still be detectable with a voltmeter.
Protection Proof:
Release the protect mode - the TV has to be unplugged to reset this protection circuit.
Threats from the HDMI input:
Excessive voltage from an HDMI cable connected product will activate the Plasma TV’s
protection circuitry. Placing an isolating / buffering connector (sometimes called a voltage
conditioner) between the TV and the HDMI input cable often solves the problem.
Testing -
Unplug all the HDMI inputs from the TV. Turn on the TV. Plug in the HDMI inputs one at a
time. The cable that causes the TV to enter the protection state is connected to the product
that has the excessive voltage (and signal). Avoid connecting this product until an isolating
connector is found.
Jan 27, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
Lg 42pg20 Plasma Will not turn on
If there is no LED burning to indicate there is power than the power supply is faulty.Repair is not verry easy to do with these complicated power supply's.
Nov 02, 2009 | LG 42PG20 42 in. Plasma HDTV
Speakers for my Dell 4200 Plasma TV
in stock at allrepair you have to call them
1-719-687-6997
Jan 12, 2009 | Dell W4200 42 in. HD-Ready Plasma...
My dead 42" plasma - power problem
I have same issue with Samsung HP-S4253 Plasma. The fuse is a Littlefuse (manufacturer they do not sell), I have search and called over 20 places and the latest is Fuses Unlimited but it is discontinued and they do not stock but they can order. I will not be able to contact them until the holidays are over. There most likley is a minimum order. If there are other fuses you need write down part #'s so you can fill the minimum if required.
If there is anyone out there that can help with finding these hard to find fuses it would be appreciated.
There are most likey other Plasmas or TVs that use the same fuse just have to figure out witch ones they are.
Fuses on Power Supply Board: The 8 amp is the one I require.
T8AH250V P
T10AH250V
Break Down of Fuse Description:
T = Time Lag
8A = 8 Amp
H = High Breaking Capacity (Ceramic) 1500A @ 250V AC
250V = 250 Volts
P = RoSH Compliant
Aug 25, 2008 | Toshiba 50HP95 50 in. Plasma Television
Dead 42" plasma - power problems
that was good to know.. good luc on your work..
`micro
Jun 01, 2008 | Philips 42PF9630A 42 in. Plasma Television
I went to Radio Shack and bought a 4 pack of 6.3amp 250v glass fuses (5x20)...stuck one in and it works like a charm.
Anyone know of any problem using a 6.3amp fuse instead of an 8amp one? I am thinking it just would blow out sooner...and I have 3 more I can go through until I find an 8amp fuse...am I crazy?
Red blinking light on a Magnavox Plasma TV
Here is the solution. For less that 100$ your Magnavox Plasma TV. Model # 50MF2310/37 will be running like a champ.
Issue:
Magnavox Plasma TV. Model # 50MF2310/37 screen has no picture. There is no sound, TV comes on and then after a few seconds clicks and screen remains blank.
Cause:
On the main power circuit board to Capacitors are prone to failure from over load. The caps are 3300uf 10v 105+c capacitors located to the left of the AC power input.
Service:
Magnavox will refer you to a service center. They will advise $$$ for an inspection. They will also want to charge upwards of 500$ to replace the entire board.
Solution:
1. Unplug your TV
2. Disconnect all connections from your TV
3. With assistance lay your TV on its face on a non-scratching service
4. Remove the back panel screws.
5. Lift back panel off
6. The central board is your main power board.
7. Remove all wire harnesses from the main board.
8. Remove all screws that are holding the main board in place.
9. Lift the main board out and carefully place it into a non electromagnetic pouch.
10. Take the board to a Circuit Board repair shop.
11. Have them replace the the above mentioned Caps.
12. Re-install the board in your TV.
NOTE: Replace the caps with 3300uf 16v 105+ high temp caps(preferrably Japanese caps)
This fix cost me 80$ and my time to search for other who had the same issue. Try searching for Magnavox Plasma TV. Model # 50MF2310/37 bad circuit board or Magnavox Plasma TV bad capacitors or Magnavox Plasma TV bad ciruit board.
Hope this all help, Magnavox is should take ownership for this problem and recall any tv's that have these caps in them. The worst part about this is that teh **** from the repair center that was paid 100$ to check the TV, stripped out the screw holes and damaged the case for the TV.
Portland Laptop Repair was awesome. They repaired the board and it looked like new. Check them out at http://www.laptopportland.com/
Jeff G
Portland, OR
Feb 10, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Philips 42PF9630A 42 in. Plasma Television Logo
394 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
