Question about Bosch Classixx WFC 2465 Front Load Washer
Fuse keeps blowing
My washing machine' s fuse blew halfway through a cycle. The new fuse now blows each time the plug is plugged in. Machine fault or electrical fault?
This is probably a water heater problem  Try operating on the lowest temp  eg.15C If it goes through the cycle then its more than likely your water heater  You will need a refit
Posted on Jun 15, 2008
Washing machine keeps tripping electric when the door locks
Washing machine tripping or fusing electrics > ... > DIY Washing Machine Repair Help
Jun 26, 2013 - A Washing machine tripping or fusing electrics is a fault you can't really deal with unless ... If washer has tripped the RCD or fused the plug but now won't work properly. ... Here's an article on Washing Machine Door Will Not Open ... If youkeep resetting it without fixing the cause of the tripping it can blow ...
6 common washing machine problems and how to solve them
Feb 10, 2014 - As mentioned earlier, front loader doors lock during the cycle to prevent the water from ... The washing machine keeps tripping the power!
Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and ...
? 7:00
Jun 13, 2013 - Uploaded by
Yeah, keep it ... Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and will not always run - .... TROUBLESHOOTING Top Loading Washing Machines in ... Maytag Neptune Door Locked but No Spin - R11 is not burnt ...
Washing Machine keeps tripping the electrics -
Dec 29, 2015 | Washing Machines
Machine keeps tripping out when starting wash cycle - electrics have been checked by electrician - no problems- have managed to get it to spin but not to wash
The washing machine is obviously drawing too much current for the breaker to handle. This could be due to the washing machine drawing more that it should or because the breaker cannot handle the current the machine needs, coupled with the other machines on the ring main. If the fuse on the plug of the washing machine does not blow, then it could be that there are too many appliances on the ring main. The fuse on the machine may not blow however, if the breaker has a faster blow time than the fuse in the plug. Try plugging the washing machine into another ring main. Or try plugging out all the other appliances on the same ring main and test it out.
If the ELCB (Earth Leakage Circuit Breaker) is tripping only when the washing machine is running then something in the machine is faulty.
One common problem is the heating element. Over time they tend to crack and when the water gets in, the ELCB will trip out. This can be problematic to diagnose as offten the element will only trip after a period of heating. Bottom line, if it is tripping the ELCB then it is dangerous and should be fixed before any further use.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting
Aug 05, 2011 | Creda W120VW Front Load Washer
My washing machine keeps shutting down and blowing a fuse.
You must have a short circuit ,try disconnecting things start with the heater element, disconnect one wire see if it still try motor plug, until the fault clears at least this tells you what the problem part is.....
Apr 11, 2010 | LG WM-2077C Front Load Washer
Hotpoint Dishwasher BF1620 blew the main fuse circuit in fuse box during mid cycle wash? Re-set main power fuse circuit but now as soon as Dishwasher switched on immediately blows main kitchen power fuse...
This is happening because you have a very bad fault, a Phase to Earth short, problem. Leave machine UNPLUGGED, Breaker/Fuses OUT. do NOT use it, nor Touch it, It is possible to get severe electric shock. PLEASE get a registered serviceman to inspect this unit.
Feb 07, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
I have a Bosch Exxcel 1400 S Express which blew
There is no internal fuse in the washer to replace.
If you have replaced the fuse, make sure that is is a good one.
If you are satisfied that you have power to the washer, then I'm afraid it sounds quite serious.
Trust this helps.
Dec 04, 2009 | Bosch Washing Machines
Candy GO1482 washing machine blows house fuse
u have an earth fault on mc caused by damp or water across the neutral check for water on electrical components
Nov 18, 2009 | Washing Machines
Maytag washer blows 1.5A fuse in back of the top compartment where the dial etc is
There is a micro switch next to the fuse. It is shorted out. Replace the micro switch and solve your problem.
May 20, 2009 | Maytag SAV571EEWW Washer
Washer was in fill cycle and stopped
You've got a short circuit somewhere in that electrical circuit.
First, unplug the washing machine.
Replace the fuse. If it doesn't blow immediately, then there is likely a short in the washing machine, and from what you describe, it's in the motor.
If it blows, then there is something wrong in that circuit, and you can likely rule out the washing machine. Check all devices on that particular circuit, of which there can be a number of plugs.
Jan 23, 2009 | Maytag LAT3600A Top Load Washer
Indesit washing machine wdg1295w blowing fuse
Proberly carbon brushes in motor,Can be supplied if req.grandadfixer
Oct 11, 2008 | Indesit W 123 Front Load Washer
Bosch Classixx WFC 2465 Front Load Washer Logo
710 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
