try selecting the input source on your TV to the one you are using, sometimes auto-detect doesn't seem to work properly. This can be done by the remote control, or the buttons on top of your set.
You might also try changing the physical input socket, eg to the RF in, SCART, HDMI etc (you will probably need different cables for this), but if your set is selecting another source you will still get this message.
Also you might try using a different input device to check your TV, although this is unlikely to have any effect because the input devive plays on your second set.
then 0178 is not the right code if the light blinks twice try code search turn the tv on press tv then hold setup till it blinks twice then point the remote at the tv then press the power button repeatedly till the tv turns off then press the tv button again
call LG if you think the TV is not accepting the signal from the remote the TV may have a fault in it. If you have any universal remotes try programing them to control the TV if they work but the other does not it is remote.
You need to isolate the problem.
1) Unplug the set for a few seconds then plug it in. 2) Operate the TV with the control/buttonson the TV. (Channels etc) If the TV operates correctly then do the following.
3) Try operating with the remote unit. If the problem returns then it's the remote failing.
Sometime remotes can be reset. Try this; Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2. (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!) Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones.
Try it again. If the problem is still there then the remote is bad.
Since this is a newTV you should use your warranty to replace any bad parts.
I had the same problem. My vizio remote for my 42 inch 2 month old vizio also seemed to stop working. Here's what I did: My vizio remote (like most remote's nowadays) was designed for multiple components (tv, dvd, vcr, etc). All you need to do to make the remote work again is set it back to tv. Now, the confusing thing about vizio remotes is that they actually have TWO places where you can switch the remote to the appliance you want to control. One is on top of the remote, the other is on the BOTTOM. Switch it back to TV using the BOTTOM. My remote had stopped working because I had inadvently switched it to another component on the BOTTOM component switch.
Ok I just dealt with the Sharp customer support for this problem.
1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system) 2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged 3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read) 4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
Perhaps you can try what I do when my KV24FV300 runs through channels and will not stop. Hard to watch and remote will not work. Nothing works but on and off from set.
Sony Says: Take all batteries out of ALL remotes that you use in any way for that set, VCR, etc. ALL batteries out. Turn TV off at set. Unplug TV. Wait at least 15 minutes then replace all batteries in ALL remotes. Plug TV back in and turn TV on from set.
Maybe, just maybe it will work. If it does not work why not call Sony, they always say that cannot happen but they have a solution for it.
