Whirlpool Washer wont spin or drain
My Whirlpool washer wont spin or drain.  The timer however does advance through those cycles and I can hear it click/ticking as it advances.  What could be the problem? MY WASHER WONT SPIN OR AGGITATE REPLACED THE LID SWITCH ALREADY THAT DOESNT SEEM TO BE THE PROBLEM
  • IMASAUCEDO Jun 02, 2008
    HOW DO YOU DO THAT?
    Scholar:
  • 110 Answers
Check your run capicitor
Posted on Jun 01, 2008
Whirlpool top load washer won't advance through cycles
A small motor that rotates the timer has gone bad. Common practice is to replace the timer. Usually a mechanical timer of this type is less expensive than a computerized timer.
Mar 14, 2012 | Whirlpool LSB6300PW Top Load Washer
Washer fills up and starts. Once it gets to rinse cycle and spin cycle is makes a loud humming noise but wont spin. If i open the top lid and wait a second or two and close it, it starts the cycle. Been...
If you have a direct drive washer made by Whirlpool, your washer transmission has what is called a neutral drain built into it. It is designed to pump water out before it starts to spin. After water has drained out, the timer has a pause in it where motor shuts off for about 5 seconds. When motor comes back on, transmission is then in gear to spin. If timer never pauses, then washer never goes in gear to spin. Timer is most likely defective.
Sep 14, 2017 | Whirlpool WTW5100S Top Load Washer
Washer will not spin
Your neutral drain is not locking in.
Let the timer advance to the final spin cycle. Once there it should have about a 5 second pause and the transmission spin gears will lock in. If no pause replace the timer. If you have the pause and still no spin replace the transmission.
My bet is on the timer.
Apr 01, 2009 | Whirlpool WTW5200S Top Load Washer
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Whirlpool washer
    hi thanks for your question. how do you turn the water off with the taps. i think you have a water level problem .check the water level switch thanks the appliance doc
    Oct 10, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    Washer stops after agitation cycle, tub full of water. Won't drain. Will drain if advance to spin cycle. Top losder
    if washer will wash drain and spin when timer is turned manually suspect timer although have known an intermittant problem with lid switch
    Sep 22, 2008 | Whirlpool Washing Machines
    Whirlpool AWO3761 stuck mid-cycle
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Not draining
    what happens once it quits and you advance the timer back to a nother spin cycle does it spin or does the motor not start back
    Apr 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    check your lid switch. if it will aggitate and not spin or drain.. then your lid switch is your answer
    Oct 29, 2007 | Whirlpool LSR5132PQ Top Load Washer
    Washer clothes
    Does the washer fill normally and just stop? Or, does the washer fill, go through a complete cycle, and just won't drain? There could be a couple of problems that cause a no drain issue. 1. FILL NORMALLY & STOPS, WILL NOT SPIN - This is usually a bad lid switch. If you open and close the lid, you should hear a "click", indicating the switch is working. 2. FILL NORMALLY, AGITATES, WILL NOT DRAIN - This could be a clogged drain pump, pinched hose, clogged rain line. Also, you need to make sure timer is advancing properly. If the timer never advances, the washer will fill, but won't go into agitate or spin. Let me know if this is helpful.
    Aug 09, 2007 | Whirlpool LSR5132J Top Load Washer
    Washing Machines Logo
    441 people viewed this question
    Top Washing Machines Experts
