Question about Tecumseh Enduro Horizontal Engine 5 HP 2532in x 2 2532in Tapered Sha
I would like to see carb linkage diagram for 6hp horizontal shaft engine my linkage was all missing
  • 7,733 Answers
Try here ------->link .
Posted on Oct 14, 2010
Troy-Bilt w/Tecumseh HMSK 80-110 engine. Where can I get a repair manual covering the carburetor OR a picture showing carb linkages?
There are a couple of reasons this could be happening.
1- The throttle shaft could be frozen or gummed up where the throttle shaft sits in the carburetor body.
2 - Check the top of the throttle shaft where the shaft meets the plate, if it is loose or separated it will not allow the throttle plate to move.
3 - The governor spool may be damaged internally in the engine.
Added a couple of Tecumseh manuals below.
http://www.barrettsmallengine.com/manual/tecumsehcarburetormanual.pdf
http://www.barrettsmallengine.com/manual/tecumsehlheadmanual.pdf
Jan 29, 2016 | Garden
Carburator linkage
The governor link hooks on the top right of this carb and the throttle linkage is on the left all this is you standing in front of engine looking toward the steering wheel with the hood off
Sep 03, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I have a 10 hs tecumseh motor on a riding mower i need an explode view of carb and linkage when start-up engine it goes wide open
Hi and welcome to FixYa, I am Kelly. I understand you have a 10 HP Tecumseh engine. There are service manuals available on line for your engine but without your engine model number it is difficult to pass you the correct one: Here is the link for the service manuals:
http://www.mymowerparts.com/pdf/Tecumseh_Service_and_Repair_Manuals
Somewhere in the list is your manual.
This is my best guess without your engine model number:
http://www.mymowerparts.com/pdf/Tecumseh_Service_and_Repair_Manuals/TECUMSEH_SERVICE%20_REPAIR_MANUAL_OHH50-65_OHHSK50-130_OHV11-OHV17_OVM120_OVRM40-675_OVRM120_OVXLC120_OVXL120_OVXL125_695244A.pdf
^-Make sure you read about Adjustments in section 1 also.
Running wide open causes:
1. Broken throttle control plate spring
2. Governor spring problem
3. Internal Governor flyweight has departed the governor gear.
4. Throttle plate (butterfly) attached to the throttle shaft in the carb throat has come off the throttle shaft.
5. Broken / missing linkage
6. Someone loosened the governor shaft bolt at the base of the governor arm and allowed the governor to get out of adjstment.
Thanks for choosing FixYa,
Kelly
Aug 12, 2011 | Tecumseh Garden
Upon starting engine screams then idles down but doesn't have power to run snowblower
SOUNDS LIKE YOUR GOVERNOR LINKAGE IS NOT ADJUSTED RIGHT , OR YOUR THROTTLE SHAFT IN THE CARB IS BINDING.
Dec 09, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
1978 Dodge 6-225 3.7 ENGINE CARB
Sounds like the kick down linkage is missing. Try your local recycler. Most dodge 225's have similiar carbs.You may find what you need there.
Sep 14, 2009 | Dodge Diplomat Cars & Trucks
Need linkage diagram for 6HP briggs carb from snapper comet mower
Try looking up your product here: http://www.snapper.com/manuals/
If you can't find what you need there, please try to contact Snapper at: http://www.snapper.com/contact/
If it's the linkage on the engine itself, try Briggs & Stratton's website here: http://www.briggsandstratton.com/maint_repair/manual_and_more/
Hope that helps!
Apr 30, 2009 | Snapper Electrical Supplies
Tecumseh hm80 snow blower motor linkage
below is a web site for you to check out the parts at. Hopefully this helps you out. If not, let me know and I will try to get you a better diagram. thanks.
http://www.outdoordistributors.com/pdf/Tecumseh/TECUMSEH-MODEL-HM80-155315N-PARTS-LIST.pdf
Mar 23, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Manual for a craftsman 6hp shredder
Go to Sears Parts Direct and put your model number in and a parts list will come up. You can order a part or even a manual. I think this will help you. Don
Mar 17, 2009 | Heavy Machinery
1997 Dodge Ram Van gas pedal stuck almost had wreck?
I honestly don't see how changing the computer could cause this - I would first suspect a broken return spring on the throttle body. With the engine off, trace the gas pedal's linkage (or cable) back to the point where it attaches to the engine (throttle body or carbuerator if not fuel-injected). There will be a shaft it attaches to on the throttle body (or carb). Disconnect the linkage at this point and try to rotate this by hand, it should snap back when released. If it does, you probably have a 'frozen' cable which needs replaced. Don't forget to replace the linkage where you removed it now. If it doesn't, look for a 'missing spring' on the throttle body's side or any place the linkage appears bent or could 'snag' on anything. If the attachment point doesn't rotate smoothly or 'binds', or kind of 'wobbles' in it's holes the shaft bushings need replaced or the shaft is bent and needs rebuilt. While your'e there, regardless, you should take some 3-in-1 oil and lightly lubricate any points where the shaft, cable, or linkages touch any other part.
Nov 15, 2008 | 1997 Dodge Ram
Tecumseh Enduro Horizontal Engine  5 HP 2532in x 2 2532in Tapered Sha Logo
1,093 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
itsman
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
